BEST Summer tires
RonventRonvent Member Posts: 1
edited December 2016 in Mazda
Can a set of tires be TOO GOOD for a car? Assuming correct fit, etc, with ride comfort and cost being no object, can some very highly rated tires actually harm the handling/safety of the Mazda 3?
    You could get tires that have a speed rating that's higher than you need for your vehicle, but I don't think that would affect safety/handing. Found a Consumer Reports article about higher speed rated tires not having as long a tread life, so you'd be replacing them more often. But in a Mazda 3 you're not going to need higher speed rated tires, so even though you say "cost being no object", why throw money away?
    http://www.consumerreports.org/cro/news/2009/10/h-rated-tires-with-shorter-life-spans-become-more-common/index.htm
    You certainly don't want to go with "cheap-o specials", but you're probably going to run into as many opinions on "best summer tires" as there are people. For what it's worth, our choice for a long time has been Cooper CS5's. I've toyed with trying out Michelins, but for the difference in cost, my tire shop buddy says I wouldn't really see enough of a difference to warrant the cost. Some folks swear by Michelins though. :)
  • kyfdxkyfdx Moderator Posts: 270,951
    If you haven't had summer tires before, the difference can be shocking. Handling characteristics may change, but nothing should be unsafe, unless one is oblivious to how the car reacts.
    I recommend Michelin Pilot Super Sports. ;)
  • texasestexases Member Posts: 11,182
    Only if you try and use them in cold weather - they will have much less grip, you could be unpleasantly surprised.
    I must be related to Kreskin ;)
    They will change your life! (unless you drive a Nissan Versa)
