1. A M240i automatic in Sunset Orange with Cognac leather. Every option box checked with sunroof delete and M Performance Locking Differential, or...
2. A M2 manual in Long Beach Blue with only the Executive Package or...
3.A M2 Competition Package in Sunset Orange(I'd have to wait about 8 months...)
That is all...
I think driver100 (grandpa) should quietly shop for a suitable replacement and present it as a gift to the grandson. For under $5,000 he can probably pick up a safe more reliable transportation type car that will let him sleep nights. If he thinks it will cause a family rift for circumventing dad, he can offer to trade "his" car for the X3.
Just make sure the grandson promises not to share it with the dreaded SIL.
Here's one:
https://toronto.craigslist.ca/tor/ctd/d/2004-honda-pilotex-4wd-8/6326240356.html
Although I think the dealer left a 1 off the front and a zero off the back on the milage. CL ads in Canada list km instead of miles, right?
You have said it is a "hack job", your SA says it is a "hack job", I tend to think it is a "hack job",........I just would like to know why....kind of like they have to prove these things in a courtroom
Knowing the SIL....if it ever broke down or caused trouble he would blame it on me.
There was a warning in this weekends newspaper about flood cars that come up this way, they said to look in all the little holes and crannies to see if there is rust, mud, or fish. There is something wrong with a car that sells for $4900 with 3000 miles on it.
I was at a red light and this Lexus was opposite us. My wife rarely comments on car designs, but she said, what an ugly grill!
She believes it is supposed to be some kind of macho look.
2. Ditto for the DSC(stability control and torque vectoring). Those electronics function based on signals going to and from the transfer case. The electronics will "assume" in some cases that the torque is being apportioned to the front diff when in fact it isn't.
A guy on bimmerfest.com has been diddling around with a 2WD conversion on a 5er wagon. One guy who knows what is involved posted the following:
VO/FA string is only stored in LMA and CAS.
You need to default every module (including LMA and CAS) after changing VO/FA (and writting VO/FA to LMA/CAS) so those modules update the coding based on the new VO/FA. VO/FA does not need to be written to other modules
Pushing the job Code Car in NCS expert often fails in my experience. Especially on modules that not often coded, such as DSC, EGS, or MOST components. Just run SG_codeiren with Expert Profile (or any profile with manipulation turned off) on the affected modules.
For that VO/FA code, I would default CAS, LMA, DSC, EGS, DME, and KOMBI.
Disconnect the VSGS module under the car.
Also, you installed a USED DSC module? VIN must to coded to that module via WinKFP. You will need to flash the module to write your current VIN to it. Then it will be recognized. I recommend you use an ICOM head. DCAN is a more slow interface and the risks of bricking modules increases with the use of a DCAN cable.
If your battery is weak, replace it. Low voltage while flashing will brick the DSC module, unlike coding. With coding, you can always default the module. When flashing fails, you need to force flash the module via NFS. If that does not work, a new module is needed.
You need a POWER SUPPLY, not a battery TENDER to keep voltage stable. You also need a continuous supply, not intermittent and it needs to supply at least 50Amps.
Do you think the doofus your dangerously cheap SIL hired can even spell "DSC"- much less know or have the correct equipment to do what was suggested above?
I doubt US flood cars could make it into Canada. All the import regs alone would tend to frustrate the crooks. At least for $5k cars. Just run the VIN through the US check system and do due diligence as usual.
If I had the money I'd be buying cars for every niece and nephew I could find.
https://www.bmwofturnersville.com/detail-2018-bmw-m3-sedan_4dr_sdn-new-16862893.html
1) I am surprised an amateur could manage that, and
2) that he would be stupid enough to try it, especially because of liability issues.
I do know the SIL drove the car to our grandchild (his daughter) and that was almost a 300 mile drive.
I don't know what has happened since then.
Thanks for the information....that is even worse than I imagined.
