Visitor Agreement.
Happy Motoring!
burnedagain
http://www.epa.gov/OMS/consumer/warr95fs.txt
My daughter has the same enigne you have (2.0) and she has complained about a "squeeking sound" on the passengers side of the engine bay when the engine is cold. I know it is her serpintine belt or its tensionor that is sqeeking. When the weather gets above 20 degrees, I plan to fix it for her. (but of course... when it gets warm the sqeeking goes away anyway 8-)
Try this, when you push the AC button, does the sound change? (the AC compressor puts a load on the serpentine belt)
it's more of a constant squeal while i'm driving. the sounds continues and fades when i turn off the car. it's similar to the sound when you let air out of the ballon while pulling on the opening, but much at a much higher pitch. this is the only way i can describe it.
actually i tried fooling around with the AC and such, but it didn't change. i may have to try it again to really listen for it.
i just want to avoid going to the garage AGAIN.
Len
Tip: If I were you, I would go to Sears Auto and have them replace the entire left side drive axle. A single cv-joint costs at least $175 to replace - if both cv joints on the drive axle are bad, it will cost you $$$$ to rebuild each individual joint on the existing drive axle, as opposed to spending $275 on a remanufactured drive axle (cv joints included). The remanufactured drive axle (from my personal experience) should last you just as long as the ones that originally came with the car from the factory.
The Sears warranty covers the axle for as long as you owned your car, so if a cv joint (even a single joint) should go bad due to boot breakage,
Sears will replace the entire drive axle free of charge (the only cost you will have to incur is a $60 alignment - which is a must whenever one or both driveaxles are removed and replaced). I took full advantage of that while I had my 1987 Golf for 16 years (and 624,000 miles) - I had the car for so long, I didn't have to worry about paying for a new driveaxle (or a single cv joint) while I owned the car...:-)
fast foward to today, 8 months later, and I am at 68,000 miles now. I started to hear a scraping noise every time I braked and thought it was coming from the rear brake pads. I took it to the same garage thinking it was time to replace the rear brakes now.
the shop called me back and said that it was my front brake pads and rotors again!! unfortunately I did not have my paperwork from the first time and so I wasn't 100% sure they were doing the same work. I consented and they went ahead and replaced the front brake pads AND rotors.
The owner of the shop said that the sound was coming from the front because the front rotors were completely worn down, and that the rear brakes were fine...
now that I am home, i found my old paperwork and it is confirmed that they did replace the front brake rotors/pads, only about 3,000 miles ago. My father says this is unheard of and I just want to have further "ammunition" when I call the shop on monday to find out what the heck happened. Is it impossible to wear down brakepads and rotors so quickly? I only work 5 miles from home and drive a stick shift. I am not heavy on the brakes at all.
thank you.
a naive car owner
There are some conditions which *may* wear them down in that short milage;
*) Sticking brake caliper
*) "riding" the brake pedal (even lightly)
*) Parking brake cable sticking (rear brakes only)
In my experience, even if you locate your paperwork after the second repair, a reputable shop will honor any warantee on the origianl repairs. All you should have to do is present BOTH sets of paperwork to them and they should reemburse you for the "covered" items.
PS: Since you did not mention that a sticking caliper was found during EITHER repair, I am VERY suspcious about what wore out the brakepads.
Are you certain that you are not touching the brakepedal while you are driving??
The rear disc pads are completely gone after <35K miles, too. the front brakes look thicker than the new pads I just put on my Tahoe. i don't get how there can be such a significant difference between the two.
the lights for the A/C controls in the dash have gone out as well. it's not clear how to address this, as no fuse appears to have issues.
I just ordered a Chilton's manual so that we can keep up with everything breaking! This is probably our last VW until we are millionaires and can afford the regular maintenance they seem to demand.
Your problem with the brake-lights not working was a dangerous situation indeed. That is why many states have annual safety inspection to catch these items and have them corrected. This was certainly no *fault* of the dealer nor VW. It was a kind jesture of them to 'cover' it.
It is too bad you allready orderd a Chiltons manual. There are much better documents for VW repairs than Chiltons or Haynes books. Last I knew, those books do no longer even provide schematic diagrams.
You do seem to have grasped the fact VWs tend to require preventive mantenace. (As do all German roadcars) They will last a long time when proper tended to and return a driving pleasure far beyond most other vehicles. VWs are also SIGNIFICNTLY safer in a crash due to the side-curtain airbags, airbags in the seats, headrests for ALL passengers...etc.
If you wish to "just drive" you would be better off with an Aisan vehicle. They tend to be more forgiving.... even when recommended maintenance is not done. Too bad they are as boring as a pet rock. (They also tend to be lower quality, and rust faster)
I called the garage today and confirmed with the owner that I did just have the rotors/pads replaced in july. He then told me that it may be a sticking caliper problem.. HOWEVER, wouldn't he have noticed this when replacing them? Is it obvious when there is a stickin caliper?
He told me to come back after another 1000 miles and he would see how the rotors/pads were holding up (if they were damaged again so soon, then it would definitely be a caliper problem). That if it was, indeed, a sticking caliper, we would be able to tell at that time...
