In any case, the door sensor is located within the locking mechanism of the door. Most folks have corrected problems such as yours by either adjusting or replacing the affected components within the door.
Be sure you have a compatible after market CD changer.
Since they had it for 10,000 km and you for only 320, if they are saying it failed to due to abuse it certainly would seem reasonble to assume that it just may have been abused during those first 10,000 km. Did they inspect the clutch before you took the car? If not, what evidence do they have that you were the cause of the problem rather than them?
1989 Plymouth Voyager bought new, donated with over 120,000 miles and original clutch still working.
1986 Plymouth Horizon bought new, donated with over 120,000 miles and original clutch still working.
1995 Ford Contour bought with 70,000+ miles, now has over 130,000 and still running with, I assume, the original clutch.
1996 Ford Contour bought with 70,000+ miles, now has over 100,000 and still running with, I assume, the original clutch.
The "big secret" is to NOT TOUCH THE THROTTLE until the vehicle is moving. After several weeks of this "practice", you will begin to understand the feel of the clutch. Revving the engine when starting off from a stop is a big NO-NO. One must have patience to wait for the vehicle to start rolling.
As an example, listen to the engine of a professional driver (trucker) as they start off from a stop. They NEVER-EVER rev the engine up until AFTER the clutch pedal is released.
It is the HEAT from friction that wears out a clutch. If you keep clutch-slippage to a minimum, then there is no heat.
More manual xmission tidbits...
After first starting a cold engine, put into neutral and release the clutch pedal for at least 30 seconds. This gets the oil-pump in the xmission pumping and lubricates the inside of the xmission.... then start driving.
The throwout bearing will wear out if you keep the clutch depressed. If you will be sitting still for longer than 30 seconds, put into neutral and release the clutch pedal. Use the BRAKE to hold the car still...never the clutch.
Thoughts much appreciated ! Thank you!
Do I need to add oil to the transmission - yes or no?
Not unless it is leaking.
IF you say No - WHY is that?
Because if it is not leaking, the xmission lube level will not change.
HOWEVER: Since you say that you have 187,000 miles on your Jetta, I would suggest that you consider CHANGING the xmission fluid. (Use only VW manual xmission lube...which is synthetic)
BTW: It is not uncomon for CV joints to need replacing after about 90,000 miles.
Thanks for any assistance.
Visit #1
Interior Squeak/Rattles
I stated front & rear doors rattle when music is played.
Tech Notes: Verified concern on road test - Performed tech service bulletin 70-05-01 Added foam insulation to doors. Retested OK
FP Number: 1KM-898-001 Description: Foam
FP Number: 1Y0-871-435 Description: Tape
Visit #2
I stated right front door was still rattling when music is played. The Tech, my boyfriend, and I listened to the rattle and discovered the chrome seal on the door was vibrating against the window. Tech stated he would add a felt strip between the chrome seal and door.
Tech Notes: Verified concern on road test - Added foam insulation to right front mirror housing - Retested OK
I was very confused why the Tech did not add the felt strip between the chrome seal and door as he stated he would, especially since all three of us discovered where the rattle was coming from. Instead, he added foam insulation to the mirror housing? Very confused...
Same FP Numbers and Descriptions as Visit #1
Headlights
I stated right front headlamp went out for half a day. The warning indicator came on during that time.
Tech Notes: Removed headlamp assembly and checked all parts. Connection was loose. Tightened connections and reassembled headlamp. All OK at this time.
Visit #3
I stated my right front door still continues to rattle. Also stated felt strip was not added during last visit.
Tech Notes: Performed felt strip insulation to left front window. Road tested OK Once again, I felt very confused. Why was the felt strip added to the left front window when the rattle was on the right front window/door? I am also very confused why the Tech states the car has been retested and is OK when the problem still occurs.
FP Number: 533-867-910-A Description: Felt Strip
Visit #4
I stated front window/door continues to rattle. The Tech, my boyfriend, and I once again hovered around the door to find the rattle. Tech explained that Volkswagen will not allow him to add the felt strip completely along the door seal for safety reasons because of the location of the airbags. He was only able to cover 1/3 of the door with the felt strip.
Tech Notes: Retested and tested other three A5 Jetta per VW instructions - All exhibit the same if not louder rattle - We are waiting to have instructions from VW Quality Tech Manager on further repair strategy. We will contact customer for meeting with Quality Tech Manager for this concern.
