2010 T & C Is there a headlight relay in the system?
retired8retired8 Member Posts: 15
edited August 2016 in Chrysler
My T & C started to lose headlights. They blink on and off when turned on. They even have the left lamp blinking when the right lamp is on solid. When both are on, and you hit high beam, both will go off, or one go off and the other blink. Some times they will work correctly on a trip around town. Is there a relay, and can it cause this problem? Thank you.
Best Answers
