Isuzu Rodeo transmission slip?
I have a 1998 isuzu rodeo v6 automatic 2 wheel drive.About a month ago, when you start to take off, the transmission will kinda slip and jerk a little and even when you are going into a right curve it will slip like it is in neutral until it finally grabs back in gear.I'm no mechanic,one guy said he had one do that and it ended up being a wheel baron went bad.Anyone seen or heard of this and wjat it may be?
Answers
If you are slipping while turning hard that sure sounds like low fluid level.
I am kinda having the same trouble. Mine started out that way so we put fluid in it & it was find for a day then on the way home it stopped shifting into any gear. We changed the fluid & it still wont shift. Any ideas anyone????