I definitely do not ride the brake pedal, only tap it when i have to slow down, downshift and then when i get to below 20 mph, shift to neutral and then brake. Also, my car is 7 years old...and I got my first new rotors/pads just last year. If i was so harsh on the brakes, wouldn't I have needed to change many years ago?
I pushed him until he finally agreed to give me a refund but he still wants me to come back after 1000 miles so he can look at my brakes. He still insisted that he replaced them twice so I'm not quite sure what to believe...at least I got my money back!
NHTSA CAMPAIGN ID Number : 04V096000 Recall Date : FEB 20, 2004
Component: EXTERIOR LIGHTING:BRAKE LIGHTS:SWITCH
Potential Number Of Units Affected : 377130
VWoA has not yet started sending out notifications. Supposed to start in April.
Bottom line - if your 1.8T engine's longevity (and warranty) is important to you - use what the manufacturer recommends.
1.8t Gas: If VW recommends (which they do) to use premium, I would use premium. You should not buy the 1.8t engine if you can't afford the premium gas.
I would say that you are correct. I have gone up to 10 years in another make of vehicle without changing brake fluid. When I changed the fluid it was marginally dirty and had experienced absolutely no fade in app 108k miles. While I would NOT recommend this interval,
However, the real problem is there are all kinds of variation sensitivity and sensiblites. So for 5-8 dollars worth of fluid each 2 years and/or parts and labor, if you want or need to take it to the shop, it is a small price to pay for a date certain where the possibility of water and/or air and contaminates in your brake lines and fluid can be removed and replenished with clean fluid. Remember the wet boiling point is measured with 3% of water in the system. So (using 1 liter/33.8 oz or 1 quart/32 oz) that is about an oz of water.
Specifically for my 2003 VW Jetta TDI I have a year to go and will hit 50-60k miles at the two year mark. At the one year mark the fluid is as clean as it came new and it has not even gone down yet due to brake pad wear.
If you only had one (1) replaced, then there are 3 others that were manufactired at the same time as the 'bad' one and may be susceptible to failure.
http://www.troublecodes.net/articles/brkfld.shtml
Btw, visual appearance absolutely does not indicate moisture content.
I think the Germans' focus on a 2-year replacement interval [it's pretty universal among the EU makes] is probably too conservative...but waiting 5 years is also probably too liberal. Something in between makes sense to me.
If you only had one (1) replaced, then there are 3 others that were manufactired at the same time as the 'bad' one and may be susceptible to failure."
That being the case, didn't the ignition coil recall cover all of them?
The coil pack consists of four, six or eight coils encapsulated (with epoxy resin) in a single unit. There is no way to replace each individual coil. You must replace the coil pack in its entirety.
I hope this clears the confusion.
It seems like the quality of cars nowadays are hit or miss (especially VWs). Even the venerable Hondas and Toyotas haven't escaped the quality bug with their recent recall notices (check out the most recent NHTSA recall lists). If those car makers (with their solid reputations for reliability) are having problems, then we are really screwed... Looks like we may have to revert back to a horse and buggy...
1. Windows falling in doors
2. Ignition Coil failure
3. Radio failure
4. Purge value failure
5. Check engine light illuminates multiple times and stays on without them being able to determine why.
6. Vibration/Humming noise when driving at highway speeds.
And the list goes on with cosmetic problems (rattles, paint, etc.) The last issue of vibration can not be identified by the dealership and they have attempted to fix the problem four times now with no resolution. They replaced a bearing (2 times, one in each front wheel), the entire tranny, and now the drive axles. We contacted the customer service line for VW and also the dealership GM re: arbitration since the car is a lemon. We have had it beyond one year but it only has 14,000 so we have a definite argument as the issues started last summer (w/in the one year period of the lemon law in our state.
Have any of you encountered these issues? Have any of you gone through the arbitration process or know of someone who has? This is new to us and are not sure what to expect.
Thanks for your help.
KLB
The ignition coils are a result of VW's achilles heel - their choice of suppliers for the many components in their automobiles. I had a 1987 Golf GT that was recalled for faulty heater cores - because of a bad batch of cores from one of their suppliers in France. They couldn't pick a good supplier worth beans, and their abyssmal track record continues to this day...
VW, for all of their technical innovations over the years have really been shooting themselves in the foot as of late.
I started the car and the radio display says "safe" It allows me to manipulate 4 numbers with the preset buttons. I put the radio code in but I dont know what to do next.
What happened and how do i fix it? My thought is that I can disconnect the battery, but I'd like to know the official fix
Disconnecting the battery won't work. It automatically sets the radio to safe mode, because the system assumes that someone is breaking into your car.
If you don't have the owners manual, the dealer should be able to find the correct code in their computer system. Ask your dealer for a copy of the factory radio code and keep it with you at all times (at least while you're driving)...
BTW: I think we understood your problems in the first post, the second was not necessary.
Sheanin vs. Volkswagen of America, Inc.
VWoA eventually extended the warranty of the regulators to 7yr/100k miles. Don't think it covers the Mk III.
