1147914801482148414853158
    Buy a motorcycle.
    Ya mean motorsickles don't have reverse gears?  :p
    Honda Gold Wing has had an electric reverse for years. Some sidecar bikes have a gear-driven reverse but driving a motorcycle in reverse is most definitely a sure way to crash.
    Rear cross traffic alert.
    @stickguy
    What do you think the range is on rear cross traffic alert though? Will it warn you about someone far away gaining fast on you? If you are backing out slowly, it takes some time to get 3/4 of the way out, and then your a sitting duck.
    Buy a motorcycle.
    Mine does, it's called my feet.
    Bingo. I love mine. very helpful, especially when stuck in a small car between big trucks! And this story is also why I park as far out as possible and hoof it in. That, and to stay far away from shopping carts. plus exercise is good for you.
    No question about it - front and rear cross traffic alert systems are great.  Coupled with those features, my car stops/brakes if it senses an imminent collision with front or rear cross traffic.  Same for pedestrians - it alerts and automatically stops the car if there is an imminent collision sensed.
    The system uses cameras and sensors on both left and right front and rear bumpers.  I can’t tell you how many times in the past 9 months it has saved me from hitting a car or a pedestrian.
    thebean said:
    I'm just curious, is anything ever your fault?
    Absolutely. I take blame when blame is due. Like when I was a teenager and rear-ended somebody at about 5 MPH; thankfully there was no visible damage. My car had a damaged license plate and that's about it. I suppose the license plate frame showed plastic stress "coloring" from being compressed. I'm still thinking the photos show more of a "side" impact than they do my rear going into her. The damage clearly shows fast motion from the right to the left. Not from being compressed inward.
    By the description of the damage to her vehicle she had to be behind you or just almost so when you started backing out. Otherwise how would you have damaged her car doors. If you were at least 3/4ths of the way out and she came by and hit you her damage would have been far more towards the front. based on where you say her damage was I would tend to believe your insurance company did the right thing.
    ---------------------------------------------------------------------------------------------------- Not necessarily. If she didn't see him backing out due to distraction, she could have easily have run into his corner as he was far out of the parking spot. I know we tend to disbelieve @andres3 because of his love of speed, but I'm kind of on his side here, looking at things objectively.
    Not so sure, if he was out as far as he said he was and she was inattentive she would have struck him damaging her front end.
    @stickguy
    depends I think on the angle the car is coming at. If it makes a sharp turn you get less notice. But based on backing out of my driveway, with cars coming down the road at normal speed (say 25-30), with a clearer view it gives a pretty good heads up.
    You keep assuming she was in her proper lane. If she's distracted it's not much of a jump to put her anywhere between the two rows of parked cars.
    When backing out of a parking space or a driveway, if you hit a pedestrian or another car, the fault is yours.  Sure, there is often contributory negligence on the part of a pedestrian or car driver for not reacting appropriately to your car backing up, but try to prove contributory negligence in those cases.  Unless you have 2-3 witnesses who observed that the pedestrian was purposely walking into your car or that the car driver was texting at the time of the accident, the preponderance of fault is attributed to the driver backing out of the parking space.
    My cross traffic alert and braking system reacts in milliseconds- if I don’t brake quickly enough, the car will.
    Do you think braking to a stop milliseconds before impact would save you completely? They could argue your already in the way of their travel lane, and they just couldn't stop in time. Being stopped helps, because be definition you are no longer backing up, you are on more equal footing then, but, I could still see you getting 50% blame in such a case. Even better would be a system that could floor the throttle for a split second and put you in forward gear a;; at the same time to shoot forward about 10' as fast as possible; moving you out of harms way.
    It’s a great warning system. Especially in crowded malls. Will it stop every accident? No. But it sure helps you avoid a lot of trouble.
    It certainly appears that way, but the problem is I hadn't "just started backing out." I was backing out for quite some time already before colliding with her. She was no where near me when I started backing out. Want to do the math on how many feet of distance you cover at 20 MPH (admittedly a guess at her speed) over let's say, 5 seconds? She came from very far away to hit me the way she did. She was not in the proper right lane. I don't think she tried to swerve to avoid me which only leaves two possibilities: 1) She sought out to hit me as I was backing out, and aimed for just behind me. 2) She was in the middle or center left of the two narrow lanes in the parking lot, and not in her proper travel lane. If she was driving on the proper side of the travel lane of the parking lot, she would have hit my doors, instead of vice versa. 3) She was most definitely carrying some speed, I'm pretty sure my guessitimate of 20 is good +/- 5 MPH. At 1 MPH, no one that is parked should be able to hit the front half of the side of your vehicle. That tends to show the coast was not clear IMO. If your back half is hit, that favors the woman. I think insurance companies just look at who was moving and who reached the point of impact first. Since she was going 15 to 20X faster than me, she got there first, but I most definitely had to "pull back in" after getting out of my car, because it was in the way, precisely as I've remembered and described the events. Unfortunately for me, there were several people nearby, but they did not see what happened, they only looked after hearing the sound of a collision, but they were in the parking lot very close by, too bad! I definitely asked them if they saw what she did because an eye witness would have been helpful.
