Nissan Sentra Rear Alignment Problem
My Sentra -2013 vehicle had Rear Alignment problem
i replace back wheel full set, still my Rear tyre chipping one side, how can i rectify the alignment
Best Answers
Mr_Shiftright
Member Posts: 64,481
Probably not a DIY kind of job. You may have to go to an alignment specialty shop and have them put it on their alignment machine. It's possible that some prior road damage is causing this. They have the equipment to either bend things back into specification or replace the damaged part. I'm thinking something like a bent spindle.5 -
thecardoc3
Member Posts: 5,870
Not from the factory, but there are aftermarket solutions that make all four wheels adjustable.5 -
thecardoc3
Member Posts: 5,870
As I said above, not from the factory, but the aftermarket has a solution. Shims are installed between the rear hubs and the rear axle. Here is a picture of your rear axle without the wheel hubs.Sentra_2013 said:Sentra Vehicle , there is no back wheel alignment
Here is a link to EZ Shim. Note they do have to be selected by the vehicle and the amount of adjustment that is required. To make the adjustment the the two halves of shim have to be rotated to a specific setting as instructed by the alignment machine, or by a reference chart.
https://express.google.com/u/0/product/404409229333405815_11862889999572879234_6538286?utm_source=google_shopping&utm_medium=tu_cu&utm_content=eid-lsjeuxoeqt,eid-ygcnqnyulq,eid-lcjybysgxm>im=CN_J8c3E5YzuIhCW7LWIs52O1lkY8IOsBCIDVVNEKKCQ_d8FMK6IjwM&utm_campaign=6538286&gclid=CjwKCAiAiarfBRASEiwAw1tYv3a6b_RMPXOSkB2xMV_57aLWCi9-2TtGAYuVKyBUWiYlOJzlI7LZLxoCm8IQAvD_BwE
1
Answers
Because i checked many car work shops in UAE abu dhabi for this problem. every body answer " sentra vehicle there is no back wheel alignments " , after that i changed back wheel axle set . still back wheel cupping edge tires ( toe wear tire)
i searched in internet - answer - change back wheel shim
Please reply
My experience says that any camber setting greater than 1 degree may cause uneven tire wear - regardless of the vehicle. This is NOT what the stock settings say - and I think they are wrong.
So I think you need to get an alignment and tell the alignment tech you want the camber to be under a degree regardless of what the published values are - and ask for a print out so you can verify.
