Transmission Shifting problems
                    I have a 2002 Chevrolet Trailblazer , It has around 130k miles on it
I'm having a problem with shifting , It shifts into 1st, 2nd but it won't go into 3rd. Once it's trying to shift into 3rd it just revs up and won't go any faster or even shift
Does anybody know what the problem is or how to fix it?
It looks like when the truck changes gears in "auto" when you reach a hard curve, it is not able to properly synchronize and loud noises come from below the truck. Like if gears or cogs are not assembled or not synchronized.
I changed to 2h and the truck goes fine. It only happens in "auto". I did not try 4H because I think something similar may happen and I don't want to make more damage to the car.
Any idea what is happening?
Thnaks a lot for your comments.
Rek.
Perhaps a wheel sensor is bad, or something wrong with the control module, or the wiring harness. You should have the TCM scanned for clues here.