    The problem is if she didnt swerve then you hit her as you were backing out plain and simple, otherwise her damage would have been on her front end. Seeing that your contact with that other car is at the front door tells me that you backed into her as she was passing you.
    Now at 1 MPH you would be traveling at about a foot and a half or so a second. this means you would travel between at least 2 to 3 feet into her path before she could have even touched the brakes. Add that to the stopping distance it is easy to see that you may have not seen her when you started to back up.
    I would really like to hear her side of the story. But by your description of the damage there is not much I can come up with.
    I am not attempting to describe “at fault” blame in my several posts.  My car stops - period!  If you had my cross traffic/pedestrian system on your car, you would not have hit that woman’s car.  She might have hit you - but you wouldn’t have hit her - like you did.
    Just accept the fact that you backed into her while she was driving legally.
    Years ago my wife and a Honda tangled in a parking lot. She was backing out slowly and he turned into her from the parallel drive so that her right rear bumper and his right rear door met. It seemed like the thin Honda metal was damaged a whole lot more than the slight bumper scrape on the LeSabre. The insurance companies each paid for their own car since both cars were moving. Police do not respond unless there's an injury.
    She managed to sneak her front end behind me "just in time" for me to back into her. Hence the damage to my right corner despite backing out straight. This is the essence of your argument and what I think ultimately won her case for her, the fact is I was still moving rearward when she got behind me.
    Saying she's a terrible driver for allowing her car to be hit by a car moving 1 MPH for over 5 seconds at a constant speed and direction, is a true statement, but it doesn't change fault in the eyes of insurance company.
    She was equally as bad or as good as a completely blind driver, and just happened to have gotten lucky with her position and timing. I was easily about 10' into the path of travel before I was hit, but since I was still moving, you can technically say we hit each other, and she had the right of way.
    At the point where I was hit I was so far back I actually was well past the point of "letting my guard down" regarding side impacts, and was merely looking directly behind me. Anyone with 2 working eyeballs that was actually actively using them would not have impacted my vehicle, of that I'm 100% certain.
    edited August 2018
    Let me fix your statement so that it makes sense:
    "Just accept the fact that you backed into her while she was driving with right of way precedence legally.
    Now I get why old fuddy duddies don't like fast drivers. You're afraid you could get blamed when someone going 100 hits you doing 10 MPH, or in my case, approximately 20 MPH vs. my 1-2 MPH.
    Simple physics should make it easy for a car moving 10 to 20X faster to avoid one moving 10 to 20 times slower!
    Particularly at parking lot speeds, how long should one reasonably take to react to a backing out vehicle? Seems like a sure-fire way to inspire insurance fraud. If I wanted to commit insurance fraud, now I know how. Just target a vehicle backing out of a parking space, and make sure you fly by with just inches to spare to make it seem like they backed into you!
  • explorerx4explorerx4 Member Posts: 21,036
    @abacomike,
    Consider it a lesson learned. There is a saying "Don't feed the troll".
    I just think the rule of thumb for parking lots should be changed to:
    1. Front half of the side of your car gets backed into (forward moving car's fault assuming both are moving).
    2. Back half of the side of your car gets backed into (backing up car's fault assuming both are moving).
    Of course, most of the time when you back out you are turning; this was a rare case.
    At least it was the VW and not the Audi :open_mouth:
    @abacomike, Consider it a lesson learned. There is a saying "Don't feed the troll".
    At least we aren’t involved in speeding tickets, lawyers, traffic court, speeders and red light cameras!  It’s still no blessing in disguise.  :D
  • ab348ab348 Member Posts: 20,612
    The changeover to SSO missed a tremendous opportunity, I think.
  • xwesxxwesx Member Posts: 17,930
    Well, I'm sad to report the Alltrack has been violated. This one, as I figured, knowing insurance companies, was pinned on me, despite being 95% caused by the other female driver.
    I was backing out (game over; Insurance company stops listening at this point). I was going very slow, slower than I usually back out, maybe only 1 MPH (but speed kills :angry: )
    Well, not to harp on speed, but I think a crash assessment would clearly show excessive speed on the part of the other vehicle if that driver was going too fast for a parking lot. A collision of that magnitude in a parking lot surely indicates that at least one party was moving waaaaay too fast.
    edited August 2018
    That's a bit scary! How many did you hit prior to having that system?! :)
    I think that if I had a system like that, it would only serve to anger me. If I hit something, it is often because I intend to hit it. For example, if my car stopped itself because a dog ran out in front of me, I would be quite annoyed. I would much rather hit a dog at 5mph than have my car stop me. The dog learns nothing good from the car stopping. :(
    My neighbors used to have a dog that liked to chase cars. After I hit it once at low speed (all the neighbors would stop instead, and then complain about the dog chasing cars), it never chased another car... and the neighbors were able to keep their dog. A much better alternative than the inevitable dogcake.
    edited August 2018
    I should rephrase.
