2016 BMW M3 Lease Questions
itsagerbsitsagerbs Member Posts: 2
edited June 2016 in BMW
Hi there, anyone have an updated residual for June 2016 on the M3 for any of the following:
24/10
24/7.5
«1
  • MichaellMichaell Moderator Posts: 271,414
    24/10
    24/7.5
    .00138 and 69% (24/10) and 63% (36/10).
    BMW doesn't offer 7.5K leases.
  • mjames83mjames83 Member Posts: 24
    Please provide rates for 36/15. Thanks!
    .00138 and 60%
  • westcoastwintrwestcoastwintr Member Posts: 38
    Hello, can you please provide July rates for 2016 M3, 36/10, Denver, CO?
    Any hidden dealer incentives?
    No M3 lease information for July, just yet.
  • kyfdxkyfdx Moderator Posts: 276,752
    .00137 MF and 66% residual.
  • kapkanimdkapkanimd Member Posts: 136
    what about for a 24mo and 36mo 12k mi? Thanks!
    .00137 MF and 71%/65% residual
  • sf911c2sf911c2 Member Posts: 2
    Hi kyfdx, can you please clarify the july MF on an M3. I live california and was quoted .00165 not .00137 MF. Also I saw folks quoting they got .0013MF. Is there a regional difference? I have tier1 credit. Thanks.
    .00137 is the base rate, this month. Dealers can mark it up as much as .00040 for extra profit.
    So far as we know, the BMW numbers are national.
  • Do you have the 2017 MF and resids? 36/10.
    .00137 and 60%
  • r2km000r2km000 Member Posts: 7
    Hi. Can you help provide the August rates for 2016 M3 @ 36/12 and 36/15? I'm in CA. Thanks in advance!
    .00137 and 59% or 57%
    Do residuals change throughout the month? I was hoping the dealers would be raising up residuals for the outgoing model year.
    If there are any mid-month changes, we wouldn't know about them.
    For a car as rare as the M3, I wouldn't expect much change.
  • Okay, I'm officially confused. It looks like the August residual for the 2016 is lower than the July was, and the July residual for the 2017 is the same as the August residual for the 2016. Can that be right?
    Just to clarify, can you please tell me the August MF and residual for the 2016 at 36/10, and for the 2017 at 36/10? Thanks.
    .00137 and 66% (2016) or 60% (2017).
    July and August numbers are the same.
  • paulf123paulf123 Member Posts: 6
    I'm considering either a 24/15 or 36/15 for a 2016 2017 M3. Is there a financial advantage either way?
    .00137 and 69% / 63% (2016) or 63% / 57% (2017)
    Get a 2016 ... the payment will be substantially lower.
    edited September 2016
    I was hoping you would tell me the current lease rate or owners choice rates for 2017 M3 in Houston Texas. For both 36/10 and 36/12 with residual rates. Thank you!
    Are the rates better for 2016 M3? And if so why?
    2016: .00136 MF and 65% residual. $1500 option allowance
    2017: .00136 MF and 61% residual. $1000 option allowance
    Add 1% for 10K/yr
    2016 numbers are better, because they are trying to move those models out.
  • Thank you so much. I was wondering if you had any insight regarding BMW owners choice vs lease. Which is better? Thanks again.
    OC is a program for states that charge tax on the full selling price on a lease. Since the vehicle is in the purchaser's name, it preserves the trade-in credit for sales tax (both at time of acquisition, then again at disposition).
    I don't know enough about it to crunch the numbers, to see how you might be better off, either way.
  • Are you aware if BMW Financial will give a better rate than thier base rate or money factor? (Especially for returning customers and excellent credit?) I just wanted to know if there is more negotiating room from the number you gave me for September. Also, I wanted to know since October is around the corner if you knew there was going to be any changes in the MF or residual for 2017 M3 Sedan. Thanks again!
    Current BMW numbers are valid until 10/31.
    Unless you use MSD, the base rate is as good as it gets.
  • Thank you!
  • onie0423onie0423 Member Posts: 49
    Is it true when you put down 7 MSD on a 2016 M3 the money factor goes down from .00136 to .00127 ? I'm calculating .00087.
    Each security deposit reduces the MF .00007. Max 7 is a total of .00049. From the base MF of .00136 this month, the net MF should be .00087.
    If the dealer is telling you .00127 then they have marked up the MF by the max allowed before applying the MSD.
    This is what the dealer said after i questioned the numbers.
    ".000136 is buying rate from BMW,
    the selling rate is .00176-.00049 7MSD=.000127"
    Sure, that's what they'll tell you. :smile:
    Might be time to work with a different dealer - it only takes one to meet your terms.
    Or, be polite and tell them you won't sign a deal with a marked up MF.
    Thank you so much. Great info.
    Money factor and residuals the same for the month of October ?
    The current BMW program runs through October 31st.
    They may update it, but at this point, no changes
    Thank you for the info. I also would like get your opinion on the car I'm interested in. Is $3K-$4K off msrp on a 2016 M3 a good deal or can I do better ?
    For BMW, anything above 7% off sticker, before incentives, is a good price.
    msrp is $79020. $74K $1500 option allowance included. Not very many 2016's left in my area (Northern California). Good deal  or walk away ?
    $4k is just over 5%. Ok, but with inventory dwindling, it may be the best you can do.
    Thank You.  BMW credit tier 1 is 700+ ? I just checked my Experian Fico Score 8 and Fico Auto Score 8. 764 and 787. Fico Score 9's in the 800+. Do you think BMW Financial will do it even with a bk discharge in 2009 ?
    Anything 675 or higher is top tier. 7 years? I shouldn't think it would be a problem.
    Thanks again. You've been very helpful
  • Hello,
    I was hoping you would tell me November lease rate or owners choice rates for 2017 M3 in Houston Texas. For both 36/10 and 36/12 with residual rates. Thank You!
    2017 discussion is here:
    http://forums.edmunds.com/discussion/42956/bmw/m3/2017-bmw-m3-lease-questions#latest
  • donuschakdonuschak Member Posts: 7
    What are the November lease rates for a 2016 M3 for 36/10?
    .00134 and 63%. $1500 option allowance
    Great, thanks.
  • carsabecarsabe Member Posts: 14
    edited January 2017
    Hey guys,
    I'm about to close the deal on a 2016 M3 Competition Package. Here are the numbers I've negotiated with the dealer. Please let me know if any of these look marked up to you! Thanks!
    MSRP: $79,745
    Negotiated Price: $72,000
    MF: .00134
    Residual 36/10: 60%
    Monthly payment: $944.28 with tax (Louisiana), $858.44 before tax
    Cash due at signing: $1285.78
    carsabe said:
    Hey guys,
    MSRP: $79,745
    MF: .00134
    Residual 36/10: 60%
    .00134 MF and 60% residual are correct.
    If I add $925 to the price for the acquisition fee, I get the exact number.
    There is a $1500 incentive on this model. Looks like you have 8% off, plus the $1500.
    That looks like a really good deal for an $80K M3.
    Thank you so much! Now I feel better about the deal
    carsabe said:
    Hey guys,
    MSRP: $79,745
    MF: .00134
    Residual 36/10: 60%
  • Bill PerdueBill Perdue Member Posts: 27
    Is there any lease information for a 2016 M3 36/12k 36/15k or any incentives? I see a few on dealer lots that look interesting. Thank you.
