Engine power reduced, Service traction control, service stabilitrak and engine light
                    My 2011 Impala had these lights come on along with the check engine light. Once I turned the car off of for about 10 minutes the messages did not reappear however the engine light is still on. can someone please explain why this is happening.
Known issue with Chevy Impala 2008-2016 and still going
Per Chevy Tech / compliant Department which I talked to a gentleman who treated me like some D-women. They will never do anything about this issue. EVER.
Codes
P0042 / P0455 EVAP LEAKS
It’s a $95 part from RockAuto.com . I have been buying cars parts there for years. The garage will charge you over $200 for this part lmao. And another $200-300 to replace it. MY ESTIMATE $490.00 HAHAHA
Buy the part, and Everyone has a mechanical friend or family member in their Circle- it’s an easy peasy part to replace, for a minimal skilled mechanic. YouTube.com- if you have mechanical skills- do it yourself.
Here is the issue- It will never case any harm to let it go to your vehicle, it not needed for Inspection and after you replace it, it will almost definitely go bad again within a years’ time.
Again- 03/27/18 I spoke to Chevy and they absolutely know this is a warranty issue- will never recall it-
1. Not a safety issue / that’s why.
2. All they did is repeat themselves, it’s not an issue
3.
ABS, TRACTION CONTROL, STABILITRAK LIGHTS: all fixable on your own Rockauto.com all parts for above issues $238. (Includes the EVAP canister)
Car lot wanted $2106.60 for all the above.
Where exactly did $2106.60 come from? That is not an estimate for an evaporative cannister and a vent valve. Do you have a written copy with itemized labors and part numbers for what they said needed done? If so, can you post it? (photo and/or typed?)