    Please consider showing a little more courtesy to all our posters here, rather than feeling entitled to throw insults just because you take different points of view.
    Yes, the fact she didn't stop till at least 2 car length past me tends to indicate that, in addition to the damage she did to her car which fared far worse than mine. I know the Civic doesn't have 6-piston Brembos, but it's also a pretty light car that can brake fast.
    The problem with blaming speed though is that all she had to do was hit the brakes, or the gas, or swerve a bit more to avoid me! Who knows, maybe she did swerve a bit and in an epic error of judgment didn't swerve hard enough to make tire noises and/or avoid me. Or maybe she sped up thinking she'd get by me and the Civic's little motor failed her.
    If she was going 40 then maybe excessive speed had a role. I think speed was a factor for her, even at 20, as she obviously wasn't paying attention. You certainly shouldn't drive fast if your going to text and drive. You shouldn't even drive slow and text and drive though.
    Given the narrow travel lanes between parking lot spots, I'd say she was going too fast for her.
    Thank you xwesx--we all need to remember basic civility, even in the thick of the storm.
    That's a bit scary! How many did you hit prior to having that system?! :) I think that if I had a system like that, it would only serve to anger me. If I hit something, it is often because I intend to hit it. For example, if my car stopped itself because a dog ran out in front of me, I would be quite annoyed. I would much rather hit a dog at 5mph than have my car stop me. The dog learns nothing good from the car stopping. :( My neighbors used to have a dog that liked to chase cars. After I hit it once at low speed (all the neighbors would stop instead, and then complain about the dog chasing cars), it never chased another car... and the neighbors were able to keep their dog. A much better alternative than the inevitable dogcake.
    On previous cars without that system, I have hit three cars while backing out of a parking space in 55 years of driving.  Not proud - just telling it like it is.
    This S450 is a huge car and has many blind spots.  The cross traffic/pedestrian system has saved me a lot of anguish.  Each to his/her own.  As I age, I know my eyes and reflexes have suffered.  All this system does is keeps me and others safer.
    edited August 2018
    At ten miles per hour, it takes approximately 27 feet from the time a driver sees an obstacle until they can completely stop the car. Ten is the max reasonable parking lot speed. Faster than that is excessive. At 20 mph, the distance increases to 63 feet. So, not only was the driver not seeing and reacting to a clear threat (e.g., if you were going "1 mph" as you backed, it took a long time for you to reach the position of impact), but also clearly going faster than anything that could be considered a reasonable speed.
    Herding dogs chase cars because it’s part of their herding nature. It’s very difficult to unlearn that behavior. And certainly one trial learning won’t work on them. My friend’s border. collie just had to be put in the house when company was expected. And in any case, I would certainly rather have my car stop than hit a dog.
    I should rephrase. Please consider showing a little more courtesy to all our posters here, rather than feeling entitled to throw insults just because you take different points of view.
    Point well taken and appreciated.
    I agree with that, unfortunately Geico mentioned that "speed" is difficult to prove without eye witnesses. She was middle aged, have to admit I was expecting to see a young dude pop out of the car.
  • tjc78tjc78 Member Posts: 17,371
    edited August 2018
    That’s one hit every 18.33 years ...
    Could be worse :)
    I love the cross traffic alert.
  • nyccarguynyccarguy Member Posts: 17,737
    @andres3 - sucks about your Alltrak.  Thankfully nobody was hurt.  Thankfully you weren’t in your TTS.  There are quite a few parking lots that make me very nervous because of how busy they are and how fast some drivers try to “gun it” to get that last spot.  Like you said, unfortunately you are “at fault” in the eyes of the insurance company because you were in reverse.  The speeding & texting woman in the Civic has the right of way.
    Get the car fixed & back on the road.  Mile up whatever rental they give you & report back.  Let us know what the total damage is.
    @abacomike,
    Must be a left coast vs right coast thing.
    OK to hit a dog because it bothers you and you didn't kill it.
    Had a bunny cross the street in front of me this morning, so I slowed down.
    Then it got confused and run straight ahead because it couldn't decide which way to go.
