Radio and interior light not working on 1995 Dodge pickup.
swhe280swhe280 Member Posts: 2
edited August 2018 in Dodge
The brake warning light was on so it took the truck in to have it checked out. The shop fixed the issue with the brakes but when it got the truck back the radio/clock and the interior light won't come on. I checked the radio fuse in the door post panel and I have power coming to the fuse when the ignition is on. I can't see where any harness is unplugged. I pulled the radio out of the dash and I have power to the red/white wire with the ignition on. On other radios I've worked on there are usually two wire that are hot. Any suggestions? Do the radio and interior light share a wiring harness?
Best Answer
  • swhe280swhe280 Member Posts: 2
    Answer ✓
    Just found a blown IOD fuse. A new fuse and everything works fine.
Answers
