Won't start
 Curtis Jim Liller
                    Member Posts: 5
Curtis Jim Liller
                    Member Posts: 5
                    I have a 2004 Kia Amanti with the 3.5l engine i have replaced tge ignition coils and the fuses but still won't start  it is getting fuel and i have pulled out the plugs in the front to see if it has spark and nothing the car ran until I parked it to find the harmonic balancer pulley for the alternator split. Does this car requires the pulley and belt to be together or can i check it out?
            Best Answer
             Curtis Jim Liller
                            Member Posts: 5
                    Found out there was a bad wire for the security system that was in need of replacing and now it runs!0 Curtis Jim Liller
                            Member Posts: 5
Answers
If the pulley is broken, then when it came apart, it may have damaged other things.
Timing belt and crank sensor run off of the crankshaft, so a bad pulley and there may be more damage than what you can see.
