overdrive light remains on
mv98odmv98od Member Posts: 3
edited November 2016 in Mercury
can not turn off (overdrive off light) tried pushing the button on the shift lever no response need help have no electrical diagram from od button to transmission HELP
    You need to scan the system to see what's up. You may no longer be in overdrive for a reason. Also check your fuse box just in case. Fuse or switch if you're lucky.
    You may be able to score a free wiring diagram HERE
  • mv98odmv98od Member Posts: 3
    this van has served me well ,i have scanned ,took it apart , checked all fuses relays ,with out wiring diagram for that switch i am having a little problem
    Can't recall---is that button on the end of your shift lever?
    That's where it was on my '99 Quest but the 1998 was the first generation van. Not sure about it.
    Hmmm...wonder how you test that...maybe by accessing the harness from a cover under the steering post?
    THANKS STEVER THATS WHAT THE 1998 LEVER ON/OFF LOOKS ; PUSH PUSH PUSH NOTHING HAPPEN LOL
    Try the Villager/Quest Yahoo Group - one post there indicates that your switch may be grounding out.
