12728303233164
  • morinkmorink Posts: 12
    I went to see my dealer this morning and described the problem to the service techs. They said that this did not sound like a problem and from what I was explaining sounded like it was doing what it was designed to do. I asked to test drive another 2002 V6 Camry which they did. I made a couple of observations. As you can see from my other messages #13 and #20 I also have the "Cold Shift Shock" problem. When the service rep started this car it was idling fast (1700 RPM) which you would expect when cold. When he shifted into drive the car surged forward (expected at that RPM) but quess what !!! no cluck. I told him also about this problem and he could not give me an answer as to why mine does and this test vehicle does not.
    I did test drive the car and it presented similar symtoms as mine (described in #25) so maybe this is the nature of the beast. After I returning from the test drive and talking to the service reps. they explained to me that this car is what they called "fly by wire" no cables or pulleys. They told me that the computer makes a lot of adjustments (shifting) depending on a lot of circumstances/road conditions. I was led to believe that this is just the way it is.
    FWIW
  • pauls427pauls427 Posts: 1
    I've had my car for about one month and there is now a squeaking noise coming from the roof panel behind the sunroof. This panel seems flimsy.
    Has anyone else experienced this??
    Also my power driver's seat has too much play in it which the dealer could not fix....
  • The following is a TSB from the Engine Rebuilders Association.
    AERA Engine Rebuilders Association
    330 Lexington Drive
    Buffalo Grove, IL 60089-6998
    TECHNICAL BULLETIN
    March 2002
    TB 1963
    Mfg: Lexus/Toyota Model: Car/Truck
    Liter: 3.0L
    Code: V-6
    Year: 1993-2001
    OIL CONSUMPTION OR ENGINE DAMAGE ON
    1993-2001 Lexus/Toyota 3.0 V-6 Engines
    The AERA Technical Committee offers the following information
    regarding oil consumption or engine damage on 1993-2001 Lexus/Toyota
    3.0L V-6 engines. Either of these conditions has been reported even
    though proper oil maintenance has been endured. The cause of these
    conditions may be the result of oil pooling in either cylinder head.
    If the oil is allowed to puddle several undesirable scenarios may
    result.
    Depending upon the startup oil level in the oil pan and the amount of
    pooled oil while the engine is running, a depleted amount of supply
    oil may remain in the oil pan. The amount of oil in suspension in the
    cylinder heads may overwhelm both the valve stem seals and PCV system,
    causing oil consumption. This oil consumption may or may not produce
    oil smoke out the tail pipe as temperatures within the exhaust system
    (catalytic convertor) completely burn the oil vapors.
    The apparent cause of these conditions is oil sludge accumulation in
    the cylinder head drain back passages preventing sufficient oil flow
    from the top of the engine to the oil pan. It has also been reported
    adding a quart of oil to an engine showing a quart low level on the
    dipstick may be misleading. In some cases with excessively sludged up
    engines, the amount registering on the dipstick does not equal the
    amount added to the top of the engine.
    Some AERA members report repeated engine oil flushes and changes may
    be a temporary resolve for effected engines. Also, much shorter oil
    change intervals are necessary, perhaps as often as every 1000 miles
    to keep the sludge from reappearing.
    http://www.aera.org
  • In the morning, the shift from reverse into drive is a hard jolt you can hear and feel. Service told me this is "normal" for the 6 cyl. (After dropping off car at dealership, getting a ride home from a friend and going back in the a.m. so service could hear and feel this thud). Then the brakes failed; the brakes locked with a very fast clicking sound, this was on a slow turn into a parking lot; able to coast and when pulled into parking space the brakes were again working. Service cant find anything wrong.
    Also, when at a long stop light, brakes slowly sink down to one inch from floor. Brake p. Have taken to two different dealerships; service said everything checks out fine. Sent letters, even called Georgetown; so guess it's all in my mind, huh? I asked regional service rep if Toyota would work with me, take this back and I would pay the extra thousands for an Avalon. The answer: they will sell me an extended warranty!!!
