2016 Ram 1500 big horn lease
crobis44crobis44 Member Posts: 1
edited October 2016 in Ram
Looking for MF/Residual for a 2016 Ram Crew Cab 4x4 Big Horn - 36/12. Acquisitions waived? Any lease cash? I am in NY. Thanks
Best Answer
Answers
  • scgulfportscgulfport Member Posts: 5
    Looking for MF/residual for 2016 Ram Crew Cab 4x4 Big Horn 24/10 and 36/10. I am in Mississippi, and would also appreciate any info on current incentives available in the Southwest Business Center. I am also interested in which Ram 1500 4x4 model has the highest residual purely out of curiosity. Thanks!
  • MichaellMichaell Moderator Posts: 270,416
    24/10 - standard MF and 54%
    36/10 - .00004 and 49%
    Laramie trim has the highest residual of all 4x4 crew cabs.
    edited November 2016
    Thank you for the information. Can you provide MF/residual for 24/10 and 36/10 on Laramie 4x4 Crew Cab? One other question- you mentioned "standard MF" on 24/10 for Big Horn Crew Cab 4x4- what is "standard MF"? One last question for you- on a previous post kyfdx indicated that MF/residual on the same vehicle for 36/12 was .00016 and 58%. Was that information accurate? If so, does the residual increase for higher mileage, which would be the opposite I would expect? Thanks again. Thanks!
    New month, new numbers.
    Standard MF is around .00200.