The article did say flood cars always show up in Canada. I don't know how they do it, but, where there is a will there is a way. I don't know if I would buy a car from a private seller or a dodgy looking indie dealer. I have done it in my early days, but, I have learned a lot since those days.
I know how the SIL thinks. He probably converted the car to 2WD so I would worry about it and offer to buy the granddaughter a good used car. I am not going to fall for his plan. When he comes for Thanksgiving he will probably cry and whine and say he is sorry he has to give his daughter an unsafe car, but, it is all my fault because I won't buy them a newer car :@ That is what he does!!!!!!
What does your daughter say about all this?
Daughter...who is a doctor.......has to support husband to maintain marriage.
I have to be careful what I say.
I will try to talk about it when they come for dinner.....next week
It is a bit complicated family dynamics situation unfortunately.
Very good point. I think I sense that too. The car will only be used in the city and not in bad weather. Maybe the hack-mechanic told him that. I think it yours is a gutsy opinion and does make sense.........I like the saying "Nothing is ever as bad as it seems, and nothing is ever as good as it seems".
2017 Subaru Impreza hatch and sedan
These new Subaru Impreza's are really quite...impressive. I know, but I just couldn't resist. They have a curb weight of 2,964 lbs. which seems a titch heavy but really isn't. When you consider what's riding on your tires. For a longer, wider Subaru Impreza, you're gonna want some weight to hold the car on the road when you lean back down in and straighten your Impreza out for the long haul on the straightaways ahead.
Get out there and drive. I saw a black sedan and couldn't identify it. That's what got me looking in to what I saw that night. It was dark out and I couldn't make out the lines of the automobile. I thought Subaru because of it's body brand identity. It showed even in the side view at night. It was either a 2017 or 2018 Subaru Impreza. The underpinnings of the Impreza will now in the future be the underpinnings of each and every Subaru model. Including the CrossTrek.
Every model of Impreza gets a rear view camera and Android Auto/Apple CarPlay, which is a great thing to have. And symmetrical AWD, of course. After all, it's a Subaru. Get out and drive. All 2017 and/on Subaru Impreza models are assembled in Lafayette, Indiana. It's not a conundrum, it's a positive that they're being assembled in Indiana. Oh, no. I just got a flash thought of Bobby Knight. Uggghhhhhhhhh. That bright red sweatshirt and strong work ethic. Eeek.
2017 Subaru Impreza engine specs
2.0L 1995cc 4 cylinder, engine code FB20
Horizontally Opposed Boxer design
DOHC with timing chain (not a belt)
16 valve- dual active valve control system (DAVCS)
new for 2017 Sequential direct fuel injection
Dual Active Value Control System DAVCS
Bore x Stroke 3.31" x 3.54" (84mmx90mm)
new for 2017 Compression 12.5:1
Composite intake manifold
new for 2017 Composite valve covers
new for 2017 Active grill shutter (Sport and Limited models only)
Redline- 6600 RPM
Also, you installed a USED DSC module? VIN must to coded to that module via WinKFP. You will need to flash the module to write your current VIN to it. Then it will be recognized. I recommend you use an ICOM head. DCAN is a more slow interface and the risks of bricking modules increases with the use of a DCAN cable.....etc
I am just wondering.....the original cost to repair the car was $8000 from what I understand (that is what granddaughter said). The hack fixed it for a few $100. What I am wondering now is.....if you bought the car having AWD instead of 2WD is not an $8000 option, so why does it cost $8000 to fix it? The other thing I am wondering is.............how could the hack figure out all those codes, hook up power source, turn off the proper sensors, and not know what he was doing?
I wouldn't alter the car myself, even the possibility it could be unsafe would lead me to scrap it, I just don't know if it is actually unsafe.
My thinking would be they paid about $30k for it, got 10 years of practically trouble free driving, probably put a total of close to 250k miles on it, so for $3000 a year they got their moneys worth out of it. And, if he traded it in a little earlier which he never does...he drives them into the ground until they aren't worth anything, he could have used the trade in money to buy something else........but, he doesn't think that way.