I've been waiting for about three weeks now and have not heard from the Quality Tech Manager or the Dealership. I will be taking in my car, once again, for the recall I received in the mail. (Recall: 2005 Model Year Jetta with 2.5L Gasoline Engine - Inspect Engine Compartment Fuel Supply Line Clamp and Replace, if Necessary) At that time, I will ask for an update. My rattle seems to be more annoying as time goes on. The other day I was listening to Bob Marley and had to change the station because Bob was rattling too much. This is unacceptable and BS! I can't wait to see the Quality Tech Manager to discuss my DISSATISFATION.
80K-90K range (I usually change the belt at around 90K). Any longer than that, and you're rolling the dice at that point...
Rattles are not a serious safety issue, but can be very annoying. Most don't expect a new car to rattle. To add insult to injury you are on visit 4 or 5? and its still not fixed. Good luck and be persistant. This may be a first model year issue!!
I cannot believe the wiring harness and engine management system computer are broken. You have to question is that possible since it is a new car. It 's nice the dealership gave you a car to drive around in the meantime. However, with a new car, you shouldn't need to bring it to the dealer already.
I hope there are no patterns of problems. The car seems to run well except for the rattle. What are you doing about your rattling problem? Does it not annoy you? Sometimes, I just want to turn off the stereo because the buzzing, rattling noise is too irritating. I have a friend who has the same car and is dealing with the same problem. He, however, is not getting any response from his dealership. Not that my dealership is putting much effort in resolving the problem, but at least they say they will have the Quality Tech Manager contact me. It's been a month now and no contact has been made. Are they full of BS or what?
Thanks for sharing your car issues with me.
Thanks for sharing your info with me.
Use too little or too much force to close, and it bounces back up. Even if I get it to stay shut, usually the trunk isn't really closed. The display in the dash indicates that the trunk is still open, and only if I push down until I hear a "click" is the trunk really closed.
I took it in to get "fixed" but the tech said that the trunk is operating to spec, and that in VW school they told him this is how the trunk is supposed to work.
The tech also said that there is a timer in the lid latch that takes about 10 seconds to reset, and so in that time you can't re-close the trunk.
Basically, you can't pop the trunk open, throw something in, and close it right away. I live in a part of the country where it rains most of the year and it's just going be annoying having to stand in the rain for 10 seconds so I can wait to close my trunk.
Or stand in the rain as I try 10 times to close my trunk correctly, or get my sleeves all wet pressing down to hear the "click."
On a car with an MSRP of $26,740 surely the trunk should be easy to close. I know on my 2005 Jetta GLS the trunk pretty much closed itself. I don't understand why they had to mess with that on the New Jetta.
Surely the trunk on the New Jetta isn't intentionally designed to be this non-functional? I have emailed customer care about this, but if anyone has any helpful input on this matter I'd love to hear it.
For the most part I'm just in shock that it's such a hassle to do something so simple as close the trunk.
Moral of the story:
The Jetta is a very nicely designed little car from an esthetic and performance perspective. She got 30k of mostly trouble-free use out of it and all her problems started with a momentary "Check Engine" light that led her to request a routine spark plug change. As soon as a mechanic laid a hand on the engine the entire emissions system went to pot! Reading these forums it is clear that these cars have long-term reliability problems - I would not recommend buying one to anybody trying to live on a modest budget! Neither independent nor VW garages seem to be able to service them reliably - this has generated tremendous ill-will among customers expressed here and elsewhere...
Please read on to learn the details of this experience - any comments and recommendations would be appreciated!
She had a "Check Engine" light come on then go off in the spring. Someone suggested to her that it might need spark plugs with 50k miles on it so, when she took it in to an independent garage (recommended for VW service) for NYS Inspection in July she asked to have the plugs changed.
First they had trouble checking computer for inspection - called and asked if anyone had worked on it recently, maybe clearing computer codes. Answer was "No" - no one has touched it since they replaced brakes a year ago!
They recommended that she change plug wires but she did not have $ budgeted for additional work and told them "Not right now". I picked-up car for her, everything seemed fine, no "Check Engine" light and running smoothly. 10 miles from garage I stopped for a light and engine started to miss - "Check Engine" light ON. I drove it home and called garage, told them what happened, they said bring it back - it was missing so badly I could hardly get it there!
They found bad plug wire (my opinion: they damaged it changing plugs - they are terrible to access!) and gave her a better quote on replacing plug wires. THEN they were unable to get the "Check Engine" light OFF! After 2 more days of fooling-around they concluded O2 sensors were OK but CAT might have been "injured" by 30 miles of driving with dead cylinder (due to bad plug wire). They gave her a bottle of F.I. cleaner and instructed her to see if the "Check Engine" light would go out after running a tankful of fuel with F.I. cleaner.
