I have taken my car to four different mechanics due to popping noises and squeaking noises that it was making. The first mechanic repaired the passenger side strut. The second mechanic repaired the lower ball joints and stabiizer bars. The third mechanic put on new calipers and rotars. The fourth mechanic put on four new tires and replaced the turn plate on the passenger side strut. Needless to say, I have invested a ton of money. The problem is, the car is still making noise - not as much noise- it's making noise. It makes four very distinct popping noises as the brakes are applied. As you press the brake pedal, the pops will occur as it goes down. There is also a very distinct popping noise when you make sharp turns to the left and the right. The latest response that I got from a mechanic was, "The car has 150,000 miles on it, noises are normal." I don't think these noises are normal, but nobody can seem to figure it out. Any suggestions?
My 2000 Sable has 165,000 miles on it and it's as quiet as a mouse. There's a reason your car is making noises. I would keep searching for the reason.
There was a recall on Taurus'/Sables that required the installation of some kind of shield above or around the front springs. I believe it was a corrosion issue and was designed to keep the spring from puncturing a front tire should it break. Don't know if 1999 was included in that recall. I had to have the same shields installed on a Contour and Mystique that I owned due to a similar recall. There were a number of complaints about the noise if they were not installed correctly. Some of them appeared here in the Forum. I experienced the problem on the Mystique and got it corrected. I have not had the shields installed on my Sable because I had the springs and struts replaced at 140,000, and didn't want the aggravation. (Eventually I will have them done due to it being a safety issue.) If you've had them installed on your Taurus, you might have them checked. I don't think it is the cause of the popping noises when applying the brakes, but it may be the cause during turning.
I've also had front & rear stabilizer and stabilzer link repairs done. Those can make popping noises too, but it looks like you had stabilizer bars done. Front or rear, or both?
Hey, I'm fixing a car for one of my buddies, he drive a '92 mercury sable with 200 something miles on it. He told me the other day that it shut down on him while he was driving and he pulled over on the road. When he got it back to his house, he couldnt get it to turn over, now it the ignition wont even start. He said he fixed the Fuel filter, i assume it's the EEC, but i don't know. If you guys have any ideas lemme know--schools out in a few weeks and he has to drive it home. Thanks!
Thanks for the post. It was very helpful. Before leaving for work this morning my wife said her blower was not working in her 2002 Taurus. I did some searching and found your post. When she called from the garage, I asked her if there was a puddle of water and she said yes. So, I told her the problem before she told me. Our Taurus only has 38,000 miles and already we are replacing the blower motor, which I have never had to do in any car I have ever owned. I am sending my complaint from the link you provided as soon as I get home. Hopefully Ford will have to make good on this.
I am hoping you can tell me how to get the hood open. I decided to try to check my own fluids. I pulled the knob on the inside that has a little car with the hood up icon on it really hard & it seems nothing happened. I got out to try to pull the hood up (it was still closed looking!) A long time ago I could just put my hand about in the center of the front of the hood & there was a lever you could push up on & the hood would pop up (on my 75 model Olds). Is there something like that on this taurus? HELP! :confuse:
The front stabilizer bars have been replaced. I'm not having any problems with the back of the car. All of the noises are coming from the front. Here's another challenge for you. Under the hood there is a rattling noise, one mechanic said that it is the AC compressor. However, the strangest thing happens. I can crank the car and leave it in park and the car won't make the noise. I put it in gear, leave the AC off and it will make the noise. Put it back in park and the noise will stop. Okay....I can turn the AC on while in park and it will make the noise. It also makes the noise while in gear with the AC on. In short, it will make the noise when the AC is on and when the car is in gear. Also, the check engine light is on. We had a mechanic use a computer to find out why, said we needed a new EGR valve. We replaced the EGR valve per instructions and then reset the light by unhooking the battery. Lo and behold, it's back on!
I know...I need a new car, but I really need this car to last another year and a half. I'll graduate from college then and have more money to spend.
Hi, I have this same problem on my 98 Taurus. The things that push the hood up are worn out and don't work. What I do to get my hood open is, pull the hood release like you did, and then on the vehile grab the hood at the top (where the windshild wipers are located), slip your hand under the hood and pull up, then go to the front and do the normal relase at the center.
Just bought a 2004 Ford Taurus and was wondering if anyone can help me find the location of the door keypad code? Thanks in advance for your help. Mary Las Vegas, Nevada
Hi, I was wondering if someone could please explain or link me to how to replace the front door handle on a 1993 Taurus Wagon. Thank you for your help.
As a former student, I can relate to not having a lot of money for car repairs, or much of anything else for that matter!
