Also what is the proper torque values for the lug nuts? I need to rotate my tires.
BTW dtremblay, in my case the squeak happens even when the car is in park. It stops invariably when I take it to the mechanic!!
If you are describing smoke coming out from under the front of the engine, and also getting pulled into the cabin through the heater, then I can offer my own experience with my '87 w/ a 3.0 ...
About 2 years ago (when my car was about the same age as yours is), something fell off as I was driving hat sounded like sheetmetal. Turns out it was a heatshield that was on the manifold pipe (the 'y' pipe connecting the front and rear exhaust manifolds) - didn't think much of it until this smoking stuff started. After much effort, I finally traced it to drops of oil falling onto the now uncovered exhaust pipe where it crosses underneath the front of the engine!!
Of course this is right where air is pulled into the heater/ac unit.
Hopefully this may help you towards a fix ...
Btw, I'm still looking for a junkyard that might have the exhaust shields for my own car
Suspect an oil pan leak ???
oil is dripping down onto the heat shield for exhaust. Some rolls up when I stop !
Is there anything I can do to stop the leak short of dropping entire pan and replacing gasket $200!
Exterior sealer? higher weight oil ?
I tried a prestone sealer...
I think it actually thinned the oil !
Oil seems to leak even more now !
i also need cv axle so i am real tempted to bail !
Got the car back when my daughter got Outback !
ps...anyone know how to change the coolant???
A question for hutch7. Have you had the rotors machined recently?
How many miles did you have before your CV joint went out?
The more mechanical of the 2 studied the engine pretty closely and theorized the source of the leak to be the valve cover gaskets ($17 @ Autozone).
I've not had the work done yet, but am hopeful - and still haven't written off the idea of finding those heat shields...
Will let yawl know if it helps ...
Now the air bag light is blinking...
91 Taurus wagon 3.o
142k miles
Anyone have suggestions ????
Can I trouble shoot ?
Time to look at Elantra or sonata i guess.
He took the car back to the shop and pulled the wheel off and checked all of the boots and the joints and said they felt fine. In the end, he pulled out and oiled the pins holding the right brake caliper on. You know what...the noise went away, and I haven't heard it since. The mechanic was a really nice guy, and he said that if it is a CV joint that it will definitely make a louder and harder sounding noise than the one I was hearing. Although I was disappointed that I didn't get to use my extended warranty, I was glad to find out the problem was not that bad.
That gives me an idea. Why doesn't someone maintain a site with "typical automobile problem sounds" so you can listen and try to match the sound you're hearing with those produced by typical problems? Seems like it might be a decent diagnostic tool for when someone asks, "was it more of a clink or a clank?" Thanks for all your help!
So my question is...do the rest of you experience this? I have even had Ford check to see if the components that control the alignment are out of whack. They say No... Right now my plan is to get two new tires to replace the bad ones and then get an alignment at NTB or someplace that warrants its alignments for 6 months/5K miles (Ford does not). Then I will take the darn car back once or twice to get the alignment checked and adjusted as needed, but that seems like a colossal waste of time. Any other ideas? Thanks!
I think your move to go to a different shop is a good idea. They might find a problem that another shop completely misses. Make sure they know the history, so they check every possible source.
I have gone very long between alignments on my old '90 Taurus (beyond 30,000 miles) and am at 19,000 on my 2000 with very even wear. However, I watch my treadwear patterns very closely, and at the first sign of uneven wear, I get it checked out, and of course, get a rotation. I usually stretch tire rotations to 10,000 also.
My wife's newer 96 Caravan went to 50,000+ miles before having an alignment when we bought new tires!
Just a comment...I have owned 6 Fords since 1972 and have never had one that would stay in alignment.
Yeah, the tires that every one complains about have gone 78k. Will replace them in a month because snow is coming. Otherwise I would run them another 10k or more!
I have over 26k now and have never had an alignment done. Tire wear is fine. Cars shouldn't need alignment unless a part is damaged or worn, like 100k miles worn at least.
I was looking through my own personal service notes and saw that I did take the car to National Tire and Battery about two months ago because it looked like the front tires were wearing. They checked the alignment and said it was fine and suggested that the tires had been underinflated. Of course, I didn't get a receipt from them to verify, but I will in the future...
So is the 20- mpg abnormal? Anything I should do to check it out?
Your mileage could be acceptable; think it is dependent on your driving habits and style.
My 97 Vulcan Taurus, 145hp avergaes 20mpg city with AC on (short 5mi trips to work). Long hwy trips are 28 with no AC, and 26 with AC.
I really don't know how the industry meets CAFE requirements of 27mpg. If more than 50% of automobiles are trucks and SUV - there is no way they can meet 27mpg.
Removal
1. Open luggage compartment door [trunk lid] and remove quarter trim panel. [remove 4 pushpins, two in lower center, one on each end.]
2. Remove three retaining nuts from rear lamp mounting studs.
3. Note: To avoid damaging the vehicle paint, carefully pull the rear lamp straight out. Pull rear lamp away from vehicle.
4. Remove electrical connector.
5. Twist bulb socket counterclockwise approximately 1/4 turn and remove from rear lamp.
6. Note: Do not rotate bulb to remove. Carefully remove old bulb from socket by gently pulling it straight out of socket.
Installation
1. Install new bulb by pushing straight into socket until it snaps and locks into position.
2. Align indexing tab on socket and install bulb/socket into rear lamp and twist clockwise until it locks into position.
3. Align indexing tab and install electrical connector into socket base until it snaps and locks into place.
4. Carefully install rear lamp to quarter panel.
5. Install three retaining nuts and tighten to 5-7 Nm (45-61 lb-in).
If you are needing an alignment every 5,000 miles, either there is someting seriously loose/worn/broken, or you should stop running over curbs and speed bumps at 40 mph (VBG)!
I have been getting the Service Engine Soon Light go on and off for a couple of months. Gave an excessive slippage in torque converter code last time. Tranny seems to be fine and the service engine soon light has gone off by itself at least three times. I'm not doing a thing until I get some type of sign of a problem.
I just replaced original front tires tonight. Got 78.6 out of originals. Checked my brake pads in the front and still have considerable pad left, they are original.
How is everyone else doing with their brakes. Mine is a 97 GL with 4 wheel disc.
- all ranges except reverse = 48-77 psi @ idle, 168-217 psi @ wide open throttle
- reverse = 61-99 psi @ idle, 252-316 psi @ wide open throttle
Typically, shop air pressure is about 150 psi maximum. Anybody who tells you that a flushing machine will cause seal damage due to high pressure has no idea what they're talking about.
