I have been told by people that the Pacesetter seems to not be very loud. A friend of mine that was in the car one time said he could barely notice it. So maybe it being a little louder wouldn't be so bad. I need to look around on the Internet to find some glasspack wav files.
So I wonder what you are really interested in. I'm not gathering any personal information, just what you have, what you have spent, what you wanna spend, and what you wanna do, if anything at all.
Personally, I would be interested in the following:
*Affordable headers. *A stainless steel dual muffler exhaust like the one available for the SVT Contour (I love the sound of the SVT exhaust). *A supercharger if it were affordable, and reliable. *Cross drilled brake rotors. (I plan on changing out my rotors when it comes time to replace my brakes. I really want cross drilled rotors, the he one's available on KKM's website are only slotted.
As you can see other than the want for a reliable supercharger I don't really want a lot. I don't want to mess with my kitty's looks, and I think the suspension is fine the way it is. I wouldn't want it any rougher.
After doing a little research and looking at the stock air box, I came to a conclusion. The IAT sensor is located in a bad spot on the KKM intake. The sensor should be in a direct location where the air passes through. If you look at the stock airbox, the sensor is located in an air way right under the filter. On the KKM intake, the sensor is placed in a tube way outside the air flow. This will cause erronious air temp readings, and cause the computer to compensate for it.
Basically what I did to correct the situation is pull the plastic tube out of the side of the filter and insert the sensor directly into the hole. Now the sensor is directly in the path of the air flow and should read temps a lot cooler. To make the sensor fit properly, you have to clip some of the edge off the corner of the sensor. The tabs used to hold the sensor in place on the stock airbox, do the same thing on the soft rubber of the S&B filter. You may want to use a little RTV silicone to hold it in place, as a safety measure, but it is pretty secure without it.
I test drive the car for a few miles last night and there were no ill effects to what I did. In fact, the car seemed to respond quite nicely. I will be keeping a close eye on it for the next couple of weeks to see if there are any performance benefits. Up north this may not do anything for you, but down here in the Texas heat the more accurate you can get the air temp to read the better. I can definatley detect a performance drop while driving in the summer compared to cooler seasons down here. Hopefully this will help. Can't wait until Fall starts and temps stay between 50 and 80 degrees. My cat loves to stretch its legs when it's cool outside.
I've been looking at sport coil springs and have narrowed my choices to either Eibach or H&R springs. Does anyone have any opinions on these brands? If you have upgraded springs installed, how do you like them? Any info would be greatly appreciated.
I am also thinking about installing Eibach springs, but I can't seem to find anyone who has them. I want to know how ride quality and handling is effected.
Hey- I just sold my house and made a little money. I was wondering if anyone in here could tell me the pros and cons of putting a supercharger in my cougar (I know it voids the warranty). I'm seriously thinking about doing it. What kind of cost am I looking at? I've heard around 3,000. Do those things have warranty's on them? I saw an article in some magazine last month where they supercharged a cougar and it gave out an extra 90 horsepower. I'm drooling right now! My cat with 260 hp!!! Anyway, any info would be helpful. Thanks.
I read the article about the supercharged Cougar and it appears that to reap the full benefit more work than just installing the blower needs to be done. The cougar in the article also had the Qualfie diff. and stronger motor mounts installed. It appears that the stock diff can't take the extra horses. So you might want to consider adding that to the cost. The motor mount cost about 20 bucks and the Qualfie around $1300. Good Luck on the mod, once its all done your car should ROCK. Let us know how it turns out.
If you are going to try the egr block, be extremely cautious when removing the egr valve.On my car the bolts,which are steel threaded into the aluminum intake manifold, both broke off while being loosened! They are either very poor quality or, more likely, were cross threaded right from the factory. My car is in the shop now for repair. I hope the intake manifold doesn't have to be removed.
The EGR valve recirculates exhaust gases into the intake manifold, reducing combustion temperatures and emissions. The modification reduces the amount of recirculated gas and supposedly improves throttle response and performance. See post #345.
Jayhawk: Is there a supercharger available on the market for the Cougar? I know Paxton developed one, but from what I have heard they have not released it yet.
At this point, the only "mod" I've put on my kitty are small fish-eye mirrors on both side view mirrors. I live in an area of vicious traffic (as stageleft and jayhawk will confirm), and they help tremendously. Worth every penny of the $1.19 apiece I paid
I was thinking of replacing the stock headlamp bulbs with Phillips Cool Blue bulbs. I thought I remembered someone doing stating a while back that they installed them. Whoever that was, I would like to know how you like them. Was it worth the 30 dollars a pair?
I also have a question. My Pacesetter FINALLY arrived at my house today so I'm going to try and get it installed sometime tomorrow. Should any shop be able to do the job? Would a place like Midas be a good place to go to or should I look for a performance shop, what do you guys think? I live in Norhtern VA by the way, thanks guys. I will keep you guys posted as to who much I liked (or hated) the pacesetter once installed. Thanks!
daexpert, any greasemonkey with opposable thumbs and a wrench can do it.... I'm assuming that the pacesetter, is like the borla and requires no welding...