It sounds like you have been to more than one mechanic with the problems you have mentioned. An honest mechanic that you can put complete faith in is worth his weight in gold! I have someone like that, and he now does everything for me. I am finished with car dealerships and big chain repair shops that advertise "low price specials" on mufflers to brakes, to anything else, and then hit you with all the extras you need that weren't included in that low price! When my mechanic says I need something, I know it needs it.
Back to your problems. You will have to hook up again to the car's computer to find out what code has been tripped with this latest "check engine lite". (I'm not a mechanic, but I thought clearing the codes took more than just disconnecting the battery. I may be wrong there.)
You mentioned the passenger side strut had been repaired along with a turn plate. Were these replaced or just repaired in some way? Struts and springs don't last forever. If yours are original at 150K miles, they could be making some noise when turning, maybe even during braking. Hard to say from where I sit. When it's time to replace them though, I would replace them in pairs; front or back, not one side without the other. I did springs and struts at 140K, along with lower ball joints. Total cost was around $900 if I remember right. A lot of money, but I'm planning on keeping the car for several more yrs. Don't bother putting that kind of money into it unless they're broken or absolutely need replacing.
I would search out that "honest" mechanic if you don't have one. Ask around and see if you can get a good referal from someone; maybe a teacher. They are permanent residents in the community.
Which one should I get? This car runs FABULOUS and plan on keeping it for at least another 80,000 miles (when the tires wear out), and have taken care of this car meticulously. Any feedback would be appreciated.
Thanks! - Alex
P.S. A relative or friend will install the belt for me.
I recently bought a 2006 Taurus and dealer has no code. They said they can retrieve it but I have to bring the car in. The keyless entry code can be found marked on the computer module. I have yet to look for mine as I really have no use for it yet.
My daughter ran into a car with my 95 sable. I have fixed the body but the car will not start unless we hit the unlock button on the keyless remote after we are in and seated. It starts every time if you hit unlock. It never starts if you do not. Has anyone else experienced this or have any idea what I can do to fix it. Thanks
Where is the starter located on a 1995 Ford Taurus? Has anyone changed one? Is it a difficult job? I've changed them before on Chevy's, not on Fords. Any help would be appreciated, thank you!
Interesting read! I have a 2000 Sable with similar symptoms: an exhaust/oil smell through the vents whenever the car stops at a light or stop sign. A muffler shop found no exhaust leaks. The Ford dealer replaced the oil pan gasket (said dripping on exhaust), but that didn't help. I'll take a look at the cowl/passenger air filter box as you mentioned and see if that's it.
Starter on the 3.0 Vulcan is low on the block, just below the oil filter, just above the oil pan, behind the radiator. If I recall correctly there is also a subframe cross member partially below the starter as well. I haven't had the need to change a starter on this engine (I had a 1990 Taurus Vulcan and my son has a 1992 Sable Vulcan), so I cannot comment directly on how hard/easy it is.
Hi. My girlfriend has a '03 SES, 80K miles and she can not turn it over. I assumed it was the battery (here in SoCal Car batteries barely last 3 years). When she had it towed, the tow-truck mechanic tried jumping her car, and stated he thought it was the starter. How much is it to replace one? :confuse: Is the starter going in this model common? Could it be something else. The car dash lights turn on, but the car does not turn over. Comments or suggestions are appreciated.
I replaced the starter on my '00 Sable at 117K in Sep 2004 at a cost of $270 with my local mechanic. No problems since then. Currently have 168K on the car.
Regarding batteries, my dad and I have both owned Ford products for yrs, and the original batteries consistently last only 2 to 3 yrs. I live in the mid-west; he lives down south. If yours is still the original battery, have it checked along with your entire charging system so you get the right parts replaced.
I appreciate the input. I will go give her a call right now. The towtruck guy thought it was going to be $450, but she just found the starter for almost half the price ($250 vs. $140) at Autozone. Why mechanics can not go to the local autoparts store to price parts is beyond me.
Car has been idling rough for a couple months now, had significantly more trouble going up slight hills than level ground. The engine sounded like maybe all cylinders weren't firing, I dunno, but it got to sounding like a lawn mower. The rough idling kinda feels like a big [non-permissible content removed] giant is kicking my car from behind while I'm driving. It's real jerky when I'm driving. I changed the fuel filter a month ago but that didn't help. I did consistantly run the car on E which I believe is bad for the fuel injectors, don't know if that relates to my problem or not. Yesterday I was driving and the engine just stopped running, then I tried restarting and the battery sounds fine, but the engine isn't turning over itself. Any help appreciated, thanks.
my 95 Sable with 127000 miles runs great but recently overheated and shut down on my wife. since then i fushed engine coolant, installed new thermostat, replaced radiator cap and refilled with coolant. The car seems to run good but the radiator hoses get very hard once the car reaches operating temperature. Thermostat was installed correctly. anyone have any ideas. Car is not overheating at this time.
