2014 Compass noises
john1112john1112 Member Posts: 3
edited April 2017 in Jeep
After driving for along time I get a thumping noise in the rear of my fwd as if something is loose. It would the same sound as you would get going over a pothole. The noise also occurs when accelerate also Any thoughts?
    Most common rear end noises on a FWD car are strut mounts or loose exhaust. There's not too much back there. Maybe a rear sway bar bushing is loose, if you have such a bar on your car. A quick trip up on the lift might spot something obvious.
  • john1112john1112 Member Posts: 3
    Thanks for the info. I'll take it to the shop
    Took the jeep to the shop and left it for 8 days. Took a long ride on sunday 6/4 and noise is still there.
