I have very important question!!!
Yuxnier ValdesYuxnier Valdes Member Posts: 1
edited August 2018 in Acura
Hello All, I have an Acura MDX 2015 Technology , SH-AWD , V6. I want to install MasterFlow Super 10. Can I connect from the center dual single and then I want to have 2 mufflers, single Super 10 in each side and add the pipes in each side? How does it work? Also I want to know is there any risk installing the Masterflows ? Will my Catalyc Converter have a chance to get damaged ? Are there risks? Please help me!!!
Answers
  • kyfdxkyfdx Moderator Posts: 270,892
    Hello All,
    You want to change the exhaust on an Acura MDX?? Why?
    Sure, it's just a plumbing problem and I'm sure a good muffler shop could do this, but I don't see any benefit for all that expense. Also, while there may not be a risk of major damage, it is possible you could throw a check engine light because your 02 sensor will get confused.
    If you're looking for more noise, you might get that, but if you're looking for any significant power increase, that's not going to happen.
