I did not notice the same problem with my old car.
If you are out of warranty and it is a documented "factory" problem [TSB], I don't know if you can force them to pay. However, many of the dealers like the goodwill and may make the repairs for you.
Finally, it you have a Camry 2003 or 2004, and the TSB is for the 2002, but the problem is identical (like a rattle), some folks have ahd problems getting the dealer to listen.
In any case, print the TSB and talk to both the Service Manager and to a lead mechanic (if needed), if you can get access.
Tell us about your experiences.
-Hank2
Also, they advise for the 2004 models that the oil should be changed no later than 5000 mile interval. Part of the problem was people letting the oil change go over the 7500 mile limit. Therefore Toyota changed the manual to read 5000 miles.
If you have proof that the oil changes were done on a consistant basis within the required time frame, Toyota will replace the motor.
This is really, at this point, a dead issue and I have not seen any complaints on the web in the past six months.
I am in no way affiliated with Toyota.
This is my first auto with ANTILOCK BRAKES and TRACTION CONTROL.
I've seen these features in normal operation and believe that I can recognize them when
they are in effect.
I'm experiencing 2 problems that might be related. They both relate to rain/water
and they both relate to the front end. When hitting a bump AND puddle simultaneously on the right front side, I
momentarily hear a clicking sound in the front. It's almost like a ratcheting sound and it
remains for a few seconds, clicking about 3 to 6 times. The clicking sounds very much like a bad CV joint.
I feel no difference in the steering wheel or performance, however.
The second problem is that when driving in medium-to-heavy rain quite often the engine
(or transmission) changes into a mode that makes it feel as if it has downshifted or something.
The engine (or trans) noise is MUCH louder. I recall this happening in heavy snowfall as well. In fact, I recall
one time just trying to get out of a parking spot in VERY heavy snow that this situation came up. So somehow it
seems as though something is sensing that there is bad traction on the ground (?). When it gets into this mode,
it seems to stay that way for at least a few minutes.
I have tried turning off TRAC (I think?), but I'm not sure if it's related to that system or not. I'm not even
sure if turning off TRAC while the engine is running is even supposed to work that way.
I don't suspect that these problems have anything to do with ANTILOCK BRAKES, but I have not ruled out
TRAC, since I don't know enough about it. I have played with the TRAC in the snow in a parking lot and
was impressed with how well it worked, and it didn't make any such noises in those tests.
Any suggestions?
Thank you all, and thank you Edmunds for providing such a forum !
I bought a 2000 Camry XLE V6 brand new in 2000. I've put 175,000 miles on it so far, mostly highway miles. I know that's alot of miles for such a short time but I thought this car would last me at least until 250,000 miles.
Well, yesterday, all of a sudden in the morning, I noticed some non-uniform vibration comming from the engine area while idle as well as during accelleration (although less so). Clearly, you can tell it's engine related When the car is situated down hill, the vibrations are least noticable and vice versa while up hill if that means anything.
I took it to a mechanic shop and a young lad (late 20's early 30's) told me after changing the spark plugs that the fourth cylinder is misfiring.
Please say it isn't so. I just closed on a mortgage yesterday (seriously)!
Can it be? Someone please tell me it's probably an electrical or timming belt problem. Could it be that my V6 Camry engine, supposedly one of the best engine on the market today, is dying? I took good care of this engine. I changed the timming belt twice (last time at 120,000 miles (currently 175,000miles). The oil was changed regularly, even more often than needed many times.
(on average every 4000 miles).
What should I do next. I haven't taken it to a dealer yet. Perhaps this is the most logical thing to do. But how do I find out what to do while avoiding having to pay too much only to find out that my car will soon be a junker.
Please tell me it isn't so.
Thank you for all of your responses sincerely,
Joseph
now in San Diego
Could it be a dirty fuel injection system??
I own a 2002 4cyl. Camry with 28,000 miles.
At first, I thought I had a fuel injection problem (I noticed a ticking in the engine and it was idling rough at stops). At one point they mentioned something about the sparkplugs too.
However (after 3 weeks in the dealership shop), it turns out that a cylindar wall was scorned. Toyota had to replace the engine. Luckily, it was still covered under the warranty. They said it would have cost me $12,000 (not $1,200) for all the work they did.