    My answer was I am not talking about a starter, I am talking about the BRAKES and I am not keeping this car. I am looking at eating a minimum of $7,000 to unload it on another 2002 trade in, different mfg. Have had Toyotas in the past and they have been great. This has been a huge and costly experience for me. Toyota again for me? Even a gold plated one, I think not.
    Good luck getting Toyota to back up your problem.
  • 90camrydx90camrydx Posts: 1
    I can't find any diagram or information on resetting instrument cluster lights. Anyone help me?
  • deepandeepan Posts: 342
    this is a general question about the colour of oil. my parents visted me over the weekend and because of the sludge paranoia i took a look and found the oil to be dark brown. Its a 2000 Camry (4 cyl) and has 25k. The oil was changed in March and since then the car has about 3k kms on it mostly highway (2* 850km round trips). I have a 2000 sienna and due to diligent chking of the oil have never seen it this dark. I also have a 87 camry and the oil hasnt been dark. any reason for the colour of the oil. The oil has been changed
    every 4-5 months within the 6K specs. The oil appears to be "thick". this was the case before the March oil change as well and at that time didnt pay too much attention. the Car runs fine.
  • armtdmarmtdm Posts: 2,057
    Based upon all the discussions I would say that your parents 6K oil changes are way too long. They need to go the the 3-4K changes to play it say. I use synthetic in my 92 and at 7500 it is still amber. You may also suggest pulling the valve cover on this one to play it safe. Especially in Canada
  • 8u6hfd8u6hfd Posts: 1,391
    since deepan is a canadian....it's 6k kilometers, not miles. 6000 km turns out to be 3728 miles. Still on the safe side.
    for deepan: the color of the oil. All your cars take the same oil, correct? Different oils (weights, brand, lots, etc) will have a variation in color. Castrol Syntec is usually dark amber from the bottle.
    it was easy to miss, because it was written twice (km). And they were placed in the middle of the post, not the beginning.
    Its kms. I have no idea of the oil used in the camry but on my sienna (dealership dino oil) and the 87 camry its pennzoil (sp) and the original colour is "light". 5w30. My dad gets it changed at the dealership and its not synthetic. My dad will take it in one of these days and will keep you posted.
    Hello 8u6hfd
    You mentioned in your note #26 that you believe there are TBS's for shifting problems on some 2002 V6 Camry's with auto transmission. Could you please point me in a direction that would indicate this somewhere. Toyota says they are not aware of any transmission issues on these cars which I do not believe. I just want to find out if there is someone else that is experiencing the same shifting issues as described in my message #25 and if there was a fix for this.
  • teh3teh3 Posts: 1
    response to Starter Problem??? by andrelaplume:
    It is the Neutral Safety Switch that sits just outside the automatic transmission that is the problem. This can be temporarily fixed when you move the automatic gear from "park" to "neutral" or just wiggle it when you are in park or neutral. This happens because the electrical connection on the Neutral Safety Switch (NSS) is worn and "wiggling" it allows it electrical connection to touch again. I had the same problem & so bought a second hand NSS and installed it myself & didn't have a problem after that.
  • stans40stans40 Posts: 16
    Does anyone know a phone number for Toyota to ask a technical question? The customer service people are of no help and neither is my dealer.
  • dengsgdengsg Posts: 1
    I have a 2002 Camry LE V6 with GI package#2 option (remote keyless entry, driver's power-adjustable seat, JBL AM/FM stereo, CD player, cassette player, eight speakers and diversity antenna). So far I’m quite happy with this car (3100 miles). But I have two problems that I’m not sure:
    (1). The theft deterrent system can't be activated? I contacted Toyota dealer and was told my car doesn't have this feature. But I could not find any option that includes the theft deterrent system or alarming system. I suspect this is a standard feature in all Camry. You can test your car according to owner’s manual (pages 28-29).
    (2). According to owner’s manual (page 88), if the car is equipped with automatic light cut off system, we should be able to turnoff the headlight immediately when we lock the car with keyless remote. This is not what I observed in my car, I have to wait for very long (>30 minutes) before the headlight turns off. I suspect my car doesn’t have this, but this feature is not listed in any options.
