When, on average, do you need new tires?
                    Let's just say that our Manual Transmission Mazda 3 I touring has only had 2 tire rotations in it's lifetime. At how many miles would you say it is RECOMMENDED and at how many miles would you say it is NECESSARY to change the tires?
Also, if you're on the original tires that came from the factory, those generally don't last as long as what you'll replace them with. Typically I've only been able to squeeze 25-30K out of a set of OEM tires. Your driving style and roads you typically drive on can affect tread life as well. (Driving on hilly, winding roads vs mostly straight highway, for example)
Here in PA, tread depth of 2/32" won't pass inspection, but you'll start to notice traction issue in the rain and other conditions before you reach that point. At 4/32" the tires are "worn". Once you get to worn, it's time to think about replacement. You can check tread depth with a coin:
That will give you an idea wear you stand on tread. There's no such thing as a "perfect alignment" and if you don't rotate regularly, you will see some kind of irregular wear. Certainly make sure your alignment is within specs, but then keep up on your rotations.
As tires wear, they lose their siping and I don't like the loss of traction.
Consider that tires are the most used safety item on your vehicle. We're coming into fall here in the Northeast. Leaves coming down, rain making them wet. If you're beyond "worn", you'll see a loss of traction on less than ideal conditions. Heck, you'll notice a little tire chirp if you start up from a standstill and the tires happen to be sitting on painted pavement markings.
I replace my tires between 4/32 and 5/32. With an SUV that means all four tires replaced together as a set. I get just about 60K per set and my Escape is due for it's fourth set after the originals next month.
As a field test engineer for a major tire manufacturer, I've seen the same make/model tire wear out in as little as 10,000 miles ( Phone company installation van), and go over 100,000 miles (city to city package delivery van)
Dads are so smart sometimes