Honestly, Toyota is not all it is cracked up to be. My Camry has a ton of annoying rattles, pulls to the left, wind noise, and the engine had to be replaced. The are unable to fix the rattles, so far. If you want "Toyota Quality", buy a Lexus (Volvo, Benz and Cadillac are also excellent options).
As a side note: I have not had a single problem with my 1997 6cyl. Grand Am SE.
Sorry to hear about your problem.
camryman5
(Illinois)
Our 2002 LE V6, built in KY, runs like a clock and has absolutely no rattles. Toyota does make a great product. It's just that some out of the thousands of cars manufactured are lemons.
I have always maintained this schedule and have never experienced a sludge problem. We have kept some of our cars for eight to ten years.
Prehaps it has nothing to do with the quality of the car, but the quality of the person you bought it from.
Not that they are perfect, but did you pull a carfax before you bought it? Sounds like you might have picked a winner there..
Be glad Toyota felt for ya and picked up the new motor.
The Carfax report was fine. I assume both cars were rental cars. Regarding the Camry engine, I tend to believe that mine must have been abused. I've read about some car rental companies that never change the oil in their automobiles.
Toyota did indeed pick up the tab...kudos to Toyota!
Thanks for your diagnos. Quick question, so the engine is mis-firing. What if I drive it anyway.
Is it a safety hazard? Is there a risk of fire.
I'm thinkin about just driving this baby till she croaks.
Thanks for the response,
Joseph
in San Diego.
PS. How's the BMW 330 reliability?
http://www.yotarepair.com/breakingnews.html
Steve
While you are at it, change the cabin air filter. It gets filthy after 15,000 miles. There is a great illustrated instruction in the owners manual.
PS. Also changed the cabin air filter couple of days ago, it's real easy and at 11,500 miles it was already pretty dirty
I am considering options including checking with the dealer's sales department to see what kind of a deal we could make on a new car. However, I'm really not sure I want another Toyota. The failure was catastophic - during a merge onto the interstate with a semi coming up behind me. I'd appreciate any advice including whether I'm being unreasonable to assume that the engine should not have failed so spectacularly in a car of this age and mileage.
I do plan to write an indignant letter to Toyota and the dealer, and possibly check into the Hyundai with its 100K powertrain warranty.
In the 2001 camry, the smell goes away, once I let the air run for a while(without recirculating it).
anyone recommend a solution? Is a "moldy evaporator"? My neighbor has 2 camrys both with over 45K miles on them(2001 and 2002) and he says he does not have this problem. So what gives here?
I'm "sick" of this new camry, almost thinking of selling it. Should not this be covered under the warranty? Please help.
thanks.
333 of 384 canoe2 and andrelaplume by amphipri0n
Feb 19, 2004.... Posted the following:
andrelaplume: you can download http://www.tt-cc.com/ratko/TSB.zip open it up and the noise issues all start with the letters "nv"
-Hank2
zguy in AZ
I'm getting really poor gas mileage. With gas prices so high and my problem, I dropped 90 bucks on gas last week. That's really hard on the pocket especially when you don't do much driving. So I just did the throttle body cleaning because I had a lot of carbon build up. I hope that helps. But while I was getting that service done, I was told that my air/fuel sensor was going bad ($600 plus to fix... ouch). Could that be the problem? I'm doing a major tune up this weekend(changing wires, plugs, etc.) Is there anything in particular that I should be checking while doing the tune up. Thanks.
BTW, my car is a 99 with 79,000 miles
Thanks Members
I have an 03 SE V6 and had the same problem with my transmition. Took it to two dealers, they couldn't fix it. Took the car to Toyota of Glendale in Los Angeles county and they fix it by re setting the software and now it is it shifts very smoothly. Hope this helps & good luck.
I had the tranny problem since week one after the purchase and it was during low speed or during freeway bumper to bumper traffic. I also found Toyota dealerships to be ignorant or lazy about taking care or their customers. This past week I bought my daughter a new Hyundai cause I was turned off by Toyota's response to our few problems.
Good luck