    Can anybody test your car and send your answers to deng_0[email protected], many thanks in advance.
    dengsg
    8u6hfd,
    Thanks for the pointers. I did go out to a site and low and behold I found 2 service bulletins for shifting issues with my 2002 Camry. The service bulletins are as follows.
    Make: TOYOTA
    Model: CAMRY
    Year: 2002
    Service Bulletin Number: 689
    Bulletin Sequence Number: 625
    Summary Description:
    Electronic message regarding shift quality feeling improvements on vehicles equipped with the 1MZ-FE engine.
    Make: TOYOTA
    Model: CAMRY
    Year: 2002
    Service Bulletin Number: EG01301
    Subject regarding U140E shift quality improvements.
    In a message that I sent to Toyota USA I asked if they were aware of "ANY" service bulletins with regards to shifting issues with my vehicle.
    I received a reply back from Toyota saying that they were not aware of any service bulletins with regards to shifting issues for my vehicle. I just sent them the 2 service bulletins that I found and are dying to see how they get around this one.
    I did not trust the Toyota dealership where I purchased my car for giving me a straight answer that is why I went to Toyota directly. I should have known that I was not going to get a straight answer from them either. I would imagine that Toyota puts out these service bulletins and if Toyota customer support is not aware of them something is VERY wrong.
  • can find out what other owner's complaints are:
    www.nhtsa.dot.gov
  • My Camry came from Georgetown, Ky:
    l-502-868-2000 or
    1-800-868-9750
    Ken, thanks for the response. That is the factory number, but they only refer you back to customer service. Toyota has isolated themselves from answering any technical question even if the potential problem was caused by the dealer.
  • pham2001pham2001 Posts: 15
    The car had 215 miles now. No rattle anywhere. Its
    engine runs so quiet even at 80mph. I'm happy that I got the v6 instead of the I4. I4 (got it).
    I picked the Luna mist metalic over the red and white. To me it looks more elegant.
    I am so fed up trying to get a straight answer with regards to this "Cold Shift Shock" problem that I am also experiencing I decided to send a complaint to Toyota. The following is what I sent.
    My vehicle is also one of many that is experiencing the "Cold Shift Shock" problem. I am not sure if this is the proper terminology for the problem but this is what one Toyota service rep. told a customer.
    When I start my vehicle either first thing in the morning or after work the car cold idles at about 1700 RPM which is fine. When I shift the car into reverse (brake on) I feel the car surge backward which is normal because of the higher RPM. When I shift into drive at the higher RPM I hear/feel a cluck or thud while shifting into drive. If I do let the car sit and idle for about 2 to 3 minutes and bring the RPMs down then the cluck/thud into drive does not happen.
    I have read of many folks with my year and model Camry experiencing this same problem and others are not. Just for my own curiosity I went to the dealership where I purchased my vehicle and had a service tech start up (cold) a vehicle exactly as mine. I watched the tach and it was at 1700/1800 RPMs and then had the tech shift into reverse and then into drive and quess what!! no cluck/thud going into drive. I questioned him as to why mine is doing this and he could not give me a real reason. This techs brilliant response was to let the car warm up before shifting into drive.
    If some cars are doing this and others are not then there is a REAL problem in the vehicles that are having this problem. I am not taking this car back to the dealership again because if there is no TSB from Toyota or a check light from the computer they are NOT going to be able to help. I(we the loyal Toyota customers) need someone higher than the dealership service techs to look into this problem.
    If I do not hear from Toyota that they are going to seriously look into my problems then I am going to place a "LEMON" sign on my vehicle and drive around with it until I can get some straight up answers from Toyota. I will also place my problems on any WEB site that I think may help the next person decide whether they want to purchase this vehicle.
    Unhappy Toyota owner
    I also have the strange shifting problem ( I submitted #19) which I am also trying to work with Toyota. For those of you who are having problems please keep pushing to get Toyota to open their eyes and know that there are real problems with these vehicles that need to be addressed. I have the 2002 Camry LE V6.
    Kurt ...
    I also have another issue with my new Camry that has been happening. While descending down a hill ( between 40 and 45) and when I apply the brakes the car will down shift VERY (can even hear/feel a cluck) hard. This has been happening quite often and is not normal. I have seen this problem entered on another site. I will be forwarding this off to Toyota USA.
