What is flat plastic strip above radiator called
nozmoking1nozmoking1 Member Posts: 7
edited April 2018 in INFINITI
Mine has a weird circular cutout/marring on it and I want to replace it. (Like that when I bought it)
  • nozmoking1nozmoking1 Member Posts: 7
    Will take pic when I have time
  • kyfdxkyfdx Moderator Posts: 201,023
    Maybe a fan shroud?
    It connects to the air intake on the driver's side.  I believe it channels air from the fans
    Any ideas how those gashes got in there?
    Just a guess. Pulley failure or fan blade failure, causing belt or partial fan blade to go flying through the engine compartment.
    Thanks kyfdx.  Any idea what that piece is called?
  • thecardoc3thecardoc3 Member Posts: 5,484
    I suspect that the top of the fan shroud fell down against the pulleys and the serpentine belt at some time in the past.
  • Mr_ShiftrightMr_Shiftright Sonoma, CaliforniaMember Posts: 64,482
    It might be called "upper radiator shroud" or "upper radiator T-bar".
    AIR INTAKE DUCT !!!
    Ah, so it's plastic! It must fit over the radiator support bar. This is an odd bit of engineering if you ask me. I hope it pushes cold air and not hot.