Your engine cooling system is designed to run under pressure when up at full operating temperature, which is why the hoses get hard. Shouldn't be a problem. The radiator cap is designed as a pressure relief valve to maintain a set operating pressure. Once the pressure is exceeded, it bleeds some coolant into the plastic overflow tank. When the engine cools down, that overflow is sucked back in to keep the radiator full.
As long as you do not go over temperature any more, everything sounds like it is behaving as designed.
Hello all. The turn signals aren't working on my Dad's 1996 Mercury Sable! Where is the module/relay located so it may be checked out? Thanks for your help.
Hi. I have an 03' Taurus and the horn stopped working. Everthing else is great. With my experiences with the Ranger for instance, I thought the fuse would be bad (to prevent tampering it is connected with the radio, which is odd) Anyone have any suggestions. Thank you in advance.
My 2000 SEL bought in June 2000 STILL has the original battery in!! I've driven nothing but Fords all of my life starting in 1968 and my experience has been that the original battery has always lasted longer than any other brand that I have gotten since the original, which is six years. I grew up in Cincinnati and am now living in Northern Virginia.
have a 97 Taurus wagon.... drives great... just had some of the exhaust replaced.. muffler and a couple of pipes.... It failed inspection because the check engine light is on, and the inspector say's it the catalytic converter... outside of the light, it seems fine... The mechanic said, maybe he can figure something out to get it to pass... I really don't want to replace it $$$$$. He reset the light and in 2 days it came back on.. So any ideas how to pass the inspection. thanks J
The battery clamps on my Taurus have corroded and need to be replaced. I recently replaced the battery and AutoZone sold me the "old fashioned" battery clamps, the type with the single cable that is inserted into it with a screw down clamp. Ford has their own clamp with 2 wires going into the positive and negative cable. Can I just cut the battery cable at the very end and insert the 2 cables into the new clamp or 1. Go to Ford parts, buy their cable and replace the whole cable? 2. Go to a mechanic and let them do it? The cable itself seems fine, it's just the clamps that need to be replaced.
My 18 year old daughter wants to purchase her 'first' car -- a 97 Ford Taurus with 61K miles. It is from a private party from a Grandmother that passed away. She told me that it has new tires and a new battery. The asking price is $3000.
Before I look at it -- I wanted to get opinions on the vehicle from people who have owned the car. How is the reliability? Have there been common problems or complaints? What should I look out for?
On the surface I know it would be a safe car, and it is in her price range. But she is heading off to college and I dont want her to have a vehicle that is going to be a maintenance beast! At least I would like her to have a car that would last 3-4 years until a 100,000 miles or so.
I am open to other suggestions for other vehicles as well -- I'd like her to get a Honda or Toyota -- but for $3000 or so, all I see are cars with 150K miles.
My thanks in advance for all your help and opinions?
$3000 for a 97 Taurus strikes me as a little high. I see 00-01 Tauri (the plural of Taurus) with a few more miles going for just a little over that amount.
The major problems with the Taurus of that vintage is transmission trouble and engine head gasket failure. Ask the Grandma that you are buying the car from if either the head gaskets have been replaced or if transmission work has been done.
Nobody on this forum can advise you as to whether or not that particular car is a good one or not. Used cars are a bit of a gamble. Maybe you'll get a good one. Or maybe you'll have repair after repair. If you or your daughter are not willing to do some of the work yourself then that $3k car may cost you quite a bit more.
On the other hand, young drivers tend to have little fender benders. Maybe a cheap car won't hurt so much when it gets its' inevitable dents.
Jasmith52 is in error concerning head gasket issues. Those were almost exclusively a problem with the 3.8 engine, which is not found on 1997 Tauri. Either the Vulcan 3.0 pushrod V-6 or the 3.0 Duratech DOHC have proven to be pretty much bullet proof engines.
Transmissions? Maybe somewhat of a weak point, but I know of a lot of people with well over 100K miles with no problems. Get the fluid changed and you will probably be OK for at least another 30K miles.
You can't buy much for $3K these days. If it is in good shape and driven by a Grandma, go for it. It likely was not abused and may even have been overmaintained, depending on Grandma's personality!
Any 10 year old used car is a bit of a gamble. But for 3000 (asking!!!) any car with only 60000 miles is worth a look. The best advice would be to drive the car and have it checked out on a lift. Rust issues would be terminal. I would check the suspension,fuel and brake lines,look for any leaks etc... That said,96-99 Taurus are a bargain. Both available engines will give almost 30mpg on the highway. Drivelines are stout and parts are readily available. There are many of these cars out there with well over 100000 mi. My 93 has over three times as many miles-still drives me to work everyday. Everything works too. One of the most economical cars I have ever owned.