Fredly, any greasmonkey can do it, but it does not necessarily mean they'll do it right. I've had a couple of friends that have had "simple" setups screwed up, therefore, I wanted to know of a place that would not screw up my car. But the good news is that I got it installed and I love it. Just for the looks alone it's worth it, I really think that Cougars should come with dual-outlet tips, it looks great. The sounds is awesome as well, you can hear that it is definitely not stock, but it is not bothersome nor does it give you headaches from the deep droning other systems produce. I think it sort of has a European sound to it, but I guess everyone has their own opinion regarding that matter. I would recommend the Pacesetter, I'm not exactly sure how long it would last, but it also comes down to how long you plan to keep the car, and how much money you have to spend. Two thumbs up from me though! = )
Stageleft, I called around and got it installed a shop in Chantilly. The place is called Curry's Auto Service. When you go in there you see some awesome Porsches (spelling?) and some BMWs because that is their specialty, but they also work with Mustangs and with a 500hp Ford Lightning! They were very helpful, and promised me that the exhaust would be done that same day, so I dropped it in around 12 and it was done by 3:00 pm which is when they close. Btw, I'm still happy with the exhaust, can't get enough of that purr that the car produces now.
Where did you get your window tints done? I remember that you said you were happy with the job, and a fellow I know is going to need to have his tints stripped (too dark to pass inspection) and redone on the car he just got.
I got them tinted at LA Tint in Sterling. The original shop I went to years ago is on Route 1 though, about halfway between the Multiplex Cinema and where Telegraph Rd. hit's Route 1. The guys there are really professional, and the metal-based tint is definately worth the extra $$, IMO. Plus, you can get a lifetime warrantee against scratches, peeling, accidental removal, window breakages and just about anything else you can think of, so you never have to pay twice for the same tint! Great deal, if you ask me.
I just had my pacesetter installed last weekend (local mechanic $45). It looks awesome, and sounds great. It's a lot louder than stock, though. So, I wouldn't reccommend putting on a louder muffler, like some people have suggested. Also, I have not noticed any performance degradation, as some people have claimed. In 5th gear, I am hitting the same speeds about 200 rpm quicker than I was with the stock setup
I'm still happy with the Pacesetter, and for the price, it can't get much better than that! Performance has not decreased, nor increased, it's more of a feel that you get when you hear the rumble of the exhaust, pretty cool.
Has anyone here changed the bulbs to the Cougar's headlights? Did you get different ones, if so which ones? I think the ones that come with the car are a little crappy and don't help that much when it's rainy and dark outside.
jjp: I don't understand your comment about getting to the same speeds about 200 RPM quicker than stock. As far as I know, only a change of gearing will do that.
Actually, I've experienced about the same with my Borla. I think it has to do with the engine management system and how it deals with increased flow of gases. I remember when I had the stock exhaust, at 35mph the tachometer would register about 3200rpm, but with the Borla (and the KKM intake) it will cruise at 35mph at around 3000rpm. Is that what you're talking about Jjp?
That is exactly what I meant stageleft. Previously, 65mph in 5th gear was 3000rpm, now it is ~2800rpm. That is the only really noticeable difference. It seems about the same as far as acceleration goes. It does sound nice, though, and the dual tips look really nice.
It's like this, guys. The engine is connected to the wheels through gears. Gears have teeth and they don't slip. One turn of the engine converts to a specific fraction of a turn at the wheels. Unless the gears are changed, any given RPM in top gear will always produce the same wheel RPM. More power will give you greater acceleration but it can't give you more speed at the same RPM.
Maybe the pipe confuses the tach so it reads funny.
What your saying makes sense to me, lmigliore. Therefore, I can only conclude that a side effect of changing your exhaust is that it makes your tach either less (or possibly more) accurate. Does anyone know how the tach reads the rpm?
I believe it monitors the piston strike, and after about 6 combustions it considers that one revolution. Now do that about 3200 times in one minute, and you're doing about 30-35mph. The conversion of this power does happen at the gears, to the wheels through the transaxle, but if the airflow is better through the intake and exhaust, it doesn't necessarily move the car faster at those RPM's, but it gets you there faster. That's where the benefit is of upgrading the breathing system of your Cat, IMO.
Of course, I'm just grabbing at straws here, so any real scientific data is appreciated! ;^)
Engine blueprinting is basically a complete rebuild involving tolerances, balancing, and lightening all moving componenets.
No, it's not cheap as it involves a lot of labor time, and usually new pistons, rods, balanced crankshaft, bearings, etc...
Also, the HP increase is strongly dependent on the engine size and design to begin with. The larger the engine, usualy the more HP you can gain. However, as a percentage of original HP, it can vary strongly with design.
Yup. Unless you're building a serious racing machine and can expect to recoup the expense before you blow it up, it's not worth it. A complete machine shop is also required as you face the block & heads, center bore the crank and cams, balance everything that moves, balance and seat valves, valve guides, and a whole bunch of other stuff.
Not sure the warranty would actually be voided, a a true blueprint job isn't actually a modification, but returning to the engine to design nominals, eliminating tolerance buildup and slop.
I'll stick to intakes, exhaust, chips, and suspension mods. They may not produce the performance of blueprinting, but they are a heck of a lot easier and cheaper.
mods for the Contour/Mystique and Cougar.
I would like you to fill out the survey at
http://www.createsurvey.com/cgi-bin/pollfrm?s=382
Cheers,
TB
Cheers,
TB
http://www.spmotorsports.com
I purchased the Brembo/KVR Combination before all of the new choices were there.
Essentially, the Cougar uses the same calipers as the standard Contour, but bigger rotors.
So I'm sure there are parts there for you.
Also, check with BAT, I believe www.batinc.com
They have some British tuner parts, some may fit the kitty.
Cheers,
TB
(stupid question, right? Maybe my mind is failing me at a young age ...)
Have your friend check them out: www.latint.com
8-)
Stepping back from lecturn, removing mortarboard:
Skip G.
Expensive?? You betcha!!!!
Skip G.
