Navigation system
                    The navigation screen on my Tahoe says that it is trying to read the map disc though the map disc is in place.  The screen will not change, will not turn off when the car is running, won't respond to any side button commands or touch screen.  I can not open the system screen to pull the in place disc because the sceeen is not responding.  Does anyone know how to get the screen to release so I can pull the disc?
Maybe if you can locate the fuse for the NAV and disconnect that, that's worth a try as it won't affect your car's PCM.
