Brakes: Drum vs. Disc
Edmunds.com
www.ericthecarguy.com
Replacing Drum Brake Shoes Part 1
Replacing Drum Brake Shoes Part 2
Enjoy.
b.
I see this on all disc brakes. See for yourself. Remove the wheel and try to spin the rotor- it won't spin freely. Why? because the pads always touch the rotor causing friction and a constant braking effect. I expect this is worse when the pads heat up.
On the other hand drum brakes do not have this rubbing problem because the shoes retract from the attached springs.
I think the drum is better.
Voyger7
Friction is an aspect that is fixed in both disc and drum brakes.
Friction causes heat - overheating causes the drum brake to sometimes not work.
Regardless of how cold it is, with friction, heat occurs.
Disc brakes are not self energizing like drum brakes
Disc brakes have much higher maintenance cost due to:
1- Calipers can't be repaired as easy as wheel cylinders
2- Rotors rust quickly
3- Rotors warp
Disc brakes harder on the environment due to high frequency of rotor and caliper replacement compared to drums
Wheels are forever dirty with disc brakes
Disc rotors and calipers are heavier than drums and wheel cylinders
You can have your disc brakes.
I dont mean to disagree with thecardoc3, but every Semi Truck and trailer I have ever seen has massive drum brakes. The reason being that drum brakes do indeed have more stopping power (more surface area and more positive applying leverage) Heat, as stated before is the issue that common drivers do not understand or account for, whereas truckers understand (usually) how to apply their brakes intermittently to allow for cooling.
It has always been my assumption that pitted against one another on vehicles of identical weight, that Drum brakes would bring the vehicle to a short quick stop from medium speed much faster than disks - but disks would maintain braking power over longer faster stops due to their ability to dissipate heat... I would like to see a test such as this done
(and welcome)
Here is a video. Those are some huge calipers, not even counting the diaphragm.
Nonetheless, there were cars in Europe winning races at incredible speeds (even by today's standards) with drum brakes.
