Pacifica stuck in park
Please help. I've disassembled my 2007 Pacifica's console and gear shift assembly. Found the spring detached and fixed pink thingy. I'm still stuck in park. I'm out here alone so ANY help will be appreciated
Best Answers
Mr_Shiftright
Member Posts: 64,481
is the cable moving? Can you move the pink piece with a screwdriver to the right and get it out of park?5 -
Mr_Shiftright
Well if the pink thingie is attached properly, and the cable is attached to the thingie, it really should work.
Do you have brake lights? if you don't you may have a bad brake light switch. That will prevent the shift interlock from operating.5 -
berri
Member Posts: 10,165
Is there a release button somewhere near it? I had that problem back in the 90's with a Toyota and I believe somewhere near the gearshift was a tab you carefully pulled to push in a button or some such in order to unstick the gearshift. But since yours is apart with a pink thingie, maybe not on your Mopar?5 -
Mr_Shiftright
The shift-interlock system must be defective---just hard to know from this distance where the problem is.
5
Answers
