There never were many 6 cyl 914s, they were pretty expensive and they're very rare now
"The most detrimental defect to look for in a 914 is rust. The worst cases of rust are usually caused by a relatively simple design flaw: the battery location. Mounted on a tray in the engine compartment, batteries would leak acid and start to corrode the tray. A rusted battery box can indicate deeper problems, as well. Left long enough, the corrosive substance can eat its way through the battery tray and the metal around it — forming what is known as the “Hell hole” — and allow battery acid to drip onto the boxed sheet metal where the right-rear suspension is mounted to the chassis. This takes major work to repair. The rocker panels on both sides of the 914 are also prone to rust, but unless there’s rust visible on the outside, they’ll need to be cut out to find out for sure.
It's too bad gel-type batteries weren't required for these cars, as there would be a lot more of them left today. If you purchase a 914 with a liquid-filled lead-acid battery, we recommend upgrading to the gel-type to avoid corrosive spillage. Finding a 914 without rust is a tall order, but fortunately the aftermarket has recreated most of the necessary sheet metal to repair the common rust-prone sections. New battery boxes are available as well, so look to see if the tray is welded or bolted in; if bolted, it has definitely been replaced."
Two other oldies visible are the late 40s Ford (or Merc) going toward camera in the bottom left. Another old Ford of that vintage is turning left at the light.
Very distinctive chrome and color statements back then.
This photo was taken in Tazewell VA, a coal mining town which obviously prospered during the 50s (Lots of late model cars). Since then it has fallen onto hard times but now they are attempting to make use of a different kind of resource, twisting Mountain roads that might attract sports car and motorcycle enthusiasts. They're calling it "The Back of The Dragon" emulating the success another Smokies town, Deals Gap TN and it's "Tail of The Dragon".
Sounds like cool fun. (search Google or nytimes.com for more info-I can't make links work today)
Street could be in Tazewell County Illinois.
Click on this picture of 'Vette>
I think the 'Vette is a 1958, the aftermarket scoop is right where the lovers would be on a '58. You don't see many Corvettes sporting aftermarket mods but this one has some that were common then. Do you see 'em? There's at least some trim that has been removed too, see it?
The photo was taken in Tazewell County, East Peoria, Illinois.
Looking down East Washington Street, cars are turning left from South Main Street onto West Washington Street.
Bank is now a Planet Fitness.
I would imagine Iveco make more trucks now, but they certainly don't make anything like this.
I had to go online to find the connection between Turin-based IVECO and Pegaso. Wikipedia sez that Enasa based in Barcelona bought Pegaso and was in turn taken over by IVECO in 1994. The Pegaso(Pegasus) name was retired in 1994 after production of vehicles had ceased around 1990.
That blue looks stock to me. I have a scale '67 GT350 in the same color, it could be that there was more than one blue available. I've seen various Shelbys and Cobras painted all sorts of metallic and non-metallic blues.
Sounds good, too:
have appeared on new generation Mustangs.
When the car came out I sent a note to one of car magazines feedback forum about how they really cheaped out by using Ford bits inside. They published my note with the title “Qvale is job 1”
(CVA-60). It was a lifetime ago but the second USS Saratoga was scrapped sometime ago. The first (CV-3) was sunk at the postwar Bikini atomic test along with a fleet of prewar US vessels and former battleships and cruisers of the IJN.
Front car an 88? Mustang GT in any case. I can’t tell years apart.
Also a car I like as a mild resto mod. Crate motor, 5 speed, upgraded suspension and 4 wheel disks. Stock body, better seats.
The Bundys approve
