How reliable is Audi A4 2014?
nagra_11nagra_11 Member Posts: 1
edited June 2018 in Audi
How much does it cost to maintain? Currently I have nissan altima 2008. The one I'm thinking to buy has 75000 Km on it.
  • kyfdxkyfdx Moderator Posts: 269,780
    Audi has a reputation for being expensive to maintain and repair, out of warranty. The key would be access to a good independent mechanic shop that specialized in Audi/VW.
    That's the kind of car you have to buy right and keep right. So have it checked over by an Audi specialist before you buy it, and make sure your maintenance on the car is on time and very thorough.
    Since you are out of warranty, this isn't the type of car you want to fall behind on with maintenance--the miles are good, so there should be plenty of life left in it.
  • frank7799frank7799 Member Posts: 1
    after 100k miles you will be chasing the check engine light and oil leaks like its nobody's business. and make it even worse nobody knows what is wrong with the car.. you have to pay the dealer at least an ahour to diagnose the car constantly. then find someone who is competent enough to fix it. And there are only 275 dealers in the country
