What makes the engine leak with a change to synthetic? Please enlighten us.
I don't think anyone hear is questioning regular maintenance. The question is more about the limits of maintenance and the benefits of synthetic. There are many opinions about synthetics being snake oil and not worth the "cost". However, I never see anything technical to disprove the benefits of synths, or exhibit the benefits of conventionals. It's always "I heard", or "my car ran x miles". I'm just trying to extract the truth from the fluff.
I did run 0W-30 Mobil 1 last winter during a snowmobile trip to Yellowstone and encountered temps to -30F.
I do run synthetics in my race bikes, just can't justify the cost in my daily driver/tow vehicle for most circumstances
I have a new 2001HD chevy with 6.0L gas on order, you guys are wearing me down with the synth argument, so I might go Mobil 1 full time in the engine, but would keep oil changes at the normal short interval.
markbuck, your situation is more about the additives in the oil and the cold temp zone (pour point). A synth will help with the pour point, and synths typically have better emulsion modifiers and corrosion inhibitors than the petros, but since many brands don't advertise the additive levels, it's typically a guessing game without analysis. I think the rule of thumb is 50% loss of TBN indicates that the additive package is spent and it's time for a change.
How many professional race teams do you see using Amsoil???
http://www.amsoil.com/racing.htm
although, you should know that race sponsering is a scam in itself. Many professionals have promoted (and still do) obvious questionable products such as Slick 50 and Prolong. They tear those engines down after every race anyway.
Here are some numbers I ran across during a url search;( http:/www.ibmwr.org/otech/oil_faq.html )
I use 5-30W Mobil One.
amsoil
so respectively,
viscosity index 165 186 ( higher the better)
flash 445 464 ( higher the better)
pour -65 -76 ( lower the better)
% ash -- -- ( lower the better)
So the difference is really of hairs.
I USE IT IN ALL OF MY VEHICLES! (Ohh noooo!)
By the way, only the car has a Fram filter. I use a different brand on my other vehicle. If you're that interested in what it is, ask.
Also if you look closely at my post, it was a comment about my late VW with dino oil in it, in response to #200. Some of us are taking this stuff waaay too seriously. Okay, I know I'm guilty of shooting my mouth too. D'oh!
Just a question, does anyone here use Quaker State...? Any other brand other than the two currently being debated over? ;-)
however, use what you like. it's your car. why you would use the most expensive oil with the cheapest filter is beyond me, however.
-Chris
Having said that, I want to point out that Fram filters DO meet or exceed the auto manufacturers OEM specifications. So using them does not void your car warranty, or automatically ruin your engine. Now if you, like myself, want to get that extra peace of mind from the use of a premium filter, go for it. But don't try to imply that Fram filters are so much junk they will ruin your engine, cause the auto manufacturers say otherwise.
http://members.xoom.com/minimopar/oilfilterstudy.html
several types of oil filters and stayed with Purolator One until I found this website, www.trasko-usa.com, claiming their spin-on filter can filter up to 1/100 of a micron and a reusable media. But I think $68 each is too much.
Any comments on this.
The filter is every bit as important as the oil. I would use one of these filters(Mobile 1 or Purilator)even if I only used conventional motor oil. You're only hurting yourself by buying cheap filters and cheap oil.
Ah, yes, on the horns of a dilemma! But to add fuel to the debate;
(The real lack is one of standards for the oil filter, either in filtering ability and its long term consequences, or mileage between changes.)
On one of my suv's, I go 15k between oil changes (Mobil One 5-30W) and have used fram ph8a filters, but now have gone back to the oem filters. I have 80k on the the clock, so my next scheduled oil change is 90k. At the 60k major tune,(the important thing being removing the valve cover gaskets and checking for valve adjustment,) the oem dealer certified it not needing adjustment and the engine was cleaner than a whistle. Oil use has been consistent at 1/4 to 1/2 quart at app 12-14k. So in light of the above posts, this is a cheap filter/expensive oil scenario.
Actually, I have read in some A/B comparisons that Amsoil is slightly better than Mobil One. In my opinion, the reason why Amsoil is more in price, is that they probably produce far less in volume and might have different distribution method/s than Mobil One. In my opinion, while I don;t use Amsoil, it is a superior product.
Vern
Thanks for the heads up.
I was plannig to switch to M1, is it too late in the ballgame to switch? In reading post # 208 it seems like it not worth the risk.
Consumer Reports recommends 7500 mile oil changes.
The Fram filters have "paper" end caps.
Also, can it improve fuel economy and overall performance of the engine?
There is a lot of Mobil1 users, what are your experiences with that product?
Did CR happen to mention the fact that synthetic oil is more resistant to combustion contaminant saturation (this is what turns your oil black) than conventional is. Or that synthetics maintain their viscosity at higher temperatures than conventionals do. Or that synthetics flow better at colder temperatures than dynos do. My guess is, probably not. If they would have, they wouldn't have been able to make the statement that dynos are just as good as synthetics. Dyno is not as good as synthetic, and don't let anyone try to kid you into thinking they are!
Thanks for any info.
Stan Mojave Desert so CA
Davide
I would agree with you. I am one of those that goes 15,000 miles between oil changes. One of the things that is not understood/well hidden is the reason why the 3,000 mile oil and filter change is the defacto standard. There are more technical reasons, but two big ones are less superior lubricant (conventional vs synthetic) and the much higher percentage ash content of conventional oils.
Higher ash % is a measure of thermal breakdown or the product... SLUDGE. Since synthetic has a higher temp tolerance and a lower ability to form sludge it can and does last longer as a lubricant. So the jet black you are seeing in conventional oil is partly the sludge that would form if you let it go to the maximum capability of the conventional oil.
For me, I look at it in the best and worst case this way.
Based on 100,000 miles using 3000k intervals I would have 34 oil changes vs 6 for a 15,000 mile interval. Since structurally, the synthetic has WAY less % ash the long term chance of forming sludge is greatly reduced, not to mention the time and product cost. I keep in mind that I have 4 rigs, so it severely drops the intervals in which I have to change the oil.
Since I no longer change my own oil, the cost difference over 100 k miles is 1020 conventional oil vs 288 for synthetic. While 3.54 x more cost for the conventional oil may or maynot be a big deal, I really like the reduced amount of trips.
Bottgers, I fully agree that viscosity stability, low ash, and cold-flow characteristics are key attributes of synthetic oil. Too, your point regarding "more resistant to combustion contaminant saturation than conventional oil" is a major advantage. I don't doubt this characteristic but have resisted too much extension of synthetic oil change intervals for lack of any real knowledge of this particular criteria. Can you point the way to any documentation regarding comparisons or test results regarding combustion contamination saturation? Thanks.
Valvoline is my personal choice. It looks better..is about all I can say. It has given great results.
Have read advertisments that synthetic is better. And after reading 100+ posts here, one can assume that it is better!
Two years ago I bought the Valvoline synthetic "blend" and started using it for every oil change (between 3,500-4,500 mi). Please try not to laugh. I guess that the cost factor had something to do with choosing blend. And that's a good justification for most. I mean what can it hurt? Everything has been fine so far.
Now, if total synthetic can get...like 15,000 mi before oil change, and regular oil can hold up for 4,000 miles, then wouldn't the "blend" be capable of 10,000 miles before a change?
Without any numbers on the blend, unless you can get the analysis information like you see at the "famous" oil comparison site. (I think it has been posted here before.) You may be paying more for your synthetic blend based on the amount/quality of the oil you use.
With that said, I'm sure it is a quality oil, but it would be hard to extrapolate that you could go 10K miles with it.
Cheers,
TB
