Buick park Avenue Problems
                    I have a '99 Buick park Avenue with just over 7000
mi. At 2000 mi a noise was either coming out of
the engine compartment, or from behind the dash.
The noise sounds like a fan or whistling noise, and
is most prevalent when the car is idling and
standing still, but gets louder when you step on
the accelerator. The noise stated out as
intermintent, but now is constant and very
annoying. I brought the car back to the dealer
several times, but they could not isolate the
cause. Has anyone else experienced this problem?
Also, my PA has a vibration emanating from the front right tire. It comes and goes without a pattern other than highway speeds. I've read were the LeSabre is having a terrible time with this. Buick keeps blaming it on poor balancing, wheels out of round, and tires. I'm skeptical.
My theory is the cause may be in the drive train or brakes. Something is causing a slight vibration that in turn causes the tire to wear unevenly, which then amplifies the vibration. I just can't understand why it doesn't happen all the time?
Also, not aware of the vibration problem. Does it do it when the tires are cold? sometimes in cold weather a tire may "flat spot" slighty when sitting and cause a vibration for a short distance.
Here is an example of products available:
http://www.crutchfield.com/cgi-bin/S-0czlVnbFPZj/blockpub.exe?bid=795&store=2&sid=S-0czlVnbFPZj
http://www.crutchfield.com/cgi-bin/S-0czlVnbFPZj/blockpub.exe?dept=790&store=2&sid=S-0czlVnbFPZj
Radio Shack may carry similar items.
Good luck
your host, Bruce
I had the blower motor and fan speed control (1 piece) changed several times. It would take care of the problem for a short time and then would start again. On the fourth replacement in a year the service rep told me that they were getting the blowers from a different supplier. I have had that blower in the car for 4 years and have not had any problems.
I don't know the problem with the original blower but suspect that it had something to do with the electronics of the variable speed control in the blower.
Besides the noise issue how does everyone like the car? I had one as a rental car once and thought that it was an amazing car. I just spent the day test driving cars. I'm looking at the Park Avenue, Chrysler 300M, Lincols LS, and maybe a Pontiac Bonneville. Any thoughts?
Mark
I got rid of the car because I drive in the NYC and NJ area and the roads are often in poor condition. While on rough roads the car felt unstable. For example heading down a hill while turning and you hit a bump you almost felt like the car would go out of control. This could be a function of the car's front wheel drive. Also I would take trips into Queens NY to see the Mets and the roads were particularly bad. There was a few times when I thought the frame of the car was twisting.
I have a 92 BMW 525 with a 5 speed and got tired of driving a manual transmission and I purchased the Park Avenue. I was going the sell the BMW on my own, but because of the handling of the Park Avenue I would up selling it and kept the BMW. GM should bring back the rear wheel drive GM cars that I remember when I started driving 20 years ago. These large front wheel drive cars don't handle well in the NYC-NJ area and may from my experince be unsafe. No wonder Police Departments won't buy front wheel drive cars.
Over the years I have had front wheel drive cars, the VW Jetta 88 and a Nissan Sentra and I never experienced the control problems that I did with the Park Avenue. I believe this may be due to the size of the car or maybe GM just cheeped out on stiffening the frame properly. The BMW is rock solid and now has 124K miles on it and the maintenance is high but at least I'm safe.
the front bumper, that barely misses the ground
standing still. When actually driving over just
a small bump, it hits it . When backing out of
a driveway, the thing does a nosedive into it-
including the high bounce the car does.
It does drive nicely outside of this weird
flotation number when there's a lift in the road.
But, I just don't get why this air deflector has
to be there. That has to cause a lot of damage
Good luck!
Pat
I've just had the front struts replaced, and it made a world of difference in handling (79K miles). Now, I notice that the rear end is quite soft.
Seems the air-pump is failing and I can't find the gosh-darn thing to save my soul.
If anyone is able to locate the sensor and the pump for me, I sure would be grateful.
Anyone know if this failure is common? Could other damage have been done which I will have to face after the warranty expires? I am debating whether to sell the car and what to buy.
other than a light wallet. Suspect crank sensor.
How do you get the vibration dampener (balancer)
off? Ice cream melting in the trunk at the grocery store.... it will get you there but you can't leave. Help.
The 2nd & 3rd time was because the driver's side rear door would not open. They've replaced most of the guts of the door. The last visit was about two weeks ago and the door won't open again. I'm about to schedule the third visit for the same problem. Can you say Florida Lemon Law?
I also have various and sundry rattles inside, mainly the sunroof. Nobody seems to be able to identify or fix them though. The sticker on this car was $36,000. I thought I was buying a quality car but I'm beginning to wonder.
it delivers cold air, but most of the time if I select AUTO and 60 degrees it just blows
ambient air. This intermittent problem is frustrating me . I went to the library copied some
troubleshooting proceedures, but unable to locate problem. I've been through the self
diagnostics several times but no fault codes show up then the a/c will start working for
awhile then stops working. The control panel display buttons seem to function as
advertised. Any Buick A/C wizards out there?
My wife's 95 Park Avenue (58K mi.) recently noted
a "fan-like" whirring sound every time it's
started. The noise continues for about 5 min. &
then shuts off. Had the oil changed this morning
and discovered the noise is coming from what looks
like a small compressor directly behind the
driver's side headlights. Every start, it comes on
and runs fo 5 min. or so. The grease-monkeys at the
oil change place said they thought it was the pump
for the suspension but that it shouldn't run that
long...Any ideas would be appreciated.
Will sell for $50.00. My '91 was totalled August 4th and I doubt I'll ever find a car that good again.
