Brake Rotors
robertnaylorrobertnaylor Member Posts: 9
edited April 2017 in Mitsubishi
Hey I bought some Brake rotors of RockAuto.com and the came with some kind of sticky residue on them and im not sure if I can take some water and clean it off or if I should just buy some brake cleaner to clean it off.
Best Answer
Answers
  • robertnaylorrobertnaylor Member Posts: 9
    thank you sir
  • thecardoc3thecardoc3 Member Posts: 5,878
    To clean that stuff off, brake cleaner first, then you have to wash away any solvents left over from the brake cleaner with soap and water. If you don't get all of the solvents off of the rotors then you risk contaminating the brake pads with them as material transfers between the pads and the rotors during burnishing.
    That's being thorough, and probably a good idea with spankin' new pads.
