I'm having two problems with my 2001 dakota, which may or may not be related. The first is that at night, when I open either of the doors, the headlights go out. At first the dome light came on, but now it doesn't anymore. The second is that the radio keeps resetting itself. We took it to a garage where they supposedly rewired and fixed the radio, but after a few months it started resetting more and more. Now it is almost every time we start the truck.
hey guy i have a 2002 dakota replaced the computer and it still want turn over with the key,no lights come on when i turn the key to the on positon ever thing else works checked the fuse no power to the starter fuse inside the truck can soneone please help.
The speaker noise could just be bad speakers, but it's always a concern that something hooked into the wiring has caused other issues down the road. If nothing else, you could try disconnecting the player and see if you can reset things that way. BBBind.com has free wiring diagrams if you want to scour them for ideas.
You could try calling some dealers (or maybe find an indy shop that repairs CTMs) and see what they say. Maybe that would save you a long ferry ride!
You do have a shop near you that is a sponsoring member of the iATN, The Auto Works on Tongass Highway. Three techs in All American Auto are also members.
First time posting. I have a 2001 Dakota in which both dome lights flicker. If I turn the headlights on, the flickering stops. If I temporarily disconnect the (new) battery, flickering doesn't start until the dome lights are activated. Replaced the headlight switch on dash but made no difference. No other lights seem to flicker.
thanks...
When I hooked the battery back up after the repair to my heater core my hazard light indicator was on CONSTANTLY as it would usually blink when turned on, and the high beam indicator light was on. After startinvit I realized the instruments weren't working either.
Thought that I damaged the whole panel so I got another from a recker shop. The high beam indicator went off but hozard indicator was still on and instruments weren't working.
PS: when using blinker they flash as usual and when not being used they are off, just the panel light is the issue. What do y'all think?...
Previous owner claims to have done an engine swap and it runs strong aside from the fact that I have to manually shift from 1 to D at every stop light
I've swapped over almost the entire wiring harness (Engine and Interior) I know the interior harness is good, pretty sure the engine harness is good.
Battery refuses to charge, I've got a new ignition switch (saw a video that said that was part of the system), new alternator (90A), and a new PCM from Rock Auto. This is one of those PCM's that has the voltage regulator inside the PCM unit itself instead of an external unit. Made sure the numbers match up with the PCM, still no charge.
There's another part of the engine wiring harness that sits on top of the engine, in which connects to the alternator, AC compressor, throttle body n' such, in which I deem the "secondary engine harness". I've got a hunch that the problem is in that part of the wiring harness, it's just a matter of weeding it out.
I've got a complete and separate engine harness in which I can swap out if it's in the main engine harness and I've got another interior harness I use to eliminate the interior harness that sits in the truck.
But anyhow, any of you got an idea as to what my problem may be and how I can fix it?
Do you have a scan tool and if so, what modules responded and were there any trouble codes?
