Rubber gasket around moon roof ripped
with parts and labor what should it cost to replace the rubber gasket that is around the moonroof? Mine tore and I was able to close it and water is not leaking. If I were to replace it, what should it cost?
If you pay someone to do this, figure at least one hour in the best possible case. If your car requires the entire roof assembly to be lifted out, that's going to take some time.
