2016 GMC Canyon Lease Questions
kyfdxkyfdx Moderator Posts: 275,750
edited December 2015 in GMC
Ask your 2016 Canyon lease questions here!
  • drewblooddrewblood Member Posts: 1
    What are current RV and MF on 2016 4x4 loaded to @$41k - 36mo/15k
  • kyfdxkyfdx Moderator Posts: 275,750
    .00163 MF and 62% residual on all Canyon models.
  • pstew123pstew123 Member Posts: 18
    Can I have numbers for
    2016 Canyon Base 2WD - Auto
    2016 Canyon Base 2WD - Manual
    24/10 , PA. Thanks!
  • MichaellMichaell Moderator Posts: 270,862
    24/10 , PA. Thanks!
    .00213 and 73% for both
  • trp3383trp3383 Member Posts: 90
    canyon 2wd all models 36/10k and 24/10k thanks
    24/10 - .00199 and between 75-79% residual
    36/10 - .00149 and between 66-70% residual
    Need to know trim level and cab style to get more specific.
  • klnmcmgklnmcmg Member Posts: 113
    MF and RV for Canyon SLT Crew Cab 2WD in NC? 36/15, 36/12
    .00149 MF and 63%/65% residual. $160 lease cash
  • culbyg7culbyg7 Member Posts: 71
    MF and Rv for 2016 GMC Canyon all terrain and slt 4x4 36/12 and 36/15 in CA
    All Canyons are .00150 MF and $160 lease cash
    Somewhere between 63%-69% residual for 36/15.
    Not sure I can decipher which model is which, though.. We don't have our usual docs, this month.
  • gamestheyplaygamestheyplay Member Posts: 1
    Any Help would be great - July - Canyon SLE Crew Cab short 2x 4 cyl gas lease deal in FL $1250 cash 1500 non gmc lease incentives with 1499 down. What are the MF and RV on 10/36 12/36. Any diff if 6cyl vs gas 4 cyl? and what makes up the 1499 - all cap cost reduction? GMC gives no detail (unlike other manuf. disclosures) and hate getting jerked around
    .00149 and 71% or 70%. No difference based on engine type.
    If this is an advertised offer, my guess is the $1499 is all cap reduction. Fees and taxes vary by state and cannot be quoted in that sort of ad.
    Canyons are not cheap to lease .. have you considered a Sierra?
  • ajpbf7ajpbf7 Member Posts: 97
    Hello. Could you please post MF & residual on a 2016 Canyon SLE V6 Crew Cab 2WD; 36/10. Located in KY if that matters. Thank you.
    .00149 and 70%
  • anderm30anderm30 Member Posts: 123
    Hello, do you have the October numbers for a 2016 4x4 v6 crew cab all terrain? 36/12 and 39/12? I am in TN. Thanks!
    .00149 and 69% (36/12) or 67% (39/12)
  • mike_brandonmike_brandon Member Posts: 1
    Are the numbers above still the same or the same for Missouri? I am looking at 2016 SLT CREW 4x4. Also, would like to know the numbers 36/10 and 36/15
    Numbers are valid through today.
    From the 12K residual, add 1% for 10K or subtract 2% for 15K