Did you ever get a reply on this? I have a 98 Taurus SE have the same code which should indicate a problem with the Oxygen sensor Heater Circuit on the left side (front of car, left of engine). When we tested the sensor it tests good, no problem.
My wife called me panicking from the train station yesterday- car (98 Taurus GL) will start, but will not shift out of park and the brake lights don't work, the sunroof, radio, and power windoes don't work either. I checked most of the fuses and they all looked fine. I shifted to N to start car, then R and D and I followed her pretty close b/c of the no brake lights. I'll dig in this weekend to take a better look, but what would cause all that to go at once, when all worked fine 8 hours prior? Thanks! -Dan
">What could possibly be the cause that the radio will not play or no clock if all fuses are good? Is there another fuse inside the radio? Any help would be greatly appreciated.
We're looking for a first car for our daughter in college. We found a 1997 Taurus SE Sedan, the body is in fantastic shape. We took it on a test drive, handles well and seems to shift fine, no slippage. Our concern is that it has 165,000 miles. It was a fleet car for 6 years, sold to a private owner who recently traded it in. The asking price is $2100, which fits our budget. We've read about problems with the transmission. We're having our mechanic give a look in hopes of identifying major concerns. Any thoughts on how much of a risk are we taking?
asking 2100....you should get it for less. This is a safe,economical car that would make someone a great first car if treated with some respect. Less than 2000.....if everything works???? How can you go wrong. Have the car checked out. My old 93 still runs strong. 30+ mpg too.
With 165,000 miles the transmission and anything else is well worn and would be on most other cars also. If it's in good condition now and is only going to be driven low additional mileage by your daughter, it should be fine for some time.
Strange how different people can have such different experiences. My dad and I live in 2 totally different climates, our driving habits are different (I commute 500 miles a week, his is a combination of local & city), and yet, between 2 Grand Marquis, 2 Sables, and a Contour, we can't seem to get more than about 3 yrs out of the original battery. But, that's why I said to have the whole system checked out so they replace the right parts.
Maintenance is the key issue with any used car, especially one w/ that many miles. Without any records, you are going in absolutely blind. I'm not saying don't buy, but without records, you have to look for other signs that the car was well cared for. "Does it run well?" is only the starting point, which you obviously realize from your questions. Here are a couple of other things to keep in mind:
Exterior appearances can be deceiving. Years of neglect can be covered up or hidden with a professional detailing and an engine cleaning. (I know. I'm very good at that.) Interiors are another matter tho. Stains, carpet & upholstery wear, and just overall appearance can tell you a lot about the previous owner. Most of these things can not be covered up, short of re-upholstering or putting new carpeting in, but who does that?
My 2000 Sable will turn 170K in a couple of weeks. I'm told by everyone who rides in it that it still smells like new! Not sure why that is, but I know it still looks like new because I've taken the steps needed to keep it that way, and that will be obvious to the next owner. When it comes time to sell, I will also be able to provide a complete maintenance record from the day it was new along w/ any receipt they would like to see. When I tell them the transmission fluid was changed every 35,000 miles and have the receipts to prove it, they can buy the car with a little more peace of mind than something they have found on a used car lot with similar miles. Can my transmission go out the day they drive it away? Sure. But it's less likely.
I am actually planning on giving the car to my daughter in a couple of yrs, knowing I would never be able to find a comparable car for the $1000 or $2000 I could afford to spend. That would be my advice to you if you can do it. Give her a car you've had in the family and know the history of, and get something new for yourself.
I cannot find the pre-wiring location for a CD changer. I looked underneath the carpeting in the trunk and on the driver side in the trunk, but cannot find cd changer plug. please help. Thanks!!
Mary
Las Vegas, Nevada
Sorry I could not be of more help.
I have a 2001 SES w/almost 113K on it, and my serpentine belt is starting to crack a little. I usually go to Auto Zone and have (3) choices on a belt:
1. Valucraft - $19.99
2. Duralast - $26.99
3. Goodyear Gatorback (special rib design) - $33.99
- Alex
Thanks, Dave
Here's a company that does disk brake conversions...
Call em' up they probably have something that would work with your car.
Stainless Steel Brakes, Dept. MF
(716) 759-8666
(800) 448-7722
(716) 759-8688 Fax
www.ssbrakes.com
:confuse:
Kevin
Again, thanks.
Kevin
I am now looking for other possible causes.
