Lesabre dies at Idle.
I have a 94 Lesabre and it started dieing while Idling, ie: at light.
The oil was just changed, so I'm wondering if it's possibly a Fuel Filter?
I'm still learning the In's & Out's to GM, I usually work on FORD.
Any thoughts or ideas would be appreciated, thank you!
Answers
But presuming you don't have such a tool handy, there are some general things you can check, and if the problem is obvious, you might just find it using THIS TUTORIAL ON STALLING.
Good luck with it.
While the 3800 won't start, turn key to ON and see if you hear the fuel pump at least turning for 2 seconds to prime the pressure. You didn't give any info about the circumstances as to when and to how the stall occurs, so I'll give you the shadetree mleSabres echanic lines of checking. A few had fuel pumps that quit when the pump heats up after running for a time. You can try hitting on the bottom of the fuel tank to vibrate the fuel pump if it doesn't turn and help it restart. Replacement requires dropping the tank on leSabres until 2000-2005 models where there is a removable cover in the trunk above the tank.
EGR valves also caused rough idle and eventual stall for some. Sometimes sticking slightly open.