When she used-up the F.I. cleaner and "Check Engine" light stayed ON they told her to bring it back so they could re-check the computer codes. They told her that, according to VW "recall" bulletin the CAT needed replacement under warranty and she should take it to VW. Independent garage (same one) wanted to charge her $60 for pulling the code but I told them "NO" - they let it go, I think because they knew they had damaged a plug wire which caused the problem in the first place!
She called VWOA and described problem and they told her if it is the CAT it would be replaced at no charge. When she made app't with VW dealer they would not commit to replacing CAT w/o charge but she took it in anyways. They told her that THEIR Dx indicated the problem is Coolant Sensor and total bill will be $150 - $80 for pulling the computer code. Also that, if the CAT is still checking bad after Coolant Sensor replacement it WILL NOT BE COVERED BY WARRANTY!
Mechanics find this car difficult to work on, especially the computer/emissions controls which seem to be marginal at best.
VW dealers seem to be uncooperative with customers - probably because VWOA is not treating them right with warranty reimbursements.
Any advice for my daughter on how to proceed with getting this all resolved? Thank goodness she has made her last payment on the car loan! I think she needs to save-up to trade it for something more reliable and economical to maintain - my advice is a pre-69 6-cylinder Chevy! Meanwhile she does have a bus pass...
While she had it at the dealer they told her she had a loose tie-rod and quoted her an unreasonable price to repair that. She had the presence of mind to tell them that it had just passed NYS Safety Inspection last month and she did not think it would be necessary to repair anything in the front-end. (My girl!)
The bottomline on this may be the observation I made today at lunch. I parallel parked my '82 Chevy Monte Carlo behind a car with a NYS vanity license plate that read "JETTA" - the car was a Honda Civic!
I think you need to do whatever you can to have the problem fixed. It is unacceptible for VW to tell you that this is the way the trunk is suppose to work. Do not accept that response. I would ask the dealership to contact the Quality Tech Manager to check out the trunk. Like I said, the trunk is not meant to operate that way because my trunk appears to work just fine. I do have to somewhat slam it closed though. It is a heavy trunk. You may want to contact VW customer care to state your dissatisfaction.
I have problems with my doors rattling when music is played. VW said they will have a Quality Tech Manager come out to test drive the car with me. I am not going to accept the fact that the car is "designed to operate that way." Your absolutely right, with a MSRP as high as it is, there should be no problems with the trunk or rattling. (I purchased package #2 and the rattling makes me think why did I pay more for premium sound?)
I hope you get this issue resolved and don't have to stand in the rain waiting to close your trunk. Good luck!
I have started to notice some buzzing coming from the front passenger door speakers. Not constant, but it's there even though I don't turn up the volume at all. It's only those speakers that buzz. I will ask to have a Quality Tech Manager test drive the car with me. Thanks for the idea, I didn't know that was possible.
How long will it take for you to get that test drive with the Quality Tech Manager scheduled?
Unfortunately my trunk is not working as well today as it did yesterday. Yesterday I managed to shut the trunk all five times that I used it, on the first try. Today all 3 or 4 times I need to mess with it even after it was "closed."
At one point, neither my husband nor I could get the trunk to register as closed, even though it clearly was closed. We pressed and pressed, and heard lots of clicking, but the dash display showed the trunk was still "open." We were unable to re-open the trunk using either the release or the key fob, and eventually I had to fold down the seat, and crawl inside the trunk and pull the release handle.
It's the second time in 9 days that we've had to crawl into the trunk to open it. It's getting old pretty fast.
I'll feel alot better once I get this trunk thing taken care of. That and the TSB for the door speaker buzzing.
Well, right now I've got to write VW an email to tell them how I didn't enjoy having to crawl inside my trunk to open it.
Do you know where I can read more about these VW TSBs? Thanks.
http://www.edmunds.com/maintenance/recalltsb.do?step=tsb&year=2005&make=Volkswagen&model=J- etta&style=New+2.5+4dr+Sedan+%
By your description, most of your issues were caused by incompentent (with VWs) mechanic. I bet the "cooant sensor" was the initial problem and all the other issues were induced by sloppy sparkplug replacment.
The "coolant sensor" is a very common problem on pre-2001 VWs. It has been superceeded at least 2 times since then. The reliable one is GREEN in color.
As for the Cat-converter, READ YOUR OWNERS MANUAL!!! There is s FEDERAL EMMISSIONS WARANTEE that covers all emmissions equipment for 10-years, 100,000 miles. (It does not matter what the dealership "says")
BTW: I am not clear on what needs to be "resolved" at this point???? Is your daughters VW not running OK now with no CEL ?
This is getting ridiculous.