    I didn't hit it to teach a lesson, although it slowed down my commute to work. ;)
    edited August 2018
    Yes, it is a choice we all make. Most herding dogs do pretty well with the car chasing thing. It's the dumb ones that run out in front of the cars to "chase" them that generally end up in the doggie morgue. This was one of those, but it didn't end up there thanks to my efforts. And, really, that's my point: A program and sensors cannot read situations to determine the best course of action; all they can do is make the same response to a given set of input parameters.
    Once in 40 years of driving and that was 30 some years ago. It was the only accident I ever had in a parking lot.
    I may have told this story before. My sister was a rural route carrier for the Post Office in Colorado. One of the places she delivered mail to had this dog that would run up to her car, clamp down on the back bumper of her car and wouldn't let go. She had to slowly drive away dragging the dog until it let go.
  • fintailfintail Member Posts: 58,773
    That reminds me of a good one I saw when I was a kid in the early 90s. A relative with a fetish for big cars had a Lincoln Mark IV, and was rear-ended by a Geo Prizm. I swear I couldn't see damage on the Lincoln, and the Geo had to be hauled away by tow truck. No injuries to either party, but the Lincoln driver said the car had issues after the crash, maybe frame-related as the alignment was always off after that, and they soon replaced it with a 1965 Cadillac. Fun taste in cars. This person is now roughly 60, and drives a Jeep Liberty - fun car days gone.
    When I was a little kid, my mom had some kind of parking lot run-in while in her big T-Bird, I think a Brady Bunch type event where both cars backed out at the same time and bumped each other. I think the other car was an early Celebrity or something, which had some damage, while the T-Bird had nary a scratch due to being built like a tank with thick bumpers. I don't recall the verdict on that, but I think something happened with insurance.
    speaking of miling up a rental, my BIL has had a loaner Jag for a couple of weeks now. His XF is in for some weird rattle that requires welding in the B pillar (hey, it's a Jag, don't ask). And of course, dealer tried and did not get it, now corporate is involved, etc.
    anyway, between taking his loaner XE on vacation, and back to work for a week, he has already put on over 1,600 miles on the loaner. he wants his hotrod version back, but is enjoying putting miles on their car! Might have to bring it back for an oil change (maybe new tires) though soon.
  • driver100driver100 Member Posts: 32,669
    Seems like the rule is....drive faster than average when going forward.....go much slower than average when backing up.
    I know that with my 2011 Kia Soul, backing up is something I must be careful doing. A backup camera would be cool, and it does have a decently big back window, it's just the rest of the box shape is ample enough in dimension ta make my backups slow and careful, especially in a busy southern New Mexico parking lot.
    ab348 - yeah the idea of deleting cookies is an interesting one to try and get myself logged in to Edmunds on my desktop. I notice my browser lists cookies from many sources, about 15 of them related to Edmunds alone. I want a little more information before I go hacking and punting, like I hope the Eagles and Patriots have to do a lot of this NFL regular season.
    Hah! Yeah, that is sorta fun. I put a little more than 1,200 miles on the Q3 I had back in January when my Q7 was having the emissions modification performed. They ended up having it for a whole week, and, being nearly 400 miles away.....
    edited August 2018
    2019 Kia Forte
    This is the new Forte - the Sephia came first. Then in 2002 Kia's Spectra was the successor to the Sephia. The Spectra gave way to the Forte. And here's the 2019 Kia Forte. I'm not sure I like those wheels so much. I'll take a more full-up Cragar mag-type look.
    Ive had some great loaner cars over the years.  The 2 favorites that stick out in my mind were a Saab 9-3 SE Convertible & a BMW 335d.
    There is a dealer in northern NJ (Mahwah Honda) that has had loaner cars since the late eighties.  My best friend bought & services his 1992 Prelude Si there.  There were a bunch of ‘88 Civic with stick and ‘92 Civic With a stick.
    I thought this would be a novel way to spruce up a car;
    Didn’t VW bugs have a little vase for a flower?
    What's going on in Toronto? ….
    According to Bloomberg news "Toronto’s tech scene is so hot the city created more jobs than the San Francisco Bay area, Seattle and Washington, D.C., combined last year, while leapfrogging New York in a ranking of “talent markets.”
    Toronto was the fastest-growing tech-jobs market in 2017, according to CBRE Group Inc.’s latest annual survey, released Tuesday. The city saw 28,900 tech jobs created, 14 percent more than in 2016, for a total of more than 241,000 workers, up 52 percent over the past five years, CBRE said. Downtown, tech accounted for more than a third of demand for office space."
    Read the full article at: https://www.bloomberg.com/news/articles/2018-07-24/toronto-beats-bay-area-in-new-tech-jobs-and-new-york-in-talent
    We have a main office in Mississauga. Toronto area is indeed a hotbed of tech. We’re crying for people at that location and the competition for young techies around there is fierce.
    @abacomike
    I'm glad you had a wonderful visit with your son & grandson for the past few days!