New!
Previous:
Now that I posted them, I think the new one with the old front (with a bit of an update) would be good, and I am not a fan of the small rear quarter windows.
The new one, like many new generation Toyolex products, is really overstyled, to my eyes. I don't think these will age well design-wise, as time goes on - the Germans seem to be toning it down a bit already.
Outward visibility is probably iffy in both of them (of course, these are often driven by people who don't look before changing lanes anyway
In contrast, outward visibility is pretty good on the '17 and/on Subaru Impreza. It has those little slant windows connecting up to the A-pillars, like my first car, the lovable 1965 Ford Mustang.
Holy (non permissible content removed)! 250k miles plus what you put on it before you sold it to him? That bucket ain't even worth the few hundred hack job.
It's one thing to flog a hooptie to squeeze a few more miles if you are a broke dirt farmer like me but to ride a dying horse when you could afford a thoroughbred just seems foolish.
The Koreans are similar, but bring it down a notch.
American cars are made to look solid and fast.....sometimes aggressive especially in the grill area.
European usually keeps some of the old world flavor....simple lines, usually carried over from the past.
Very general and only my impressions.
Both sides of the question seem reasonable to believe, either you can't convert the car 100% safely, or, possibly removing the driveshaft doesn't really matter....I don't think we have a conclusive answer - though some excellent theories!.
I said to my wife, I have to clear my conscience - I don't really know if the car is safe as it is or not, but, if there is any question I wouldn't allow anyone to drive it. She will be visiting our daughter and will tell her my thoughts privately without the SIL around. When our daughter buys a car her main concern is safety....she was in one fairly bad accident once. I doubt if she has any idea whether the fix is questionable or not. She is a smart lady, but, naive especially where her husband is concerned.
I am OK with no more comments unless we learn something new.
When he bought our business we probably made a late payment less than 6 times in 12 years....and if we did miss a payment it was because the supplier didn't get an invoice to us. All our other bills were paid when we received the goods, we wanted to be number one with our suppliers.
When the SIL took over, I doubt if he ever paid 6 invoices on time. He spends more time fending off people who want money than he does trying to grow the business. And when he does send a check he often puts the wrong year on it or "forgets" to put on his signature. He does this with people's pay checks as well!
Another favorite trick was to tell them he was sending them a check that week. Then the supplier would call me on Tuesday or Wednesday and say he promised to send a check last week and it didn't arrive. I found out later that he would go to the post office at 5 minutes to five, get a post mark for Friday, then put it in the mail to stretch the delivery time.
That is only a small fraction of the stupid stuff he would do, and I would have to stay up all night trying to figure out what his schemes were.
Not sure if I'm unique with this, but exterior styling (from a form standpoint) is way down my priority list when picking a car.
I know you built your business from the ground up. You hustled, worked very hard, and made a very good living from it. Does it drive you absolutely insane what your Son In Law is doing to the business. Do you ever get calls or emails from suppliers saying: "Hey, what's going on here?"
If he hustled a bit and found new customers he could have had a nice business. I told him he had to replace 10% of his customers every year, because the current list of customers won't stay static. If he had done that for 5 years he would have been fine.
I am sad that about 10 people lost their jobs, and I am sad that a nice little business isn't around, but, we had a good run of about 20 years. I think SILs method is if he can take advantage of you he thinks he has won....but, business doesn't work that way anymore. I thought if we can do well for our customers then we will do well, and if I pay my suppliers immediately (not wait 30 or 60 days) they will sell me their best products - where else will they get cash immediately and be sure to be paid?
It was quite an experience.....the good thing is I now know what I am dealing with.
The latest generation of MB has a lot less clutter, and it seems that brand reached peak styling volume (in the modern era) around 2010. As Europe is usually the design leader these days, we will see/hope this trickles down.
