MF & Residual for 2016 Range Rover Lease
13
  • buckeyefan8buckeyefan8 Member Posts: 24
     Any news on the new numbers in February  for a 2016 Range Rover HSE TD6 for 33, 36 and 39 month lease at 15,000 miles a year?  Thanks!
  • kyfdxkyfdx Moderator Posts: 273,949
    robertsa1 said:
    robertsa1 said:
    hi great info here! thanks!
    looking for 2016 Range rover HSE diesel 24 and 36 months at 12 k
    looking for 2016 Range rover Supercharged V8 24 and 36 months at 12 k
    any know incentives out there from land rover? Who do they use Chase bank?
    24/12 - .00345 and 75% for both trims
    36/12 - .00235 and 63% for both trims
    No incentive information.
    Land Rover Financial Group is Chase Bank
    is this for 2017, i was asking for 2016, thanks
    do you have new numbers for feb for 2016
    Not yet..hopefully soon.
    Still waiting..
  • robertsa1robertsa1 Member Posts: 71
    you did not answer if this is 2016 or 2017. when will feb numbers be out> thanks
    2016 RR HSE Diesel:
    .00165 MF and 71% residual
    .00057 MF and 59% residual
    2016 RR SC
    .00241 MF and 72% residual
    .00114 MF and 61% residual
    .00046 MF and 59% residual
    .00057 MF and 57% residual
    .00067 MF and 56% residual
    There is a lot of confusion here. did the residuals for 2016 drop for the diesel in feb compared to jan? what are the current feb numbers for 2016 diesel and 2016 v8 supercharged for 24 and 36 months. 12 k a year. thanks!
  • MichaellMichaell Moderator Posts: 269,764
    24/12
    Diesel Base - 74% and .00297
    SC - 72% and .00241
    Diesel Base - 62% and .00138
    SC - 61% and .00114
  • fjohn07fjohn07 Member Posts: 22
    just to confirm, is the MF on the 2016 RRS SC 0.00114? if so, looks like it went up from December when i looked at it last. thx.
    Yes, .00114 is correct for 36 month terms.
    Ok, thanks very much.
    Can you provide the 10k and 12k MF and residual for both the HSE and SC? Also, what's the sweet spot in months? Thanks!
    Which model Range Rover?
    Oops, forgot to include. The 16 RRS
    12k numbers; subtract 1% for 10k
    33 months
    HSE 58% and .00029
    SC 57% and .00043
    36
    HSE 56% and .00039
    SC 55% and .00052
    39
    HSE 55% and .00049
    SC 54% and .00061
  • eaglesguy20eaglesguy20 Member Posts: 46
    What are the MF and residual for 2016 Range Rover (full size) gas HSE trim for 33/36/39 month terms at 10K miles? Also, it appears there may be a $2000 customer cash for remaining 16's, if you can confirm.
    33/10 - 62% and .00046
    36/10 - 60% and .00056
    39/10 - 58% and .00065
    No information on any incentives available.
  • zp_zp_zpzp_zp_zp Member Posts: 4
    Could you give me the #s for the Base 2016 Range Rover (the one that starts ~87k) for a 39 month 10k/yr term?
    Also, generally, I'm confused about the term "SC". Aren't all the models Super Charged?
    could you please review your numbers? they are all over the place. on feb 2 you say the 2016 SC v8 was residual of 61 for 36 months. on feb 4 you say 55 percent. which is it? is said in my post there is a lot of confusion here.
    .00143 MF and 61% residual.
    The SC model is a super charged V8.
    The base model is a V6
    Might have accidently read from the 2017 chart.
    Latest numbers for 36/15 on 2016 RR SC (not Sport) - 59% and .00114
    Do the mf and residuals change daily with land rover chase? a week ago mf 2016 were .00015, now .00114. thats a big jump within the month
    Support is likely ending on the 2016's - probably not a lot of inventory left. At that point, the residuals drop and/or the MF goes up.
    LR does change the numbers monthly.
    there are hundreds left. more than 2017s on the ground.
    do you see the mf change at all during the month?
    and how much can they increase the mf at the dealer?
    No mid-month changes expected, or ever seen.
    Max MF mark up can be .00100
  • nicksmu17nicksmu17 Member Posts: 188
    Can I get a 33/10k, 36/10k/ 39/10k MF and residual for 2016 Range Rover HSE in Illinois?
    A week ago was January... this is February.
    Also, is there a big MF/residual drop off on the diesels?
    can you double check this. my dealer says 2016 RR Supercharged (not sport)
    36 month 10 k 61 percent which would make the 35/15 you quoted 58.
    Long WB is 58%. Standard WB is 59% for 36/15.
  • bdmaxcatbdmaxcat Member Posts: 3
    what is mf and residual on 17 Evoque SE Prem for 39/15 and 39/12
    The 2017 Evoque lease thread can be found here:
    https://forums.edmunds.com/discussion/43119/land-rover/range-rover-evoque/2017-land-rover-evoque-lease-questions#latest
    Do these work for the diesels as well?
    No; HSE diesel numbers are as follows:
    33/10 - 62% and .00046 (OK, this one is the same)
    36/10 - 60% and .00057
    39/10 - 59% and .00067
    edited February 2017
    How about 33/10 and 33/12 Range rover 5.0? Any different there?
    I don't show a 5.0.What trim level?
    sorry,
    2016 LAND ROVER RANGE ROVER 5.0 SUPERCHARGED 8
    So basically the supercharged v8 as opposed to the v6 hse. Thanks
    .00107 MF and 64%/63% residual
    Best term is 39 months
    .00119 MF and 60%/59% residual
    Do you know numbers for 2016 Range Rover full size HSE td6 for 39mo at 15k miles a year, is 39 month still the sweet spot? Thanks!
    54% and .00063
    Range Rover 33/10 and 36/10 in Illinois?
    Which trim?
    gas and diesel v6 SE and HSE
    Which trim?
    I'll assume SE is base
    33/10
    SE gas - 64% and .00130
    SE Td6 - 64% and .00129
    HSE gas - 61% and .00041
    HSE Td6 - 61% and .00043
    SE gas - 63% and .00135
    SE Td6 - 64% and .00135
    HSE gas - 60% and .00053
    HSE Td6 - 61% and .00056
  • martina827martina827 Member Posts: 5
    hi - could have have the march money factor and residual for the 2016 RR Supercharged V8 for 33/12, 36/12 and 39/12. i can calculate 10 k and 15 k accordingly. Thx
    hi. 2016 full size range rover supercharged and V8 HSE 24 AND 36 MONTH residuals and mf for 10k. thanks!
    62% and .00101
    61% and .00109
    58% and .00114
    73% and .00233
    62% and .00109
