Speedometer not working on my 1998 Dakota, had transmission rebuilt.
dakkota65dakkota65 Member Posts: 4
edited January 2016 in Dodge
Best Answer
Answers
  • thecardoc3thecardoc3 Member Posts: 5,860
    Did the PCM have to be repaired/replaced when the transmission was repaired? Has anyone pulled codes and monitored data from the PCM, TCM and IPC?
    Is your ABS light on as well?
  • dakkota65dakkota65 Member Posts: 4
    hi yes the abs light is on , no they did work on the pcm
    its stuck in third gear and speedometer is not working
    well they got trans to shift , but no speedometer , he said the wire harness was bad and speed sensor was replaced, still trying to figure that out
    If your ABS light is on and the speedometer isn't working, chances are pretty good that the speed sensor in the differential is bad---did they replace that one or some other sensor. The differential speed sensor is a simple fix--20 minute job.
