Years versus Mileage on used cars
sjashinskisjashinski Member Posts: 1
edited December 2015 in General
Its time to start looking for a car for my teenager. I have narrowed it down to several makes/models and have set a budget for this purchase. What I would like some opinions on is whether it is better to buy an slightly older car with less miles or a new car with more miles. For example, a VW Jetta is on the list and I found an '08 with 75,000 miles and a 2011 with 110K miles for the same price. Which would you chose?
I know there is no one answer but hoping to at least get a framework for making the decision when I am ready to actually buy a car.
  • texasestexases Member Posts: 11,289
    The most important thing when I did this was the safety rating and equipment. Older cars may have as much as newer cars. I used this site, it ranks all cars, combining available crash test results:
    http://www.informedforlife.org/
  • MichaellMichaell Moderator Posts: 270,982
    Another issue is how the car was cared for ... if you can get maintenance records for both cars, that might help your decision making.
  • carboy21carboy21 Member Posts: 760
    Everything else being the same, lower miles is preferable provided the car has been well maintained .
    More the miles, worse the wear for the engine and transmission.
    I would like to see at least 8,000 miles/year, much less and I start worrying about the car being driven rarely, without enough maintenance.
    I agree that there's no straight answer here. All new cars are the same but every used car is different, and has to be judged on a number of factors. For a German car, I'd generally choose lower miles, but I'd also take a very careful look at the maintenance record before making up my mind.
  • If you are concerned about durability I would, for sure take Volkswagen off your list!
    For that matter, anything european.
