If you've checked the owner's manual and checked with the dealer, try a general web search.
Other options: Find a Chilton's (or similar) maintenance manual for your van at your local library or buy one at an auto parts store or online. You could also subscribe for maintenance data for your vehicle at http://www.alldatadiy.com .
Jeff
Web search brought me hear and I was hoping to find out the problem online without bringing it in to the dealer.
What's odd about the beeps is that they are long 4 second beeps with a 2-3 second pause in between not like the short ding ding of a seat belt not on.
If anyone has had this same issue I would love to hear how you resolved it.
Thanks again.
Corkscrew
When I figure this out i'll be sure to post back here what the problem was.
Cheers
No "check engine" lamp illumination after starting?
I've never owned a diesel. Could the symbol represent glow plugs, indicating malfunction of one or more glow plugs? (Since it's winter, thought that might be a glowplug symbol.)
The 8A to 14A change in alternator current might be related to an intermittent glowplug or intermittent connection to a glow plug.
Jeff
If you think the people who frequent dodgeforum might have an answer, you could register there and post your questions.
Jeff
In the diesels I operate for the Highway Authority, they all have this symbol, including the front end loaders. The FORDS say "WAIT TO START"
The Wait To Start Indicator will illuminate when
the ignition key is first turned to the ON position.
Wait until theWait To Start Indicator turns OFF then start
the vehicle.
kcram - Pickups/Wagons/Vans+Minivans Host
https://www.facebook.com/media/set/?set=a.10151608340892192.1073741825.675762191- &type=1&l=a6d2c2ac08
Jeff
