2017 Infiniti QX80 Lease Questions
2
  • kyfdxkyfdx Moderator Posts: 269,289
    jkipster said:
    jkipster said:
    What are the new numbers for FWD 39/10? Thanks.
    Its RWD.
    Base or SE?
    Base RWD.
    .00128 MF and 55% residual
  • bmnjlapbmnjlap Member Posts: 14
    Do you have the numbers for qx80 AWD with theater and driver assist packages in Northern NJ?
    36/12 ans 39/12 please
  • MichaellMichaell Moderator Posts: 266,289
    Base, Limited or SE?
    Base
    bmnjlap said:
    Base
    .00098 MF and 52%/53% residual for 36/39 months, 12K/yr
  • socalqx80socalqx80 Member Posts: 2
    SoCal, QX80 AWD signature! Thanks in advance!
    Sorry, 39/12.
    socalqx80 said:
    Sorry, 39/12.
    .00136 MF and 55% residual
  • tbelder7tbelder7 Member Posts: 7
    Could someone please provide current MF and RV for QX80 RWD base with 39/12 and 39/15?
    .00128 MF and 54%/52% residual
  • dallasmandallasman Member Posts: 79
    What is the MF discount for a single payment lease on infiniti?
    Doesn't look like there is any.
    That's correct. If you want to cut the money factor, use the MSD program. .00090 discount for 9 MSDs would take the money factor down to .00038.
  • scotttennantscotttennant Member Posts: 2
    Can you tell me the residual and MF for Tampa, FL on on the higher end trim levels, AWD, 24/12k, and 36/12 or 39/12 (new to Infiniti leases but I saw a 39/12 earlier in the thread, assuming this is common)
    39 months is the sweet spot for Infiniti; 39/12 numbers are:
    Limited AWD - .00071 and 46%
    SE AWD - .00136 and 55%
  • jasherrrjasherrr Member Posts: 33
    Hi there! Looking for October numbers for the QX80 SIgnature and 4WD Limited. DC Metro area if it matters. 36mo/12k miles, and 36mo/10k miles. Or - if the sweet spot 39, would love those figures also. Thank you!
    39/12 is the sweet spot for Infiniti; add 1% for 10K
    Ltd - .00192 and 53%
    Sig - .00003 and 45%
  • mlevinemlevine Member Posts: 594
    QX80
    My problem with 39 month leases is as follows:
    Requires more scheduled maintenance
    Definitely will need 1 to 2 additional sets of tires
    Brake and rotor replacement very likely.
  • shake_74shake_74 Member Posts: 1
    Hi. Would like to know residual and MF for QX80 - AWD, Driver Assistance, Theater and Tire packages. In Ohio. 39/10 and 39/12
    Base, Limited or Signature?
  • metahimetahi Member Posts: 42
    could I please get the MF and Residual for 39/12 base, limited and signature in the Boston area? thanks!
    Base - .00062 and 51%
    are there updated Nov numbers for the MF and Residual for 39/12 base, limited and signature in the Boston area? thank you
    Assuming AWD
    .00062 MF and 51% residual
    .00192 MF and 53% residual
    .00003 MF and 45% residual
  • de_1210de_1210 Member Posts: 14
    2017 MF and residual 10,000 / 36- 39 months pittsburgh
    ^^^QX80
    de_1210 said:
    ^^^QX80
    RWD or AWD?
    Base, Limited, or SE?
  • patrickdqxpatrickdqx Member Posts: 12
    Can you please provide most updated December numbers (resid. & mf) for 4WD, Base, QX80 with Driver assist, Theat. & Wheel package for 39 mo. 15k miles in Ohio. Also, does it change if you add tech package?
    .00062 MF and 49% residual
    Packages don't matter.. just trim.
    who sets them, the dealer or MFG.? If i was quoted something higher than that, is it safe to assume that they were just marking it up? How often do these rates change?
    IFS sets the base MF and residual. Dealer can mark up the MF for extra profit.
  • b3311b3311 Member Posts: 5
    edited December 2017
    Can you provide MF and residuals on 39/12K RWD base, limited and signature for TX?
    RWD Base - .00093 and 52%
    RWD SE - .00133 and 54%
    Those are the only two QX80 RWD lease trims we show
    What is the lease cash being offered for December?
    We don't have Infiniti incentive information.
    Do you have any info on the MSD program? How many can you put down and at what price?
    Max 9, each of which lower the MF .00010
    The size of the MSD is the monthly payment, rounded up to the next highest $50.
    Hi, guys
    Can I get Base Q80 AWD for 36/12K residual and money factor. What is the acquisition fee? Thanks as always.
    mlevine said:
    Hi, guys
    .00062 MF and 51% residual for either 36/12 or 39/12.
    Pretty sure Infiniti acquisition fee is still $700
  • nyccarguynyccarguy Member Posts: 17,631
    Good afternoon guys. Can you please give me the money factor and residual value for a 2017 Infiniti QX 80 (all trim levels) all wheel drive in CT?  36 months/15K miles per year as well as 39 months/15K miles per year?  Thank-you.
    39 months is always the sweet spot for Infiniti
    Base - .00062 and 49%
    Ltd - .00192 and 51%
    SE - .00003 and 43%
  • stratapropstrataprop Member Posts: 21
    Please give me the money factor and residual value for a 2017 Infiniti QX80 AWD in California (where the local lease offer has lower lease payments than the national offer)? 39 months/ 10, 12, 15 k per year. Thanks!
    Can you please provide most updated December numbers (resid. & mf) for 4WD, Base, QX80 with Driver assist, Theat. & Wheel package for 39 mo. 15k miles in Ohio. Also, is it expected to change between now and the end of the month?
    Program runs through January 2nd
    Base model
    Base model
    .00062 MF and 52%/51%/49% residual
  • jmcortes93jmcortes93 Member Posts: 37
    Hi Guys,
    how do the numbers look this month on the base model for 39/10 39/12?
    Also, is there numbers out for the 2018?
    Im in Texas, thank y’all
    Hi Guys,
    RWD?
    .00093 MF and 53%/52% residual
    2018 numbers are in.
    That discussion is here:
    https://forums.edmunds.com/discussion/49797/infiniti/qx80/2018-infiniti-qx80-lease-deals-and-prices/p1?new=1
