Leaking Rack and Pinion
At 90k miles, leaking rack and pinion.
Our 2011 Chevy Impala also has a leaking P.S. rack at only 47K miles, not covered under warranty repair. What's GM putting out defective rack and pinion and not recalling them???
You can buy a reman power steering rack for about $200. Labor would run about $400. You should also have an alignment done after this repair.
Be sure this isn't a known problem on this car--the high pressure power steering hose. Maybe the rack is ok.
