2003 Suzuki XL7 - No paradise by the dashboard lights
Since last week the dashboard lights including lights on the shifter are all off, The speedo and tach display are still lit but the dimmer no longer works, and although my hi-beams work when I flick them, when I flip them forward to engage them full time they no longer work. This all happened at the same time. I've checks all battery connections, cleaned leads etc. no luck. Any help?
Did you try to reach underneath and do the "wiggle test"?
How did you check your fuses? If you did it "by sight", that could fool you easily.
How about checking for another fuse box? Are you sure there's only one?
How about fusible links coming off the + battery post?
You may need a wiring diagram to figure out how all these symptoms interconnect.
To test fuses properly, you should pull them and use a simple volt/ohm meter and test for continuity.
This is why a wiring diagram is so important for diagnosis. In the diagram, you may find what controls all these functions.
