A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
amsoil oil and air filters.I also use the by-pass
filter and have been changing oil once a year at
about 14k miles.If you are leary of the one year
then take oil samples to reassure you.it's almost
defeating the purpose of synthetic oil not to go
the full year.
filters to a finer degree than the mobil one
filter.the leading filter makers seem to stress
percentages and housing strength and never say
how small a particle it will filter,I don't care
if my oil is being filtered 10 times a minute
if the filter is not stopping the smaller
particles.the by-pass filters to below one micron
this virtually eliminates wear caused by solid
particles in the oil,plus you get to use an extra
qt. or 2 depending on filter size.
Keep your oil changes to what the manufacturer recommends.
engines using amsoil and have gotten good readings
even at hi mileage.I think alot of the acid and
dilution would depend on location,time of year
and driving habits.
I have also used the oil sampling that the
catapillar dealers sell.
My motive is that I think it is the best product
out there,I am a dealer mainly to get the product
if I sell to individuals I sell for dealers cost.
I'm not sure about redline but amsoil makes the
only syn. atf fluid so that eliminates other
brands,they make a "oiled foam" air filter that
is much cheaper than k&n.they make the bypass
filter,(there are a few other brands out there
but not the exact same kind)I think these help
when you have a 4 cyl.holding 4.5 qt. and using
this gives you an extra qt.I think mobil one is
the next best syn out there but I think amsoil
has a better array of products to compliment the
oil.I think the only way to conduct long term
tests would be to buy 2 of the same car one with
syn. one without and give them to one driver
and tell him to switch cars every day till you
get a few hundred thousand and then take the
engines apart and compare.
I use it in my '97 Bravada AWD, both the tranny and transfer case, using 30K miles replacement intervals.
My second of two bits is that you get what you pay for. There are so many products in the market that you have to really do your homework if you are either that worried about it, or you really take engine science seriously.
Hi packman2, remember me?
Hey oilcan2, is it true that some synths are biodgradeable?
filters a dual remote,it is a reg.filter and the
one used in the by-pass mode,the first by-pass
filter they made was the seperate one I mentioned
before,I have never had one clog up on me so I
assume it is working as long as oil passes thru
it.also why is the syn.going to have dif.benifits
if we use it right away or wait a few thousand
miles.I've read alot of posts about what the
manufacturers say,for years they had nothing
good to say about syn oils,in the past few years
some of the higher priced big three cars are
being shipped with syn oil.
Though, in the manual, GM recommends using synthetic oil - while only in the very cold places.
TB
MB E320 (that I know of) comes with synthetic oil, and the first oil change is due @10k to 15k.
Seems like when the manufacturer/dealer pays the tab for the maint and oil changes they want to extend the intervals (and can for the superior synthetic oils).
I have been on 15k change intervals and in effect do 4 less oil changes, (80% less or 5x more [using the 3k interval}) depending on your point of view. I like using less oil products, saving time and money.
for 7500 mile oil changes. Since yours is still
under warranty I assume that you have a newer one,
and that MB has extended the oil change intervals.
I personally change even below 7500 miles, but
this is only because of two reasons:
a) It is so very easy to change oil on an MB.
b) It might be my own superstition, but I would be
concerned about particles after 15K miles.
All this probably will make little of a difference
in the end, but engine oil seems to be such an
emotional subject, that I'd rather stay in my own
comfort zone.
Yes, Y2k model yr. Less than 1k on the clock, so not even close to the oil change interval. Yes the old habit of 3k oil changes dies very very hard.
A good reason for increasing change intervals is the environmental impact as well as the cost savings. This is the reason Europe is going to 9K+ intervals regardless of vehicle.
I have read that most (if not all) new cars in Germany are filled with synthetic, and you would have a hard time finding petro-based oils there.
In response to markbuck's question on acids and such, high quality oils contain corrosion inhibitors, oxidation inhibitors, and emulsion modifiers to protect against the acids from combustion. These additives are designed to coincide with the recommended change intervals. However, you should always have your oil analyzed at least once a year to determine if there are problems within the engine that increase combustion by-products from normal levels.
I have occasionally used oil analysis, but mostly as a result of some concern, to determine if I have any engine damage.....
To spend $15-20 a year on analysis is just a given, no matter how you change your oil.
Given your situation with low yrly miles and stop and go in a high temp and humidity climate (I lived in Miami, Fl for a number of yrs) I wouldn't have any hesitation at using/switching to synthetic and going to a yrly oil change as you plan. It is a good idea to take it on a longer trip say once a month or more, if you are a low milege user. Of course, the party line is that you should not exceed the warranty reccommendation.
Shelby was smart enough to know that synthetics make a big difference in the longetivity of the engines and turbos.
I use Amaoil in all my cars and drain them every 2 years or roughly 20K miles. I also use the Amsoil by pass filter and their oil wetted foam air filters.
Past experience via oil analysis indicated no problems and on one engine, when I replaces a head gasket at 110K miles, the engine was perfectly clean, hone marks still visable, no ridge or taper in the cylinder bores etc.