    Kurt ...
  • gp4gp4 Posts: 9
    I'm disappointed in the quality of the new Camry, I think they've done to much cost cutting. Recalls, squeaks and rattles and an exhaust pipe that looks like it is dragging the ground.
    JD Powers even noticed the poor quality of the new Camry. The Camry isnt even in the top rung any more, its even lower than Chevy.
  • Me too, hard shift, brakes; file to Toyota 2 inches thick. Brakes failed, both dealerships said checked out okay. Floaty brake pedal down to one inch from floor; this at 1800 miles. Gave up and traded in (no Toyota this time); took a $7,000 hit. Interesting government defective site to check out other problems with Camry, (can file complaint if you want). Site is:
    www.nhtsa.dot.gov
    I also posted earlier message May 20 under Camry Owners: Problems & Solutions, message #34
    Good luck
  • suv4x4suv4x4 Posts: 14
    Anyone had gas pedal problem of the 98 camry? my 98 camry with 40000 miles, sometimes gas pedal couldn't be pushed when the car from stop->start.
  • iontrapiontrap Posts: 139
    This sounds similar to what was happening with my camry. All I had to do was clean the throttle body.
    My car had only 297miles on it. I noticed the brake is making a tapping noise from metal to metal when I slowed down to make turn to the drive
    way. And both rear rotors showed a lot of grid lines. Some are deep I can felt it with my finger rubbing it. The 2 front rotors still looks very smooth. What's wrong here with the brake?.
    I'll bring my car in for service this week. But I'd like to have some
    ideas regard to this problem so the dealer won't be bs me.
    Any input is very appreciated. Thanks
    PS.
    To alpha01, tiger8
    Do you have any idear regard to
    this brake problem?.
  • george00george00 Posts: 81
    I am appalled at the problems so many people are having with a car whose main attraction is reliability. I'll describe my experience here in case it can be of any help.
    I have a 2002 LE4 automatic with 3500 miles on the odometer - I bought it in January. So far, the operation of the car has been flawless - no rattles or squeaks, no shifting surges or noises (in fact, an extremely smooth transmission), the standard brakes (disks up front, drums in the rear, no ABS) work just fine, the car is very steady and quiet, and makes 28 mpg in mixed local/highway driving. It's no street racer, but neither am I; I have no difficulty merging onto a 75 mph highway.
    The only problem, and it is major, is with the driver's seat. I have the power option (all the LE4s I saw had it), so positioning is easy. But the seat is much too hard and improperly shaped - in particular, the top of the seat-back angles forward, which pushes my shoulders forward and gives me royal backaches after an hour or so of driving (which is why I didn't detect the problem during several 20-minute test drives).
    I have had 3 auto upholsterers work on the seat. They have made it much better - the seat comes, incredibly, with a horizontal metal bar a third down from the top of the seat-back; this is so hog rings can be used to pull in the fabric at that point, but it drove me crazy until it was removed. But even with all the fixes, and a top-of-the-line (= expensive) sheepskin cover, the seat is still uncomfortable over long rides.
    I have tried every aftermarket seat cushion available and even bought special "memory foam" and made my own cushioning, but it's simply impossible to overcome the hardness, narrowness, and shape of the seat. The one thing that has induced me to make every possible effort to fix this seat, apart from the financial loss which must result from trading it in now, is my assumption that otherwise it is an excellent car with assured reliability. I am therefore horrified to learn that it may not be all that reliable, after all. I guess I may be back in the car market sooner than I had planned.
    George,
    All the shifting (transmission) problems that I have been seeing seem to be happening with the V6 engines. I have a person that lives in my complex that owns a 2002 Camry with the 4 cyl. and he told me that he is not having any shifting issues at all (including the cold shift shock that so many are complaining about).
    I have submitted 3 different problem E-mails to Toyota USA and have not heard back. Usually they get right back stating that there are no know problems that they are aware of. It has been 4 days and have not heard back so maybe someone is really going to take my problems seriously and start looking into them.
    FWIW
    Kurt ...
