1998 Chevy 1500,
Christopher1962
Member Posts: 1
Hello, 5.0 Engine, Electronic ignition. I have a starting problem. I can turn the key to start and it will continually turn over, crank and crank forever, but will not start. But, if i just bump the key to engage the starter, just enough to engage it, it will eventually pick up and run. Any ideas? Thank you
Answers
If compression is good, then you need to find out if the "long-crank" is missing something that the "short-crank" provides. Maybe the "short-crank" boosts up the fuel pressure momentarily?