I wouldnt use anything else. Amazing how all the other comapnies are jumping on board, now that they see a niche market. Too bad, I'll stick with the Amsoil.
Later
While the conventional oil is better than it ever has been (meeting much higher technical standards), I agree with you that the synthetic is the superior lubricant. And on a interesting level the marketing for conventional oil seems to be doing better, judging by the numbers and %'s that still stay with it.
park sw for 8 years,change about every 3.I can
drain my torque converter and get 100% out of the
trans.On cars that cannot I would take the oil
to one of those shops that has the machine to
flush the trans and have them install the fluid.
The car has 235,000 miles and has never had trans
problems.
few companies making syn. trans fluid,so
maybe thats why amsoil was recommended.Your
buddies engine would have been a perfect case for
oil analysis,if the sample came back bad then
you could really blame the oil,if the oil tested
ok then why did the bearings burn up,did he put
the oil in a car with 80,000 miles on conventional
oil and expect the worn bearings never to
wear out?what oil was it,did he change the filter
during this time?
The cost factor is different for every individual
for me it is worth it,every car is different,and
has different wear and tear,generally speaking
you can get at least twice the use out of syn.
trans fluid vs. non-syn fluid.
P.S.This topic is getting like the ZAINO and non
zaino topics.
Falex:
Amsoil 15w-40 passed at 9 teeth
Mobil-1 5w-30 passed at 12 teeth
Mobil-1 15w-50 failed
Also, Amsoil showed better scores in oxidation tests.
Additionally, Amsoil shows less wear in their 4-ball test:
http://www.amzoil.com/facts.htm
I find it interesting that Mobil-1 makes no claims about wear testing or extended intervals on their website as explained here is an excerpt from "The Motor Oil Bible", an article obtained from another Amsoil website (http://www.bestsyntheticoil.com/amsoil/index.shtml):
"In my opinion Mobil 1 oils are most likely good for 10,000 to 15,000 miles, but the company does not make that recommendation. I have known of many people who do very well running Mobil 1 for these intervals, but it has not been designed specifically for extended drain use. Moreover, the company probably would not back you if you had any mechanical problems resulting from such extended drain use, since they only recommend 'manufacturer recommended change intervals'".
Now, don't get me wrong. I'm not saying Mobil-1 is a bad oil. I think it is an extremely good oil to use, and I have been using it for years. However, Amsoil appears to be better and backs up their claims with testing, technical properties, and warranties.
Conventional oil changes over 12K miles:
20 quarts x 2.25/qt. = $45
4 filters x 5.00/ea. = $20
Total cost = $65
Extended drain change at 12K miles:
5 quarts x $7.95/qt = $39.75
1 filter x $10 = $10
Total cost = $49.75
So, not only do I save over $15 (which BTW pays for an analysis), I perform 3 less oil changes which contributes to less oil in the refining plants, and less to recycle which is better for the earth. Makes perfect sense to me.
BTW, this is from the Amsoil website:
"AMSOIL products clearly offer better wear protection than competitive synthetics and much better protection than conventional oils. Engines can fail due to mechanical problems even when using AMSOIL. AMSOIL Motor Oils, however, in over twenty-five years have never caused an engine failure. If you ever hear someone say AMSOIL caused their engine, bearings, pistons, etc. to fail, they are wrong."
Still not convinced that premium synthetics are worth it for motor oil
I also owned an '89 Volkswagen Fox about 5 yrs ago. Used all conventional oil (Mobil) with off-the-shelf filters and it ran clean, even up to 5,000 mi. between one of the changes. The only reason I still don't own it is because it got wrecked. Maybe it was the condition of the engine. I've read few complaints about VW engines!
My stance on it,is that if your engine is not in good condition when you start using a synthetic,alot of times,they will leak.
From talking to a manufacturer engineer and a CATERPILLAR analyst,I use a premium grade 15w40 fleet oil.I have a 70 chev 4x4 with 330,000 miles on the engine,oil changed every 5,000 miles(I have no warranty to worry about),same brand and weight oil since the engine was new.I always love when they say that the oil didn't cause the failure,almost any oil can claim that,as it isn't the oil,but the impurities that get into the oil that causes the damage.
I would say that fear of the past and good marketing are at work in the 3k oil interval change cycle.
When I had a 70 VW bug and it burned regular leaded gas, 3k was even too long.
The oils sold on the market today [if they wear those standard logos], are by and large better than they have ever been.
Most car manufacturers have since gone to 7.5k and in some cases (MB E-320) have gone to 10-15k) The 3k oil change cycle is really almost 60%- 2.5x more frequent than you really have to.
Also the manufacturers hedge, by saying there is a severe duty table also. Whether you are fearful or have no fear, we take a lot on what we want to believe, sans a real oil analysis. (which I am getting the feeling not many folks actually do)
The other good news/bad news is that the cost to manufacture conventional oil and synthetic oil is virtually the same. As most would note, there is a big diffence in the sale price.
