A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
I will change like you're all suggesting, M1 oil every 12K miles and filter (some decent one,don't know what brand yet)every 6K miles.
Thanks again.
JOhn
I stopped by K-mart on Saturday to check for availability of the Mobil 1 filter. I haven't seen your post at the moment where you were asking for the number.
Yes, K-mart carries our filter. I took a very close look at how it was made. And frankly speaking, I wasn't impressed. Quality of the housing in my opinion is not as good as of the Motorcraft filter. Also it differs in construction of its internal components. So I decided to go with the FL-2005 at the moment. The AC Delco Ultraguard at the same time looks very impressive. But it's not available for our car.
I'll stop by K-mart to get the Mobil 1 part # if you're still interested.
BTW I don't know if the concerns in regards of diminishing capacity of the filter just after 6K
on a relatively clean engine are warranted in any way. In my opinion a modern engine doesn't generate enough of gunk to clog a quality filter for at least 10K miles. But again, it's just my opinion.
yura,
I've noticed that different people have different needs. Thank you for pointing this out for me.
You are not the first one saying good things about Motorcraft filter.I remember that someone (on one of those Focus forums) have said the same think about our Motorcraft filter.
Since I'm not an expert I'll have to trust you guys on that one.
Also when it comes to oil/filter change, I'm trying to find some good and easy system.
I will be driving a lot of "stop and go" with a/c on with many cold starts in between. How about this: M1 synthetic oil and Motorcraft Fl-2005 oil filter every 8k miles? (both changed at the same time)
According to this link the Mobil one is a filter of very good quality.
All I'm saying that it didn't have a high quality
"feel" to it.
Here is what they say in regards of the Motorcraft filter.
"This is an interesting filter. Basically, it is a Purolator Pure One filter cartridge in a Purolator Premium Plus case. Don’t be fooled by the differently-shaped holes cut into the oil inlet. This is the only difference. This is a good filter design and if you want to get a Purolator Pure One filter, get this one instead: it is cheaper.
Like the Purolator Pure One, this filter cartridge features a very large element surface area (400 sqin),but with many pleats (64). This packs the filter together rather tightly and may restrict flow somewhat. I could identify the Pure One element media by a purple dye they use at the seam. It also has the mysterious assembly
string wrapped around the outside of the element. Like the Purolators, it features a spring-loaded metal bypass valve and a nitrile rubber diaphram-type anti-drainback valve. The bypass valve is stamped right into the bottom end cap of the cartridge, so it is all one piece."
I don't know any other site of this type.
Unfortunately, it's not been updated since 5/25/99
http://www.scuderiaciriani.com/rx7/oil_filter_study/
change oil and filter for your particular driving habits and engine.
I've never used this method before.
But according to what I hear, there is no a better way to obtain a necessary information to make that decision. The tests are easy to use and will run you $20-39 depending on the test.
Thanks for a interesting link.
there are many kinds of the mail-in oil analysis kits.
You can buy them on-line or at your local auto parts store like Autozone.
As I said I'm just starting to look at the posibility of using one of those tests and don't have enough of information to recommend any of them.
www.syntheticsolutions.net
http://www.globaltechnovations.com/products_kit.html
Also take a look at this message board.
You can find some intresting opinions regarding the synthetic motor oils.
http://www.noria.com/boards/lab.cfm
I switched to Mobil 1 on my 2K Max at 1000 miles. I change oil and filter. Then again at 5000 miles. I now have 8800 miles, and have always noticed that Mobil one gets dark quick. I suppose it is doing it's job and suspending the soot particles.
My Syn. oil also changes to a slightly darker color soon after the change, but levels off for the duration.
I don't have an answer for you.....sorry.
John
JOhn
In my area Walmart sells Havoline oil for .72 a quart,an engine will go 200K using it, what more do you need.
I've also seen people mention improved fuel economy....sorry, no dice on that one either. Exactly the same, dino or syn.
So, why am I still using Mobil 1? Hell if I know!! Just decided to continue my experiment. I change oil and filter every 4k, rain or shine, hot or cold.
BTW that particular model used to have (still?)a big sludge build-up problem in the regularly serviced engines.
I heard that switching to synthetics made a huge difference.
http://www.engineoilinfo.com/index.sht
LOL
If our discussion is no more than "junk-science
and anecdotes" why do you even bother posting on
this board?
We're all here trying to find out what kind and brand of oil would be best suited for our engines.
We share information and ideas. Please present yours in more informative way.
But, every day and every hour we have to make our decisions, based on random bits of not-bulletproof information. At best an anecdote, a random case story, even more often just common-sense opinions, rumors and/or gut feelings: what your friend, colleague or relative told you, what a mechanic suggested, etc.
Why do we use such a not-scientific data? Because this is better than nothing.
As to Edmunds board, it let us easier ask for and receiving such opinions, and let also argue, if we see something wrong. Still not science, but very useful - much better than just reading advertisement, or ask for opinion of a neighbor...
I understand this is not a university or a research lab, however, there are some here who would advance their theories as if they were gospel, to the detriment of those who don't know any better. For example, making recommendations to extend the oil change intervals to exceed a manufacturer's recommendation is irresponsible. To those who've suggested that, will you pay for repairs on vehicles who's warranties have been voided due to a lack of proper maintenance?
And, if, as vadp states, the goal is to figure out which oil to put in your car, there is a little book that comes with every car sold in this country that has that answer....it's the owner's manual. Take a look at it, it tells all you need to know about lubrication requirements.
No, you don't have it straight!!
My owners manual gives a specifcation and it translates to Mobil One 5-30W or 10-30W and further says that to NOT use it would jeapordize the warranty! Incidently, the oil change interval can go as high as 15,000 miles.
Sorry to disappoint, but our needs are quite different.
I understand that some vehicles are coming from the factory with Mobil 1, but I attribute that more to Mobil's marketing efforts than anything else.
Let's see, a Mobil marketing guy goes to Chevrolet and says, "We'll give you free oil for every Corvette, if you'll let us say in our ads that Chevrolet chose Mobil 1 for their ultimate performance vehicle."
The Chevy guy says, "Hey, we can save $3 per vehicle, get a little more exposure for our product, get myself a promotion for being so smart...what's not to like, where do I sign?"
Both companies are happy, and the gullible consumer says, "Well, if Chevy is using Mobil 1 in the Corvette, that stuff must be great! Let me get some for the Family Truckster."
Seems logical to me!
There is a huge difference between a factory fill with a "recommendation" and an actual requirement that synthetic be used to protect the warranty.
