my 1998 Toyota Avalon leaks water into the trunk when it rains
Elliot UdellElliot Udell Member Posts: 83
edited May 2017 in Toyota
The rubber gasket around the trunk looks like its intact. My mechanic said that even it was the gasket it is no longer available. What is causing this problem?
  • ClairesClaires Member Posts: 1,219
    edited May 2017
    Looks like you're not alone, elliotu - there are a couple of discussions about Avalon leaks here, and different members have found different solutions. Check HERE and HERE.
  • Elliot UdellElliot Udell Member Posts: 83
  • Have someone take a rubber tipped blow gun and blow out your sunroof drains! The two in the back are hard to get to!
    The leak seems to be in the front of trunk only
    Put some newspaper down in the trunk and first spray only around the tail lights--tail light gaskets can leak as well. If that doesn't show any water on the newspaper, then try again by spraying around the trunk seams and see what shows up.
