Visitor Agreement.
mods for the Contour/Mystique and Cougar.
I would like you to fill out the survey at
http://www.createsurvey.com/cgi-bin/pollfrm?s=382
So I wonder what you are really interested in. I'm not gathering any personal information, just
what you have, what you have spent, what you wanna
spend, and what you wanna do, if anything at all.
Cheers,
TB
Personally, I would be interested in the following:
*Affordable headers.
*A stainless steel dual muffler exhaust like the one available for the SVT Contour (I love the sound of the SVT exhaust).
*A supercharger if it were affordable, and reliable.
*Cross drilled brake rotors. (I plan on changing out my rotors when it comes time to replace my brakes. I really want cross drilled rotors, the he one's available on KKM's website are only slotted.
As you can see other than the want for a reliable supercharger I don't really want a lot. I don't want to mess with my kitty's looks, and I think the suspension is fine the way it is. I wouldn't want it any rougher.
Cheers,
TB
http://www.spmotorsports.com
I purchased the Brembo/KVR Combination before all of the new choices were there.
Essentially, the Cougar uses the same calipers as the standard Contour, but bigger rotors.
So I'm sure there are parts there for you.
Also, check with BAT, I believe www.batinc.com
They have some British tuner parts, some may fit the kitty.
Cheers,
TB
Basically what I did to correct the situation is pull the plastic tube out of the side of the filter and insert the sensor directly into the hole. Now the sensor is directly in the path of the air flow and should read temps a lot cooler. To make the sensor fit properly, you have to clip some of the edge off the corner of the sensor. The tabs used to hold the sensor in place on the stock airbox, do the same thing on the soft rubber of the S&B filter. You may want to use a little RTV silicone to hold it in place, as a safety measure, but it is pretty secure without it.
I test drive the car for a few miles last night and there were no ill effects to what I did. In fact, the car seemed to respond quite nicely. I will be keeping a close eye on it for the next couple of weeks to see if there are any performance benefits. Up north this may not do anything for you, but down here in the Texas heat the more accurate you can get the air temp to read the better. I can definatley detect a performance drop while driving in the summer compared to cooler seasons down here. Hopefully this will help. Can't wait until Fall starts and temps stay between 50 and 80 degrees. My cat loves to stretch its legs when it's cool outside.
I read the article about the supercharged Cougar and it appears that to reap the full benefit more work than just installing the blower needs to be done. The cougar in the article also had the Qualfie diff. and stronger motor mounts installed. It appears that the stock diff can't take the extra horses. So you might want to consider adding that to the cost. The motor mount cost about 20 bucks and the Qualfie around $1300. Good Luck on the mod, once its all done your car should ROCK. Let us know how it turns out.
(stupid question, right? Maybe my mind is failing me at a young age ...)
Is there a supercharger available on the market for the Cougar? I know Paxton developed one, but from what I have heard they have not released it yet.
any greasemonkey with opposable thumbs and a wrench can do it....
I'm assuming that the pacesetter, is like the borla and requires no welding...
Where did you get your window tints done? I remember that you said you were happy with the job, and a fellow I know is going to need to have his tints stripped (too dark to pass inspection) and redone on the car he just got.
Have your friend check them out: www.latint.com
Also, I have not noticed any performance degradation, as some people have claimed. In 5th gear, I am hitting the same speeds about 200 rpm quicker than I was with the stock setup
Has anyone here changed the bulbs to the Cougar's headlights? Did you get different ones, if so which ones? I think the ones that come with the car are a little crappy and don't help that much when it's rainy and dark outside.
Maybe the pipe confuses the tach so it reads funny.
8-)
Of course, I'm just grabbing at straws here, so any real scientific data is appreciated! ;^)
No, it's not cheap as it involves a lot of labor time, and usually new pistons, rods, balanced crankshaft, bearings, etc...
Also, the HP increase is strongly dependent on the engine size and design to begin with. The larger the engine, usualy the more HP you can gain. However, as a percentage of original HP, it can vary strongly with design.
Stepping back from lecturn, removing mortarboard:
Skip G.
Not sure the warranty would actually be voided, a a true blueprint job isn't actually a modification, but returning to the engine to design nominals, eliminating tolerance buildup and slop.
Expensive?? You betcha!!!!
Skip G.
