Visitor Agreement.
I just love to use the pressure washer, but now the outside water is shut off because of the cold.
-juice
Cheers Pat.
Some gas ones are 2400psi and higher. Those can do some serious damage if not used properly.
-juice
Juice (or anyone else who wants to comment), I saw on your care website that you have door guards on your Forester, and they look pretty tough. Where did you find them? I've looked around in the past and only found simple plastic ones that didn't offer much protection. Also, the ones I put on my Probe actually caused damage to the paint where I positioned it so I ended up removing them anyway. Any problems with your guards? Thanks.
-Norm
Mine were "Racer's Choice" brand ones, pretty lame name but they work fine and have reflectors, FWIW.
Problems? Not really, but you do have to keep them clean. I'm sure the doors would be much worse without them.
-juice
Any suggestions? Can the plastic covers be removed easily?
Daniel
I have a pressure washer which allows me to clean it up pretty good. I'd just use your hose's pressure, which ought to be enough.
If you're detailing, a tooth brush ought to work.
-juice
Daniel
hmmm, after this unsolicited testimonial maybe I should ask Kraco for a commission,
Dave
-juice
Thanks for the tip on the mats. I've been looking for a good set of winter mats to protect the car. I am not crazy about the Subaru protective mats, as they don't seem to be the right size. Now I just have to find out who sells the Kraco's in the NYC area.
Mark
At the bottom of the plastic cover is a slot. Put a screw driver in the slot and pry the plastic cover off. Then unhook the two plastic hooks at the top.
To replace, hook the top hooks over the glass and snap the bottom on.
It is amazing how much muck gets accumulated in there. Yuck!
Daniel
The catch is it's freezing and I'm not off until Friday.
-juice
How thick are these? I prefer to lay the rubber mats on top of the carpet mats.
Mark, Try Kraco (non-Flash version of the site so it'll load a little faster for those on modems). Select Retail Stores.
..Mike
I saw these mats last year but didn't consider them at first because I wanted the waffle-type that claim to hold fifty gallons or more of slush. Then it finally hit me; since I knock my boots off BEFORE I get in the car, and as I haven't yet developed an embarrasing bladder condition, I don't really need anything that capacious. These are simply great mats for a great car.
Dave
-juice
Theo
I'm a huge Darlene fan, so if you buy them, get them from her.
It's just the mats themselves are too small. The rear are small, and even the front only cover the bottom half, unlike the carpeted mats.
Consider just using the regular mats, then buying a new set every 3 years or so. They fit much better.
Or get an aftermarket set and then trim it to fit.
-juice
-Frank P.
I swear you could almost hear her say "aaah!"
-juice
Juice, I hear ya. I've been hand washing my 6mo old soob at least once a week and usually after dark, as long as the temp is above 35 - nothing like a clean car.
-Tony
We've only had 4.4" of snow, and we usually get 16-18" or so. Bummer!
-juice
I've stopped using my pressure-washer for plain washing as well. I find a hand-washing with regular hose pressure to yield cleaner results than a pressure washer with that car-wash solution. Nothing beats some elbow grease.
Instead, I set the spray kind of wide. For the under side, a stream was actually better to remove the sand I had from the OBX.
I still use elbow grease, though. I use the pressurized water to soak it, then the container for car-wash solution to spread a layer of soapy water. I use my hand mitt to clean it (the elbow grease step), and the pressure washer to rinse.
The final touch is the California water blade, which dries it without leaving streaks. Works for me, since I have to wash 3 cars and it doen't take too long (all while the baby is napping).
-juice
I would be interested on anyone's comments .
..Bob
bit
The bottle that I have is of burgundy color that matches a color of my old Loyale quite well. Since I'm seeing more and more nicks and scratches on the Loyale's hood, I've decided to give ColorMagic a shot. When you just apply it (before buffing) it does look like it hides the scratches. The trick is after you buffed it out, all but the tiniest scratches come back.
Most likely, it's a moot point, since I guess it's been discontinued, but I just wanted to let you know that it's a gimmick.
-juice
There is a Chevron down the road with a carwash where the car is put through the auto-wash (you can select wax, etc) and then hand vacuumed, dried, etc.
Do these type of car washes have any adverse affects over long-term??
Caleb
Nothing beats hand-washing, but if you need to use a commercial car wash, try choosing the least abrasive types like "touchless" or "brushless".
The problem with commercial washes are that they never will get your car as clean as a hand wash. Also, the "wax" that you get from these washes are of very poor quality and won't do much in terms of improving the look of your paint let alone protecting it.
If washing it yourself is out of the question and you want to stay in a budget, try the coin-on self wash places if possible.
Ken
Cheers, think I'll be a hose and bucket!
Also, ask how many times the car wash reuses water; some jurisdictions require this. Water is filtered to reduce turbidity (enough that it might even look clear) but for each reuse, water will absorb hydrophiles* like salt, solvent (gasoline, oil), and other chemicals that promote rust or damage the paint. It's possible the car wash mitigates with neutralizing chemicals but I wouldn't count on it. It's more likely the water is used a fixed number of times, then sent to the sewerage.
In the winter, think about how much road salt was washed off the cars in front of you in the car wash queue.
..Mike
*WDB, this one's for you. Flame me if I misused it (I well deserve it).
Seriously, use the sticky end and stick it on the seats, then pull it off carefully. Do this all over the surface until the tape is filthy.
You'll be surpried at how much comes off.
-juice
Good luck
Chuck
bit
Regardless, keep it clean until you do.
-juice
Mark
Try a small area first, and wash it thoroughly when you're done.
-juice
Ken
On an interior note (off topic as it may be), just got my Dad's Buick back from the detailer yesterday - he's in hospital with pneumonia, but the upside is he's going to finally quit smoking, and I had to convert his car back from the ashtray on wheels it's been all these years. What an amazing transformation! Literally looks & smells like a new car! Something to think about before you sell your next car... or maybe a present to your SO... best $140 I've spent in a long time... truly amazing!
Cheers!
Paul
Ross
Cheers!
Paul
Ross
..Mike
