GMC Yukon - engine dies
veevee22veevee22 Member Posts: 4
edited January 2017 in GMC
I have a 01 GMC Yukon Xl it starts up and kills after a couple of seconds change fuel filter any one knw what else can I do
Answers
    There could be a lot of reasons for stalling....a long list. One place to start is to plug a code reader in there and see if that gives you any hints. You can also look around for vacuum leaks (cracked or loose hoses, etc). But without codes, you're working in the dark. Might just be a sensor.
  • veevee22veevee22 Member Posts: 4
    I hook it to a code reader but it's not reading the computer
  • thecardoc3thecardoc3 Member Posts: 5,856
    Starts up, then dies and no communication to the code reader.... Is the security light on or flashing?
    Security light is off when I turn the key on
    What does it do after you try to start the car?
    Got it fixed it was the fuel pump thanks for Y'all help
